Welcome to the North American Subaru Impreza Owners Club Tuesday November 12, 2019
Closed Thread
Old 02-04-2011, 08:57 AM   #4776
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
For those that are interested, lorenkb first showed pics of this alllllll the way back in post #27 of this ginormous thread.
I imagine I'm not alone in wanting some more details on your car, lorenkb. Is there a "build thread" somewhere that explains how that came to be? Who did the work? What suspension geometry and drivetrain geometry changes have been made? etc etc...
Patrick Olsen is offline
Old 02-04-2011, 02:34 PM   #4777
Ben98t5
Member#: 268115
2005 WRX Wagon
48W- CGM
if only we had known then what we know now! that is a beautiful piece of fabrication!
Ben98t5 is offline
Old 02-04-2011, 02:39 PM   #4778
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Here's his build thread. I've been following it for a while on dirtyimpreza.
http://dirtyimpreza.com/forums/showt...ont+end+delete
573 is offline
Old 02-04-2011, 06:28 PM   #4779
mowatt 05WRX
Member#: 197510
05 WRX
good stuff
mowatt 05WRX is offline
Old 02-04-2011, 08:19 PM   #4780
lorenkb
Member#: 143051
2007 Bugeye Wagon
Battle Ready
573 nailed it on the build thread:
You can also look at all the photos I took during the process here:
http://www.flickr.com/photos/2508757...7619046842689/
The build came about after a cross-country driving accident. Ice, me asleep in the passenger seat, and a 360 into the I-5 median. Bumper, fenders, hood, frame rails, and apron panels all ended up just a little bent. After driving the car around like that for quite a few months, I decided to have some fun with the repairs, with my friend Kyle Jackson (Jackson Rally) doing the majority of the fab work and my tinkering spread here and there.
Caster has been increased (worked out to just about STi levels if I remember correctly), track was increased 20mm per arm over stock WRX. We did away with the stock LCA mounting points and went to heim joints that mount to a solid subframe. The most significant change was from the stock ball-joint to a spherical bearing in the LCA. In order to bring the geometry back in check we had to modify the hub for a new steering tie-rod placement.
I pretty much let Kyle do what he wanted. He's been building Trophy Trucks for longer than I've been driving, so I figured he would get along just fine. He did and then some...
Just after being put on the car for the first time out of the jig:
Complete and ready for powdercoat:
You can see how we tied the front/rear LCA pivot points together. Wasn't exactly a fan of the stock design that has the front/rear pivot points on two separate structures. For better or worse we also "straightened out" the pivot points. The stock LCA pivot line isn't quite parallel to car centerline, the rear pivot points are splayed out further than the front. We couldn't think of a good reason to keep it that way, so we "fixed" it. Zero anti-lift/dive as well.
We convinced ourselves at the time that a removable subframe was a good idea, so it really is a bolt on affair. In hindsight, it was a giant waste of time and effort, and we should have just welded the whole thing in and been done with it. You can see how the front truss bolts up to the subframe.
As mentioned, I made the bumper easily removable. I had a hell of a time keeping my 07 bumper in one piece and attached to the car. With the added approach angle that we built in to the front end during our repairs, I figured it would be a waste to have the bumper in the way. Four slide latches and some of the stock plastic push-pins are all that hold it on (and I'll be getting rid of those stupid plastic things soon).
The only real issue so far as been the radiator. We went to PWR along with another guy building a custom STi (a much more beefy and thoroughly overbuilt car than mine to be sure) to get a shorter, fatter radiator built. We can't figure out why, but the radiators just aren't lasting. My third one is now leaking, even after we changed to a stock style rubber grommet and pin mount, complete with zinc anode just in case electrolysis was an issue. The SPT intake is the only other sore point. We had to ditch the stock intake because of the new radiator, and the SPT is a disappointment. It excels at ingesting water and providing screwy MAF readings, and that's about it.
lorenkb is offline
Old 02-04-2011, 08:34 PM   #4781
lorenkb
Member#: 143051
2007 Bugeye Wagon
Battle Ready
Found a couple more that weren't in my flickr account:
LCAs being built. Note the pockets for the large spherical bearings, taking the place of the stock ball-joint imbeded in the hub. I think the spherical bearings were more trouble than they're worth...
Everyhting fits nice and snug into a 15" gravel wheel.
OK, I think that about does it. The Flickr account and DI build thread should keep you guys happy.
lorenkb is offline
Old 02-04-2011, 08:47 PM   #4782
Blue_Rex
Member#: 236954
2010 WRX Base
That...uh....takes the cake. Awesome stuff!
Blue_Rex is offline
Old 02-04-2011, 09:53 PM   #4783
bue car
Member#: 176134
1995 Coupe, Sedan &
Wagon!
Loren,
Haha I did not know, thanks! One day I will be like your car.. one day.
bue car is offline
Old 02-04-2011, 11:52 PM   #4784
LGT+WRX
Member#: 91119
05/9 LGT-me/FXT-wife
ABP-me/SSM-wifey
lorenkb - You owe me for medical bills to my neck and jaw. I still haven't been able to pick mine up, from the floor, seeing those posts. Awesome.
LGT+WRX is offline
Old 02-05-2011, 01:44 PM   #4785
93legacySCMSS
Member#: 232760
1993 Legacy SS
^^^^+2
93legacySCMSS is offline
Old 02-05-2011, 05:13 PM   #4786
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
that crazy good!
hybrid gti 2 is offline
Old 02-05-2011, 06:13 PM   #4787
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I did this at sno*drift. Note the missing fog light.
Since that's the third light to die in that location(2 from snow and 1 from a rogue stone) I decided to make block off plates rather than buying more. Other factors that influenced my decision were the big gaping holes in the bumper scooped up massive amounts of snow, and those lights were hardly noticeable with my other lights on.
So... I cut up some aluminum and riveted it in place.
To any of the haters: this isn't my only bumper. I have a nice one that goes on for nice weather.
573 is offline
Old 02-05-2011, 08:19 PM   #4788
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
looks good, maybe some black paint on the aluminum might make it a little cleaner look, but it looks good.
dirtbikeridr12 is offline
Old 02-06-2011, 12:32 AM   #4789
LGT+WRX
Member#: 91119
ABP-me/SSM-wifey
Functional chic (including the Zip-Tie stitching) - I dig it.
LGT+WRX is offline
Old 02-06-2011, 02:43 AM   #4790
Bk6418
Member#: 272183
2011 STI Limited
Dark Grey Metallic
Nice job on the front end.
Bk6418 is offline
Old 02-06-2011, 01:46 PM   #4791
68Cadillac
Member#: 95901
Frankenbumper.
68Cadillac is offline
Old 02-06-2011, 07:23 PM   #4792
maxnn
Member#: 273025
Red
nice !!!
maxnn is offline
Old 02-06-2011, 08:00 PM   #4793
Teh Police
Member#: 246204
My Subaru Forester
is White.
Originally Posted by maxnn View Post
nice !!!
Are you Borat? All of your posts say something about something being "nice".
Teh Police is offline
Old 02-06-2011, 08:33 PM   #4794
SupaHottSauce
Member#: 111725
2018 WRX
Trying to get his post count up
SupaHottSauce is offline
Old 02-06-2011, 08:40 PM   #4795
Teh Police
Member#: 246204
My Subaru Forester
is White.
You're not kidding. Its a new person every week. At least get a decent grasp on the english language before hand.
Old 02-06-2011, 08:47 PM   #4796
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
ThaPuertoRican15 is offline
Old 02-07-2011, 12:13 AM   #4797
The Duke
Member#: 264877
The Duke is offline
Old 02-07-2011, 12:58 AM   #4798
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
This thread is for unique mods, not opinions. Stay on track and quit worrying about what other people do to their cars.
Exactly what i was thinking!
NutWagon is offline
Old 02-07-2011, 01:02 AM   #4799
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Originally Posted by malinwrx View Post
3M di-noc carbon
Im liking this, What is it made of? Dosent look like a cheap sheet bought from Advance Auto.
NutWagon is offline
Old 02-07-2011, 04:36 PM   #4800
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Thanks. I didn't paint it because rattle can will chip and flake off in no time. I could have had it powder coated for free, but I just did this on a weekend where I was home from school and didn't want to waste my time with that. I'm fine with the look of it. It's my rally/winter bumper, so it wasn't on track to win any beauty contests to begin with.
573 is offline
Closed Thread
show us your wings! WRX Potential Member's Car Gallery 30 02-18-2019 11:07 AM
show us your foresters palatine Member's Car Gallery 13 10-26-2003 01:19 AM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 02:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 04:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 08:46 PM
