Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 07-13-2009, 12:40 AM   #1
scoobymuff
Member#: 163563
04 aspen white Sti
DOM3,06 sti,95,02,03wrx's
Default OK need help? (trunk swap problem)
ok so.. i have a 06 sti trunk and i traded with a 06 wingless trunk. I switched the locks, the tension rods, and the latch from the trunk. We swaped the trunks bolted them down and they wouldnt shut.. we tryed switching the latches back but still wouldnt shut on either car. I did some searching but didnt find any similar problems. Am i missing something?
scoobymuff is offline   Reply With Quote
Old 07-13-2009, 12:49 AM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
I dont think you switch latches. I didnt switch mine when I got my wingless. That may be your issue (something no longer lining up)
v8eaterWRX is offline   Reply With Quote
Old 07-13-2009, 12:53 AM   #3
scoobymuff
Member#: 163563
04 aspen white Sti
we tried it first without switching the latches and thought maybe we needed to, but still didnt work. So u think it is one of the latches that needed adjustment?
Old 07-13-2009, 12:54 AM   #4
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Hard to tell without being there honestly. I have never heard of anyone having that issue before.
Old 07-13-2009, 12:56 AM   #5
r0bman
Member#: 87015
What do you mean by "won't shut?" Does the trunk like not come down flush with the body? Or does it go flush, but the latch won't... erm, latch?
r0bman is offline   Reply With Quote
Old 07-13-2009, 12:56 AM   #6
scoobymuff
Member#: 163563
04 aspen white Sti
ya i know thats why it has been so hard to search for a solution.
Old 07-13-2009, 01:01 AM   #7
scoobymuff
Member#: 163563
04 aspen white Sti
it comes down flush it just wont latch.
Old 07-13-2009, 02:16 AM   #8
All4BeSpinnin
Member#: 210456
2006 WRX
OBP - How Low Can He Go??
yessssss, weeeee need help people! lol
bump-o
All4BeSpinnin is offline   Reply With Quote
Old 07-13-2009, 02:39 AM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
Are the latches open? can you latch it by turning the key and the closing it and the releasing the key?
Old 07-13-2009, 03:19 PM   #10
wrxkid85
Member#: 108452
2005 Impreza WRX
One of two things is most likely happening.
Like kpluiten offered, the latches may be closed.
Or the latches need some adjusting. I had trouble with tspinks cf deck lid... couldn't get it to work... and had to put my deck lid back on. Come to find out, he had to adjust his latch to get the cf deck lid to latch. Why he didn't know that... I don't know.
wrxkid85 is offline   Reply With Quote
Old 07-13-2009, 08:01 PM   #11
scoobymuff
Member#: 163563
04 aspen white Sti
ya we did try having the latch open and closed and any other position i could find, and still no closing. And yes even with the key in it, it still wouldnt close. Adjustment in which way? like side to side or up and down?
Old 07-14-2009, 02:02 AM   #12
wrxkid85
Member#: 108452
2005 Impreza WRX
Yeah, sounds like you're having the same problem I had. I imagine you'll need to adjust the latch in any way it needs... up, down, left, or right.... which may be kinda hard to judge.
Maybe have someone looking through the pass-through in the backseat, into the trunk. That way you may be able to see where to adjust the latch.
Old 07-14-2009, 04:05 AM   #13
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
put a screw driver thru the latch and turn the key as you pull down with the screw driver.. itll flip the little claw back over to the right
szeny is offline   Reply With Quote
Old 07-14-2009, 04:57 AM   #14
Jim.mEh
Member#: 84517
05' Imprezilia
CruiseControl Warrior
^^ thats exacty what I was thinking.
The trunk latch is pretty simply
I really dont see how this can go wrong.
unless you try to slammed it shut while the latch was enaged(as if it were already wrapped around the hook point) and now has become broken because of it.
Jim.mEh is offline   Reply With Quote
Old 07-14-2009, 05:08 AM   #15
shemoves
Member#: 80663
2005 STi
When I did mine I think I actually crawled into the trunk with a flashlight and tools. Make sure you have help though...you don't want to get stuck in there with the heat. If you are a big guy, perhaps take out the back seat...it is VERY easy.
shemoves is offline   Reply With Quote
Old 07-14-2009, 07:06 PM   #16
scoobymuff
Member#: 163563
04 aspen white Sti
i understand how the latch works, it works perfectly fine with my trunk on. Just with the wingless regardless if we switched latches it would not shut. And no i didnt just slam it shut i have more sense then that.
Old 07-15-2009, 10:46 AM   #17
WRXtra
Member#: 191200
04 STi
WRB Flame Thrower
I had the same problem when i installed my CF trunk it just wouldent latch but was lined up right, i had my little brother climb into the trunk and see why it wasent latching. Come to find out that the latch was too far forward (toarwds the front of the car) and no matter what we did we couldent get it to line up.
What i ended up haveing to do was remove the entire latch and put it into a vice and flatten the bracket, not compleatly but just enough to get the hook to line up with the hoop. Look to make sure this is your problem and be very careful if you go this route because you can easily break it, go slow and take your time and only do minor adjustments, this should fix your problem.
WRXtra is offline   Reply With Quote
Old 07-15-2009, 11:33 AM   #18
Jim.mEh
Member#: 84517
05' Imprezilia
With OEM trunks, removing the latch and adjusting it in a "vice grip" should be far from necessary…
With that is mind maybe one the vehicles had a rear fender bender..
need help with swap, quick help. (pic request, tranny x-member) Keith Off-Topic 13 09-15-2004 04:35 PM
need a trunk swap write up will667 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 05-07-2004 11:32 PM
OK need help here 2.2l into 93 L ImprezaRacer Subaru Conversions 4 05-01-2004 12:17 PM
ok, need help choosing which turbo for mysetup---> 1WikdWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-27-2003 04:33 PM
OK, need help now!! IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-24-2002 12:24 PM
