05-24-2009, 07:29 PM | #1 |
Member#: 54702
Vehicle:2000 impreza 2.5rs brp |
AFR gauge impressions and question
Before I post my little story, I would like to address the fact that yes I have read the many threads regarding narrowband AFR guages and how they are basically useless. This is further proof that the popular negative opinion towards these light shows is true.
A while back, a friend of mine gave me an old narrowband guage that he didn't need anymore for free. After reading the threads on here about them, I never really had any inclination to install the thing. However, a few days ago, I decided to ghetto-rig it so that I could use it to test the differences in readings between my stock and catless exhaust, stock and reflashed ecu, and possibly to check if any sensors are going bad (by swapping sensors with friends and see if any changes occur in readings). I wasn't expecting anything accurate, but from what I got I really think that these gauges are garbage. I used kastle's write up on scoobymods.com as a reference for the install, except that I didn't cut or splice any wires. I strictly did this to test if it would work. Instead of splicing the ecu harness, I was able to connect the guage's wire by sticking it near the connector. AS soon as I started up the car, the guage starting reading the AFR and it slowly rose up all the way to rich. Now, this is where I was going to come back and ask you guys what you thought about it. I was going to ask if this was because the catless exhaust and the ecu reading too much emissions or if it was just a bad reading. However, I found something quite peculiar when I disconnected the guage completely, hooked it up to a battery only, and found that the guage was still reading AFR levels all the way rich. How could it be getting a reading if it wasn't hooked up to anything? Anyway, I just wanted to post up and see what other people thought. I was going to ask if using this guage was a reasonable method to try to test differences between mods and possibly sensors on their way out, but I think I have my answer.
05-25-2009, 01:42 AM | #2 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
All it reads is a voltage offset between two points. 0V will read as rich. You didn't have it wired in right.
But yes, it's totally useless anyway. |
05-25-2009, 02:07 AM | #3 |
Member#: 157348
Vehicle:I Thlammed My Penith in the Car Door |
I've heard that the front O2 sensor is actually not a narrowband, but not exactly a wideband either - sort of a ...middleband.
Can anyone confirm this? |
05-25-2009, 02:09 AM | #4 |
Member#: 54702
Well, I'm glad I didn't splice wires for no reason. I'm still puzzled as to why the gauge was getting any kinds of readings after it was diconnected from the ecu. I tested if it would even light up on a battery before I installed it and it didnt show any readings. After I uninstalled it, I tried the same, and it was still maxed out at rich like when it was hooked up to the car. Now, even a few days later, it is still getting readings when I hook it up to the battery even though it hasn't been hooked up to the ecu. It's just all a bit strange to me I guess. It's like ghost in the machine.
05-25-2009, 02:12 AM | #5 |
Member#: 54702
That I don't know, but according to Kastle the wire I had hooked it up to was for the rear o2, so it was narrow to narrow. I figured this would be actually accurate because of the lack of cats in my car. But whole experiment was useless though.
05-25-2009, 02:21 AM | #6 | |
Member#: 157348
The primary difference, as I understand it, is that the front O2 sensor is 5v, the rear is 0-1v. If there were a way to get the gauge to run on 5v rather than 0-1v, theoretically the readings would be far more accurate. Especially because of the fact that my rear O2 sensor is plugged anyway |
05-25-2009, 02:29 AM | #7 |
Member#: 157348
emailed my contact at Autometer. Let's see what he says.
05-25-2009, 11:02 AM | #8 |
Member#: 1853
TXIC
Vehicle:GC6 Supercharged STM |
Keep in mind also, that these o2 sensor must be up to operating temperature before they work correctly. Your strange readings in open air could easily be due to that.
05-25-2009, 06:07 PM | #9 | |
Member#: 54702
http://www.scoobymods.com/forums/aut...uges-t153.html - link to Kastle's write up. Edit: On 2nd thought, I never disconnected the battery. Would that even make a difference? The ecu reset anyways since I diconnected the harness. |
05-26-2009, 12:29 AM | #10 |
Member#: 157348
it might.
It looks like there's nothing preventing one from wiring it to the front O2 sensor...weird. |
05-26-2009, 12:30 AM | #11 |
Member#: 71092
The first line of post #2 contains the answer to the stuff you guys are still wondering about.
05-26-2009, 12:36 AM | #12 |
Member#: 157348
05-26-2009, 12:40 AM | #13 |
Member#: 71092
The gauge reads the voltage offset between the sensor signal wire and ground. It turns that voltage offset into an AFR to display. The gauge controller doesn't know or care if the sensor signal wire is hooked up to an O2 sensor, a battery, a gerbil running in a wheel, or just dangling in the air. It'll take whatever the voltage offset is and convert it for display.
When the signal wire isn't connected to anything, it's said to be floating. A floating input can do a large number of things, but the important thing is that you can never really be sure what the result is going to be. So when you had your sensor wire not hooked up to anything, the gauge was still merrily displaying the result for you. The result just happened not to mean anything. |
05-26-2009, 01:11 AM | #14 | |
Member#: 157348
My question is why hook it up to the rear O2 sensor when the front O2 sensor has a much wider band? |
05-26-2009, 01:16 AM | #15 |
Member#: 71092
Ah, I was only addressing the question you asked at the end of your second to last paragraph.
And the front and rear O2 sensors work on different principles. The cheapassed NBO2 gauges can only read the rear. |
05-26-2009, 02:41 AM | #16 |
Member#: 157348
05-26-2009, 07:38 AM | #17 |
Member#: 38222
Vehicle:'10 &'12 Foresters another Miata convert |
You really can't. The front/wideband O2 sensors read very differently than the simple rear/narrowband ones, and it's a lot more than 0-5v scale versus 0-1v scale.
You'd think that if it was as simple as hooking up a narrowband gauge on a voltage reduction, it would have been done by now, yes? |
05-26-2009, 07:06 PM | #18 | |
Member#: 157348
The worst that happens is I need to splice another wire |
05-26-2009, 07:10 PM | #19 |
Member#: 71092
Alright, Einstein, what's your little gauge gong to do when it's expecting voltage to change and voltage doesn't change?
05-26-2009, 07:18 PM | #20 | |
Member#: 157348
Honestly, I don't know. I'm just hoping there's some way for these to NOT be completely useless I'm going into this like I go into most of my projects - swinging blindly and hoping to hit something. |
05-26-2009, 07:31 PM | #21 |
Member#: 71092
The only way to make a NBO2 display like that worth a damn is to feed it with the output of an LC-1 WBO2. Then it's somewhat useful.
05-26-2009, 07:49 PM | #22 |
Member#: 157348
245-40-17 Impressions and Questions | subber | Tire & Wheel | 12 | 02-02-2007 01:41 AM |
STI impressions and questions | mdlfcrisis | Impreza Forum | 1 | 01-29-2006 03:27 PM |
I have finally driven the Evo...my impressions and questions on modding... | silver ghost | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 42 | 02-27-2004 11:55 PM |
First impressions and questions | XRayHipp | Newbies & FAQs | 7 | 02-17-2004 01:04 AM |
Couple of UTEC impressions and questions | roybfr | Engine Management & Tuning | 14 | 11-11-2002 07:01 PM |
