05-27-2009, 07:05 PM | #1 |
Member#: 170322
Vehicle:04 wrx Blue |
Got code P1135...
so my cel came on when i was coming home from work and the accessport wouldnt pull it so i had a local shop see if they could. he said he got p1135. does anyone know what it means exactly?
P1135 O2 Sensor Circuit (Open) (Bank 2 Sensor 1)
05-27-2009, 09:14 PM | #2 |
Member#: 166082
SCIC
Vehicle:06 STI WRB |
did you bypass your cats?
05-27-2009, 11:41 PM | #3 |
Member#: 212504
quick question
Need 3 posts to add a thread, but I'll ask here anyways. I have a 2002 wrx. Got a CEL a few weeks ago. Figured it would go off after a few starts but it didn't I went to Autozone but their code puller said no link. Is there a fuse I should check to make sure the OBDII port is functioning? I check the fuse box in the car and under the hood but there is not one labeled as OBD
05-28-2009, 01:06 AM | #4 |
Member#: 170322
i believe the uppipe one is but i still have the one after the dp and i "think" one a little father back. its been like that for 3years now and this is the first time cel. i am stage 4 btw and run rich...so im thinkin a sensor is wearing out
05-28-2009, 01:07 AM | #5 | |
Member#: 170322
do a hard reset....pull pwer cable from battery and pump brakes...see if it comes back. |
05-28-2009, 12:19 PM | #6 | |
Member#: 212504
Thanks for the help I'll try it today -Search |
05-28-2009, 06:55 PM | #7 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
P1135 does not exist on a 2004 WRX. No wrx has a bank 2 sensor 1.
retry... |
05-28-2009, 09:49 PM | #8 |
Member#: 166082
SCIC
if you have put on up pipe and down pipe you will throw that code until you get a tune. if you got a tune and still throw that code then you need to take it back to your tunner. even if you clear the code, you still need to fix the problem or it will come back on. and the code p1135 does exist on a 04 wrx because i had it also
05-30-2009, 01:56 AM | #9 | |
Member#: 170322
so is there anything actually "wrong" with my car then? i got a protune about a year ago. |
[DI$COUNT CODE INSIDE] Formula Drift runs "The Gauntlet": Round 3 - Wall, NJ | PostRelease | Tri-State Area Forum | 0 | 05-28-2010 12:59 PM |
got codes, need some brain power... | 07xtreme | Subaru Conversions | 9 | 04-13-2010 07:22 AM |
got codes pulled with interesting result. | justboosted02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 01-30-2006 04:58 PM |
CEL is ON, Got Code, dunno what to do now.... | ScubyMedic | Service & Maintenance | 10 | 12-10-2005 11:30 PM |
got codes pulled now what?? | willyb | Service & Maintenance | 6 | 07-24-2005 06:10 PM |
