Welcome to the North American Subaru Impreza Owners Club Saturday June 12, 2021
Old 09-16-2009, 01:53 AM   #26
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
Originally Posted by 69subaru360 View Post
I don't doubt you guys. But here is another interesting one. If you look at the EJ20K in this auction, it also has the later style timing cover and they are bolted on for sure. So it at least has the extra small idler pulley that the newer covers are made to clear.
http://cgi.ebay.com/ebaymotors/JDM-SUBARU-IMPREZA-STi-VERSION-5-ENGINE-SWAP-GC8-TURBO_W0QQitemZ290350030541QQcmdZViewItemQQptZMoto rs_Car_Truck_Parts_Accessories?hash=item439a35decd &_trksid=p4506.c0.m245
thats not a EJ20k its an EJ207 sti. and yeah that has a different style timing cover than what comes stock on an EJ20k (at least different than what comes with mine)
here is a real v4 complete set for reference
http://cgi.ebay.com/ebaymotors/Subar...d=p3911.c0.m14
elislider is offline   Reply With Quote
Old 09-16-2009, 05:46 AM   #27
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
That one in the Ebay link isn't even an STI it's probably a normal EJ205 out of a JDM WRX.
Marnix is offline   Reply With Quote
Old 09-16-2009, 11:12 AM   #28
69subaru360
Member#: 159682
1995 WRX
2015 F150
Ok, so one more question. Are the V5 and V6 cam gears and intake manifolds the same as the older engines or the newer ej205 usdm wrx? Thanks for clearing this up. I am going to be working on these engines more in the future as they get cheaper and easier to come by and want to know what fits what.
Old 09-16-2009, 12:07 PM   #29
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The version 5 and most of the version 6 engines have the same cam gears (and camshaft diameter) as the v1-4 engines. Partway through v6 production was when the made the change and I've seen very little firm evidence on exactly how to tell the change without actually removing the covers and gears and looking. Maybe Marnix can shed some light on this.
However, they both use the later style offset bolt pattern on their intake manifolds. You can bolt a v5 or v6 manifold up to a USDM Ej205 engine as an alternative approach to the TGV delete mod so many people do.
Old 09-16-2009, 03:27 PM   #30
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Matt, Version 5 is already Phase II (EJ205 and EJ207) and therefore have the same cam gear as USDM WRX.
Old 09-16-2009, 04:01 PM   #31
elislider
Member#: 133923
03 Legacy GT wagon
true i didnt look much closer than seeing the offset coilpack
Old 09-18-2009, 03:49 AM   #32
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
i happened to have a set of v4 sti ej20k heads and a set of usdm wrx ej205 heads apart at the same time, i took pics of the cam gears and the heads for future reference. hopefully they help...
ej20k heads and cam gears
ej20 k cam gears
ej205 heads and cam gears
ej205 cam gears
and a better pics of an ej20k...
and a pic of the ej20k manifold, you can see the bolt pattern...
route69wrx is offline   Reply With Quote
Old 09-18-2009, 04:11 AM   #33
elislider
Member#: 133923
03 Legacy GT wagon
^^^ nice pics
i was lazy AND didnt have any better camera than my iphone when i tore apart 2 blocks and rebuilt 1, so in my thread about my v3 my pics are few and far between
http://www.rs25.com/forums/showthread.php?t=86202
http://forums.nasioc.com/forums/show...php?p=23507251
Old 09-18-2009, 12:20 PM   #34
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
That manifold looks top notch
Old 09-18-2009, 12:29 PM   #35
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
Thumbs up
thanks, i spent quite a bit of time on it! you should have seen it before i sandblasted it, wrinkle coated it and rewired it....
Old 09-18-2009, 03:09 PM   #36
Matt Monson
Member#: 832
99 2.5RS, '85 911
Sorry, upon re-reading I realized I wasn't very clear about what I was trying to say.
It is my understanding that v5 and early v6 continued to use the earlier camshaft diameter but went to the phase II gear designe and triggers on the gears. Isn't that correct? Aren't there two different camshaft diameters that have been used?
Old 09-18-2009, 04:23 PM   #37
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Version 5 and 6 (MY99 and 00) already used full Phase II heads and cam gear, there is no transition period.
Need pictures of Ej20G and EJ20k THrottle Body bmxpunk Pre-2002 Factory Turbo Powertrain 39 12-17-2012 06:19 AM
JDM EJ20G and EJ20K ECUs Marnix Pre-2002 Factory Turbo Powertrain 3 09-21-2012 10:55 AM
Difference between ej20g, and ej20t? Dokturseuss General Community 0 12-30-2006 11:50 PM
Difference in 04 and 05 Sti in the US? subaru-noob Newbies & FAQs 1 11-07-2004 12:12 AM
Difference in L and RS brakes oldpreza Brakes, Steering & Suspension 9 05-11-2001 08:42 PM
