Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 08-24-2009, 01:43 AM   #1
Matt_az
Member#: 188603
2008 FSXT
Default 105 degree plus days in phx.
The problem is fixed. One of the clips on the engine cover (I know, lame) popped off and got wedged in the driver side fan. This caused the fan fuse to blow. Thanks again for all of your input.
I am a relative newb to subis and wanted to ask some of you guys a question about running temps. I have an 08 FSXT with a vf43, sti tmic, cobb ap2, and a catted downpipe.
On days where the temps approach 105+ and I have been doing standard driving, if I sit in a drive through or in rush hour traffic my temp gauge will get up to the 2/3 to 3/4 range. Once I get going again the temp drops right back to normal.
Would it be advantagous to run a more mild tune on the hotter days?
Matt_az is offline   Reply With Quote
Old 08-24-2009, 01:55 AM   #2
sje323
Member#: 194509
World Rally Blue
you could consider running a meth setup
sje323 is offline   Reply With Quote
Old 08-24-2009, 02:22 AM   #3
ShaggyTR
Member#: 197159
89 SR20 30r Coupe
Aspen White 05 STi
mhmmm meth
ShaggyTR is offline   Reply With Quote
Old 08-24-2009, 02:40 AM   #4
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Have you considered getting a larger aftermarket radiator and external oil cooler?
Those will help cool down the car quite a bit.
Fierysun is offline   Reply With Quote
Old 08-24-2009, 03:01 AM   #5
Evil Imports
Member#: 14732
+ 13 B8
none of my cars get that high when sitting around not moving, something else might be wrong there
Evil Imports is offline   Reply With Quote
Old 08-24-2009, 03:03 AM   #6
Evil Imports
Member#: 14732
+ 13 B8
Did you understand the question??
Old 08-24-2009, 03:08 AM   #7
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
sounds like low on coolant or a busted rad cap, are fans even kicking on? defintitely a problem somewhere
fastnoypi is offline   Reply With Quote
Old 08-24-2009, 03:17 AM   #8
FastS2k
Member#: 59577
04 fxt notansti
s2000 reallynotthatfast
Mine FXT was doing something similar last summer only with the ac on and I have a big Koyo. Turned out to be a fan problem.
FastS2k is offline   Reply With Quote
Old 08-24-2009, 04:15 AM   #9
bObby
Member#: 66959
04 STi and E46
M3
You beat me to it.
bObby is offline   Reply With Quote
Old 08-24-2009, 07:21 AM   #10
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
Definately a cooling issue. Will it drop and rise over and over? If so, you might have a bubble in the cooling system. If it goes away again only when you're moving, I'd look into a fan issue. Do you notice the fans kicking on?
No tune is going to change how cool or hot you car runs when you're sitting around idling.
Old 08-24-2009, 09:27 AM   #11
bigpatskize
Member#: 210691
04 WRX STi
Java Black
105+ give me a break
bigpatskize is offline   Reply With Quote
Old 08-24-2009, 11:58 AM   #12
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
i just remembered the time me and rick were at hooters and he said "i cant wait for my meth kit to come in" loud enough for a bunch of other people that don't know about cars to hear and mean mug us for a while
AWDshenanigans is offline   Reply With Quote
Old 08-24-2009, 11:58 AM   #13
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
has anyone tried that grimmspeed 160 degree thermostat yet?
Old 08-24-2009, 01:17 PM   #14
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
its identical to the Crucial and Gimmick t-stats made by motorad, get whichever is cheaper.
Expect longer warm up times closer around winter.
If you plan on trips up in the snow, it can be a PITA. A stock temp t-stat is sufficient for most situations, failsafe 170* ones can be ordered at Checkers
Old 08-24-2009, 01:18 PM   #15
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
is there a noticable driving difference?
Old 08-24-2009, 01:45 PM   #16
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
not really, only when its not warmed up. during startup, its even less of a noticable difference when using a 5w* oil, than a 10w* oil to get to full operating temperature, just my observations.
Old 08-24-2009, 11:42 PM   #17
Matt_az
Member#: 188603
2008 FSXT
I was doing a visual inspection and noticed that only 1 of the fans was running. Do they start sequentially or should they both be on or off?
Coolant has been checked, it was slightly low but was only able to take about 12oz of coolant. I will probably replace the rad cap this weekend. This has only happened a couple times.
Old 08-25-2009, 12:15 AM   #18
gormonk
Member#: 98960
1978 brat (fo realz)
red
both fans should be on or neither of them will be on. sound like you have a fan problem
gormonk is offline   Reply With Quote
Old 08-25-2009, 12:17 AM   #19
Matt_az
Member#: 188603
2008 FSXT
thanks for all of the advice. i will check out the fans.
Dyno Day in Tucson, Close to Phx, drinks and cheap dyno IA Performance South West Impreza Club Forum -- SWIC 28 11-05-2007 10:18 PM
Anyone in PHX beat a Viper in 1/4? C-grunt South West Impreza Club Forum -- SWIC 59 09-04-2007 05:01 AM
100 degree track day + Semi new FK451 = chunked tires Erexxx Tire & Wheel 34 07-15-2006 02:58 AM
anyone know a good paint shop in PHX? kastle South West Impreza Club Forum -- SWIC 5 12-18-2001 10:56 AM
Anybody a student at UTI in PHX? John2.5RS South West Impreza Club Forum -- SWIC 1 11-05-2001 06:49 PM
