Welcome to the North American Subaru Impreza Owners Club Tuesday October 17, 2017
Old 12-16-2009, 09:34 PM   #26
betterlead13
Member#: 175101
2002 Impreza WRX
Question: Will this custom installation work with the new 480 Traverse feet? I know it may be too soon, but just curious if this is Tracker foot specific.
betterlead13 is offline   Reply With Quote
Old 12-21-2009, 06:27 PM   #27
payjota
Member#: 219201
Default Rack
I just installed my rack based on this thread. Instead of using 1/4 20 I used 10-32 tap and 10-32 5/8 length bolt. I did not use the plastic feet because the bolt was not long enough. Overall I am happy with the install but the feet can move around a little bit which the tread stated is normal.
I will let you know over time and post any pics if possible.
payjota is offline   Reply With Quote
Old 12-21-2009, 06:33 PM   #28
krazy
Member#: 56400
2004 Subaru STi-SOLD
custom roofrack brackets!
enough to be able to pull this off by hand? I want this thing to be solid. you think it would have been okay if you had a longer bolt?
krazy is offline   Reply With Quote
Old 12-21-2009, 07:49 PM   #29
payjota
Member#: 219201
Default Rack
I think it is the tracker feet that feel that way. The base is pretty solid. One of my taps was not perfect so I will have to keep an eye on it.
Old 12-22-2009, 04:09 PM   #30
jsavage
Member#: 15699
02 wrx
Can you be more specific with "move around a bit"? I don't recall mentioning that movement is normal. I was able to bolt mine tight enough to prevent any movement. You may be able to twist the feet slightly, but because the gutter piece is fairly flexible you should get a really tight hold when fully tightened.
I had one hole that didn't tap perfectly (the tapping operation was fine, but I gummed the threads slightly when trying to thread the bolt in with the feet). It's been holding really well, no issues.
Like I said in my OP, if each corner can handle a solid static test it's going to be able to handle the road test.
jsavage is offline   Reply With Quote
Old 12-22-2009, 04:11 PM   #31
jsavage
Member#: 15699
02 wrx
Yes, the tracker towers will have some "play" in them, that is normal. Base should be pretty solid.
Old 12-22-2009, 04:15 PM   #32
jsavage
Member#: 15699
02 wrx
This concept will work with many different products. Pretty sure the yakima feet work well too when I checked them out.
All you need is a system that can be drilled at a decent or similar diameter without structural issues, allows for access of the bolt head when installed, and mates well to the rain gutter/roof. You'll have to play around with bolt lengths.
I only posted specific equipment because it is what I thought was the best match when rummaging around the local roof rack shop...and I could post specific instructions on how someone could do the install without all the trial and error.
If you find another combination that works, please post the details and install tips.
Old 12-22-2009, 04:40 PM   #33
payjota
Member#: 219201
Yea the feet are secure the gutter piece I guess is what I am referring to. With the tracker kit the square bars move around easily is that the case with yours?
Old 12-22-2009, 04:48 PM   #34
krazy
Member#: 56400
I plan to do this with the yakima landing pads/control towers set up within these next weeks im off. The 08+ WRX/STi uses landing pads #11 which attaches with 1 bolt, so I'm going with that route... OR the landing pads #7 which is meant to drill into the roof and use expanding anchors. I'll keep you all posted.
Old 01-03-2010, 04:58 PM   #35
krazy
Member#: 56400
Hey guys, I did this over my break and here are the facts, findings and results.
jsavage: if you want me to start my own thread i understand, but I just wanted all the info in this one since youre the originator. thanks for the contribution, here's mine regarding the use of yakima gear.
Gear:
- Yakima Landing Pads #11 (2 pairs) <-- these are the same ones the 08+ STi/WRX uses, so they are popular amongst the subie community.
- Yakima Control Towers w/48" bars
Tools:
- 10-32 thread tap
- 10-32 x 1.5" stainless steel socket head screws x4
- Drill + bits
- Center punch
- Measuring tools
Procedure:
1. Remove the rain gutter covers/strips to access the brackets you're going to drill/tap
2. Start with the DRIVER SIDE. The holes in the bracket are the perfect size for the 10-32 taps, so just thread those holes with the tap, slowly and do not force the tap. Use WD40 or cutting fluid to aid in threading. Every quarter turn clockwise, turn counter-clockwise to cut and remove the metal in order to not bung or jam up the tap (it could break if you don't do this).
NOTE:Make sure the tap is perpendicular to the surface, so that the screws don't thread in at a weird angle. You're going to have to eyeball it.
3. On the PASSENGER SIDE, the holes are diagonal to the holes on the DRIVER SIDE, you cant use these existing holes. What I did was I made a tool to measure the distant out from one of the little nubs within the rail.
Here you can see the OE hole and the NEW hole drilled on the PASSENGER SIDE
4. Test fit the screws to make sure they thread in fine
5. Mark the hole locations with tape like how jsavage describes
6. Drill out a good size hole for the screws through the gutter strips
7. Mount the Landing Pads
My control towers arrive Tuesday, so Ill post pics of it complete later. For now, the Landing Pads can sit on the car. They are secure, and look super sleek.
Landing pads cost $35/pair and the control towers cost $160 complete without the bars.
Old 01-03-2010, 05:42 PM   #36
PD5015
Member#: 198372
2006 WRX TR VF43
WRB Camo
great write up OP, bugeye looks awesome
PD5015 is offline   Reply With Quote
Old 01-03-2010, 05:50 PM   #37
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
I want to do this so bad... honestly just for looks... but I could see it coming in handy once in a while...
RoxyTheImpreza is offline   Reply With Quote
Old 01-05-2010, 05:58 PM   #38
payjota
Member#: 219201
The feet are really big compared to the thule trackers. Mine don't go past the channel .
I like what you did to drill more holes to line the rack up. I noticed that after I completed the job. I think I am going to fix that at some point because my fairing sits a little off on one side.
Old 01-06-2010, 02:47 AM   #39
Dragicon
Member#: 112323
What is the height from the roof to the bottom of the front bar? I am curious how much lower this is than the current thule feet I have.
Dragicon is offline   Reply With Quote
Old 01-12-2010, 01:31 PM   #40
mjcnv1p
Member#: 213930
2002 02wrx
Default Great Write up!
Ive been searching for a nice rack myself, and I think I might try this install.
mjcnv1p is offline   Reply With Quote
Old 01-12-2010, 01:40 PM   #41
payjota
Member#: 219201
Don't try make it happen. It is not that hard.
Old 01-12-2010, 03:22 PM   #42
mjcnv1p
Member#: 213930
2002 02wrx
Will do...Cheers!
Old 01-15-2010, 05:44 PM   #43
jsavage
Member#: 15699
02 wrx
KRAZY - The more info on here the better....I was hoping someone would post a Yakima version.
Look forward to final pics
Old 01-17-2010, 11:08 PM   #44
krazy
Member#: 56400
jsavage: that's what I hoped for too. here are the final pics!
FINAL PICS OF RACK!:
Old 01-19-2010, 02:48 PM   #45
jsavage
Member#: 15699
02 wrx
Looks great. Yakima towers look a bit higher and beefier than the thule, but looks SOLID.
Are those dents below the towers from a previous rack? (Just need to clarify)
Old 01-19-2010, 03:47 PM   #46
krazy
Member#: 56400
I had a Yakima set up with the q-towers like your previous mod. Some scum decided to take a prybar to my towers and pry them off, yanking my ENTIRE set up, leaving me with the modified q-clips. it was a sad day. on the bright side, i have a completely SECURE set up now. and I dont think this could be pried off as easily.
So yea, those are dents, but not from any rack per se.
Old 01-19-2010, 08:20 PM   #47
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
looks good. Happy that Subaru pretty much did it this way from the factory on the 08+ cars.....
irish44j is offline   Reply With Quote
Old 01-19-2010, 08:21 PM   #48
irish44j
Member#: 191290
09 OPB SM WRXsedan
on a side note....Thule towers tend to be a bit lower than Yaki towers (I've sold both for many years) for most applications, if "keeping it low" is a concern.
Old 01-19-2010, 09:08 PM   #49
IH8PVMNT
Member#: 178254
2006 Wrx Limited BUG
2006 Wrx Limited Wagon
how do you think this setup will hold down 2 bike carriers and 2- 45lbs mountain bikes ??
IH8PVMNT is offline   Reply With Quote
Old 01-19-2010, 09:15 PM   #50
krazy
Member#: 56400
i put money on it that the yakima set up will hold BETTER than the q-tower/q-clip method.
100lbs of gear is nothing.
Custom roof racks Lynne Forester Forum 0 10-07-2009 10:23 PM
Question for those of you who have the Custom roof rack dangk Interior & Exterior Modification 20 01-31-2009 02:30 AM
Questionou for those of you with custom roof racks dangk Southern California Impreza Club Forum -- SCIC 0 01-30-2009 02:37 AM
Yakima Sedan Custom Roof Racks For Sale! (Really this time) jsavage SCIC Private Classifieds 6 12-28-2006 12:57 PM
roof rack install in san fernando MPREZD Southern California Impreza Club Forum -- SCIC 16 03-30-2006 09:02 PM
