Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 07-03-2009, 08:54 PM   #1
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
Default Boost leak
Ok so I have what is probably considered a stupid question. I have a boost leak and can't track the dam thing down. Is there a common spot that the TMIC's and other boost pipes leak. The TMIC is an Ebay unit and the TMIC to TB boot is factory. I have not actually checked the TMIC for a leak but it checks out fine visually. any help is appreciated I cant stand not making full boost.
*6STARS* is offline   Reply With Quote
Old 07-03-2009, 09:53 PM   #2
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
did you check the Y pipe? And did you reuse your stock Y pipe?
KP is offline   Reply With Quote
Old 07-03-2009, 10:51 PM   #3
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
ya the 4 bolts are tight and so is the 3 hose clamps that are on there and they are the good clamps. no I did not reuse the stock y pipe. How do you guys if you have build an intercooler pressure checker?
Old 07-03-2009, 11:03 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
So how does the y-pipe connect to the ebay tmic? Are there bolt-on elbows as found on the OEM one? Maybe check those (where they attach to the tmic) as well as where the diverter valve connects to the tmic - maybe the gaskets are broken/damaged? Double check the coupler between the tmic and throttle body and make sure that's sealing properly, too.
there are instructions for a DIY boost leak checker on scoobymods (probably on here as well if you search)
Old 07-03-2009, 11:19 PM   #5
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
yes they are bolt on elbows, checked them. The gasket between the TMIC and the factory BOV is cork and RTVed caused It leaked on me when I got it but I had it sealed for the longest time and I did TGV's last wekend and now I am making 3#'s less boost than I was before. TGV's are tight I torqued them to factory specs. Also when I shift when in boost I hear a buzz/squeek sound ( the sound is very hard to describe). I also did an APS turbo inlet at the same time. I am just super confused. sorry if none of this is very well put together I am really tired and stressed out with the situation.
Old 07-04-2009, 01:08 AM   #6
gormonk
Member#: 98960
1978 brat (fo realz)
red
take dish soap and pout it around all the connector and take a spin around the block. dont water it down any. that way it will stick better. then just look for the bubbles
gormonk is offline   Reply With Quote
Old 07-04-2009, 08:46 PM   #7
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Bump for an update?
Old 07-04-2009, 09:05 PM   #8
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
I am out of town as of the moment so I have not been able to check it out. I am thinking that when I did the TGV's I put a small kink in the BOV recirculation hose where it connects to the APS turbo inlet and maybe the air can't make it around the bend fast enough and builds to much pressure and blew out the BOV to TMIC gasket. I would think I would then get compressor surge too if that happened. The kink is really small but maybe that is what is happening. Is there a common spot Subarus leak boost with a TMIC?
boost leak vs. vacuum leak exclusivedetails Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-25-2013 03:45 AM
boost leak or exhaust leak? sc0013z Texas Impreza Club Forum -- TXIC 42 02-17-2008 09:08 PM
vacuum leak vs. boost leak exclusivedetails Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-04-2006 08:29 AM
Checked for boost leaks, purge valve leaks, any ideas? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-05-2005 03:55 PM
I did a boost leak test..and found some intresting leaks. BoostedAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-13-2004 08:56 PM
