Welcome to the North American Subaru Impreza Owners Club Sunday September 24, 2017
Old 07-17-2009, 05:09 PM   #1
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
Default Do I need a tune or can I get away with an accessport map?
Been a member on this forum for a while but the EM&T section is new to me. I have a couple questions that may border on noob but all opinions/advice would be much appreciated.
The set-up:
2004 WRX
Mods:
-3"exhaust, 3"downpipe, aftermarket (catless) up pipe, headers, and underdrive crankshaft pulley.
The dilemna:
I blew the transmission and while it is being repaired, I have taken the opportunity to upgrade the aforementioned parts. Since the install, the car has not been driven, started etc. I have installed upgrade on previous N/A cars, however, this is the first turbo I've owned. My questions are:
1) I own an AP V1. Will a map take care of these mods or should I get it pro-tuned?
2) Are there any issues besides lower fuel mileage, I might run into if I were to drive it untuned for a period of time, (a month)? The reason I ask this is I live in a part of pa that does not do emissions testing. However, I may fail a visual inspection in which case I would have to reinstall the stock downpipe, get the vehicle inspected, then pull it off again and reinstall the catless downpipe. On a sidenote, I have thought of the catted downpipe, but I got a really good deal on the pipe and really wish to upgrade to the full three inches.
Again I appreciate an and all helpful info.
down_for_the_scooby is offline   Reply With Quote
Old 07-17-2009, 05:33 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I would put the stage 2 map on it rather than drive it untuned... and get it pro-tuned as soon as you can.
wrxdrvr is offline   Reply With Quote
Old 07-17-2009, 06:07 PM   #3
Woodward
Member#: 102424
2003 Tundra
GrEy
With an AP OTS base map, "stage 2" in your case you'll be fine. You'll run a bit rich for safety purposes but it wont be as good as a protune. Just dont run those mods on the stock map.
Woodward is offline   Reply With Quote
Old 07-18-2009, 03:18 AM   #4
down_for_the_scooby
Member#: 78314
04 PSM WRX
I am financially drained from all these upgrades and the transmission. Will the stage 2 work indefinitely? Also what does happen if driven with stock map?
Old 07-18-2009, 03:22 AM   #5
down_for_the_scooby
Member#: 78314
04 PSM WRX
One other thing. On the potential pro-tune place Evan's Tuning (evanstuning.com) they advise against running synthetic oil. I run fully synthetic as I was under the impression it was superior to regular oil.
1) am I wrong
2) will this f*** up my tune and eventually my car?
Old 07-18-2009, 09:07 AM   #6
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
1) am I wrong
dude there are a 1000 threads on this topic. most people stay away from mobil 1. as long as you keep up on regular oil changes i dont think it makes any difference.
424wrx is offline   Reply With Quote
Old 07-18-2009, 02:16 PM   #7
pushnpounds
Member#: 207683
02 bugeye
wrb
you can run no map or the stage 2 cobb i had the same mods and drove without a tune for a while with no trouble i now have the stage 2 and it runs great the stage 2 map calls for exactly the mods you have and the pulley won't affect the tune i have been running full synthetic in my car with no trouble
pushnpounds is offline   Reply With Quote
Old 07-18-2009, 03:35 PM   #8
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
you are telling the op its ok to run no tune with a downpipe?? thats wrong info and could potentially cause issues. dont post things like that if you dont know.you HAVE to be tuned with a downpipe. period.
Old 07-18-2009, 04:14 PM   #9
b00stin
Member#: 212898
05 CGM STi
WFC #289
Flash Stage 2 then save up for Protune... You wont get the full HP with stage 2 and your headers but it will run safe. Listen to this though^^^ Your car needs some form of a tune.
b00stin is offline   Reply With Quote
Old 07-20-2009, 05:07 PM   #10
down_for_the_scooby
Member#: 78314
04 PSM WRX
Cool. I'm really not looking to rice this car, so I really appreciate all the info.
Old 07-29-2009, 07:14 PM   #11
liljon350
Member#: 197068
2006 WRX evo316g'd
WRB 293whp/322tq [email protected]
you can actually run safely untuned on a 02-05 wrx
liljon350 is offline   Reply With Quote
Old 07-30-2009, 08:09 AM   #12
el_guapo
Member#: 132038
funk er chicks
serious bidness
This worked for you because you have a 02. It will not work for the OP because (according to profile) has a 04. Don't assume something that works for you will work for any WRX and don't give advice unless you are SURE about it.
Yes, correct in this case and in general. However Bugeyes ONLY can safely run downpipes without a tune but really won't see any gains until tuned.
Bugeyes ONLY. It seems as time goes on this is becoming more commonly misunderstood and I am not sure why.
el_guapo is offline   Reply With Quote
Old 08-17-2009, 11:24 PM   #13
nickyOTH
Member#: 158930
2007 STI
I had a turboback exhaust on my 05 wrx for two years with no tune and had no problems...unless you consider faster spool up a problem...i know that with the 06 STI you cant do that due to boost spikes but that was corrected in the 07 Sti by a little wastegate porting...and yes i had a turboback on my 07 STI for a short time with no problems...
nickyOTH is offline   Reply With Quote
Old 08-18-2009, 07:19 AM   #14
down_for_the_scooby
Member#: 78314
04 PSM WRX
Hey folks actually got a AP V2 off another member here, (Thanks 96vj), I've heard there is a learning curve that takes the car a few days to learn the new stage 2 93 octane map. I ask this as I just reflashed it on Sunday and drove it for the first time yesterday in 3 1/2 months. It feels nice but it definitely does not feel like an additional 40+ hp. Can anyone answer this?
Old 08-18-2009, 12:48 PM   #15
liljon350
Member#: 197068
2006 WRX evo316g'd
it takes time to learn the map
Old 08-18-2009, 08:19 PM   #16
down_for_the_scooby
Member#: 78314
04 PSM WRX
How long, 2 days, a week etc. And does the gain come slowly or does it just happen?
Old 08-21-2009, 11:24 AM   #17
humperdinc
Member#: 205625
2009 Impreza WRX
obp
I installed a Perrin Stage 2 map on my 09 WRX and it seems as if it learned it pretty quick; quick as in running the car semi-hard the same day and I definitely felt the difference.
humperdinc is offline   Reply With Quote
Old 08-25-2009, 06:54 PM   #18
intrinsic
Member#: 132000
Get a custom tune man...I blew my motor up with a standard map. IA performance will do a tune over the internet for like 75 bucks...pretty cool. 75 bucks or $7500 bucks for a new motor...
intrinsic is offline   Reply With Quote
Old 08-25-2009, 08:19 PM   #19
Cobb Tuning
Member#: 4803
Our OTS maps are a little too conservative to be blowing up engines. I would be curious to know what else was going on with your car to precipitate engine damage. The OTS maps is a great all-around conservative map, but a ProTune is always going to give you more performance while maintaining that reliability.
Travis
COBB Tuning
COBB Tuning Facebook Group
COBB Tuning MySpace Page
COBB Tuning Twitter Page
Old 09-05-2009, 03:23 PM   #20
mgrych
Member#: 222778
2007 WRX STI
Hate to just jump in on this thread but i have a super newbie question. I was looking at cobb st. 2 for my sti 07 and was trying to figure out exactly what the whole package requires to work properly. Do you just purchase the package, install the pipes, and software/maps or whatever and go about you business with the added HP and TQ? Or is there still a requirement to take it somewhere to get it tuned? I was under the impression that the maps and software that came with the near $2000 package took care of all that mess but am now second guessing the process.
mgrych is offline   Reply With Quote
Old 09-05-2009, 09:14 PM   #21
casper1jr
Member#: 208012
07 WRB STi
Tuned @ 21psi
If you have a catback just flash stg1 and your good. For stg2 you need a downppipe!!! I would buy the AP alone and shop around for a used good quality turbo back to save some cash!!
casper1jr is offline   Reply With Quote
Old 09-07-2009, 09:46 AM   #22
bluemicamatt
Member#: 220246
2007 WRX TR
mgrych,
I'm only at Stage 1 with my '07 WRX, and have been for a month or so using the AP V2 and Cobb's 93 octane map. the difference over stock is really worth it and the V2 is a fun toy.
This weekend i'm headed to Chicago for a wedding, and getting a protune up there. The additional expense of a protune probably isn't necessary, but it should enhance the tune above the off the shelf Cobb map.
I don't have an STI and am a noob, so take my opinion with a grain of salt. It seems to me though that the OTS maps are good but a pro-tune is even better. Is it $350 extra better? no F'in clue... at Stage 1 the consensus is NO, at Stage 2 the consensus is YES.
I'm doin' it just to do it & brand new to all this and have more $ than brains I guess! It is a bitter pill to swallow though - spending $500 on the Accessport and then another $350 for a protune a month or so later.
a decent analogy might be buying a suit. the OTS maps are a nice italian suit that'll set the tone for your look...way better than a t shirt and a pair of Umbro's. A protune is adding dope shoes, a shirt, matching tie, socks, and that ghey little silk hanky that sticks out of the chest pocket. You're in the door with the suit, but "pullin' wool" once it's all doll'd up.
bluemicamatt is offline   Reply With Quote
Can I get away with an oem replacement clutch Overboosting04 Transmission (AT/MT) & Driveline 13 03-23-2010 04:36 PM
do you need a tune or accessport for a catless dp yamaha_rider619 Service & Maintenance 1 02-24-2010 05:13 PM
How boring is your jerb- or, what can you get away with? burningman Off-Topic 3 06-23-2006 11:56 AM
Can I get away with just the Stage 2 Map with these mods or is a Protune necessary? Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-16-2005 12:11 AM
what fuel mods can i get away with, and NO ecu re-tuning WRXallNiteLong Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-21-2003 07:29 AM
