Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 09-26-2009, 12:33 PM   #1
aikido
Member#: 73554
2006 WRX Wagon Stg 2
Default 2006 wrx spark plug replacement?
My local shop doing a tune-up on mine - said they have to move (jack up slightly I think) the engine just to change the plugs??? Anyone?
aikido is offline   Reply With Quote
Old 09-26-2009, 12:54 PM   #2
02MillzRex
Member#: 206359
2005 WRX
CGM
Sounds weird to me but im no expert i have changed plugs about half dozen times in my current wrx and my last and never once jacked it up at all.
02MillzRex is offline   Reply With Quote
Old 09-26-2009, 01:40 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
15ft-lbs torque
Old 09-26-2009, 03:05 PM   #4
bzbuzz
Member#: 116052
2011 STI ( Sold )
NO need to lift up the engine at all.
bzbuzz is offline   Reply With Quote
Old 09-28-2009, 01:55 AM   #5
hai8616
Member#: 224495
Default Replace spark plugs for 06 wrx
I just change my one last week , do the driver side first , remove the battery , and air pump , take the top cover of the fuse box
The passenger side is easy : remove the air filter box and you will see every thing.
hai8616 is offline   Reply With Quote
Old 09-28-2009, 01:57 AM   #6
jody88
Member#: 207555
Psm
i did mine a couple months back, didnt have to move anything but the washer fluid resevoir. just used a flex head ratchet and it took about 45mins start to finish
jody88 is offline   Reply With Quote
Old 09-28-2009, 03:17 PM   #7
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
for an 06 just remove battery on driver side, air box on passenger side. no need to jack motor up. there's enough room to get the coil out and then the plug out. definitely want to get a rachet that allows you to angle the head. NGK plugs = don't use antiseize.
Tahoe SC is offline   Reply With Quote
Old 10-13-2010, 10:34 AM   #8
Waynuts
Member#: 229176
I replaced mine recently after checking out the info on nasioc, and figured a video might help. I'm happy to help out other newbies, especially since the dealership wanted $338 to replace my plugs. Also included are the cabin and engine filter locations, and how to take off the bumper to replace headlight bulbs.
Waynuts is offline   Reply With Quote
Old 10-13-2010, 05:17 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by Waynuts View Post
YouTube - 2006 wrx bumper, spark plug tutorial
take off the bumper to change headlight bulbs
YOU are totally outa your ****ing mind
waynuts is right...yer nuts alright
Old 10-14-2010, 09:03 AM   #10
SteveDoten
Member#: 260673
2002 WRX, 2003 Z06
ever notice the coil pack plugs are the same? it's kind of obvious due to the length where they go
fwd plug is white??
just something you may want to note prior to removal
SteveDoten is offline   Reply With Quote
Old 10-14-2010, 03:17 PM   #11
JohnM10
Member#: 244231
2018 Crosstrek CVT
Is this a joke? You need to take off the bumper to replace some of the bulbs in the headlight assembly
John
JohnM10 is offline   Reply With Quote
Old 10-14-2010, 04:47 PM   #12
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
IIRC, there are some models you have to remove the bumper to do.
blackfang is offline   Reply With Quote
Old 10-14-2010, 04:55 PM   #13
elokos
Member#: 260778
2004 WRX
sorry but I have to have 3 posts untill I can ask a question, this is #2
elokos is offline   Reply With Quote
Old 10-14-2010, 04:56 PM   #14
elokos
Member#: 260778
2004 WRX
and number 3
Old 10-14-2010, 10:29 PM   #15
JohnM10
Member#: 244231
2018 Crosstrek CVT
I have a 2006 2.5i and I have changed the main headlight beams. Does this model require the bumper to be removed to changed some of the bulbs? If so that is in my opinion a very poor design!
John
Old 10-15-2010, 12:09 PM   #16
rkramer
Member#: 118209
2015 WRX Limitec
John
no, you do NOT have to remove the bumper... EVER. Yes, that might be ONE way of doing it, the very, very hard way... Kind of like changing your oil by pulling the engine, putting it on a hoist, and tipping it upside down so the oil comes out the dipstick tube. (actually now that I think about it, you can't change your headlight by removing the bumper, as far as I know those two pieces are not connected in any way on ANY year subaru)
Old 10-15-2010, 01:25 PM   #17
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
The engine does not and should not be jacked-up to remove the spark-plugs.
The driver's side rear coil-module needs to be rotated 180* to be removed (after the connector is disconnected and the bolt is fully loosened).
Respectfully, the shop you are considering going to doesn't know what they are doing.
As for removing the front bumper on a 2006/2007 to change the front bulbs = NO and I don't think so.
The turn-signal and side-marker bulbs are accessed through the fender by unclipping and pulling back the fender-liner and on the passenger's side by removing the air-baffle box.
2006 WRX spark plug question gunmetalgolfer Service & Maintenance 11 07-19-2009 01:22 PM
2006 WRX Spark Plug Question RUKnight Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-27-2007 09:35 PM
2006+ WRX spark plug part no ray101381 Service & Maintenance 5 03-19-2007 12:52 PM
2006 WRX Spark Plug question az03wrx Newbies & FAQs 3 10-05-2006 08:01 PM
WRX Spark plug replacement. jnmarshall Texas Impreza Club Forum -- TXIC 6 10-17-2005 12:44 PM
