10-06-2009, 05:16 PM | #1 |
Member#: 208220
Vehicle:2006 STi |
What engine oil to use in high HP engines
Just wanting to know what some of you guys are using in your built engines
During run in & after run in. Are you using Mineral Fully synthetic Semi synthetic Ive been told never use fully sythetic in any Subaru engine
10-06-2009, 05:31 PM | #2 |
Member#: 98199
NESIC
Vehicle:2007 Impreza WRX STi CGM Cosworth GT4094r |
In the manual to my cosworth motor, it says to use Mobil 1 Synthetic 15w-50. I'd trust their advice.
10-06-2009, 06:23 PM | #3 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Most people use synthetic, the weight depends on your bearing clearances, weather, and driving style.
10-06-2009, 07:37 PM | #4 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
I always ran Rotella 15w40. Tried rotella synthetic 5w40 when it was really cold out.
10-06-2009, 07:44 PM | #5 |
Member#: 179783
W. Canada
Vehicle:2002 WRX Silver STi swap 380wph!! |
Yeah ron at Raw 1 recommended Rottella 15w40 which comes in mineral, blend and full syn. FYI this is diesel engine oil with special detergents for the diesel soot... maybe ron recommends this because of all the blow by we have, just a thought.
10-06-2009, 08:30 PM | #6 |
Member#: 87653
South East
Vehicle:97 Supra / 17 GTR 16 Z06 / 07 STI / 05 Evo |
I use whatever I can find that is cheap. 10w40
10-06-2009, 09:10 PM | #7 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
I have and always will use amsoil (after breakin) on all my high hp applications.Used it for years in my 7 sec. suzuki topgas bike and now use it in my built sti and all my clients motor builds and swear by it.
10-06-2009, 09:33 PM | #8 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
$1.99 20w50 currently.
10-06-2009, 11:00 PM | #9 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
10-07-2009, 01:39 AM | #10 |
Member#: 197147
TXIC
Vehicle:2004 Subaru Forester Java Black Pearl |
THE ONLY OILS YOU USE HAVE TO BE SAE-SL RATED....
If not, foghettaboutit.... Cheapest SAE-SL oils: AUTOZONE brand orange bottle 10w40 PEAK brand 10w40 Chevron DELO 400 (diesel oil in gallon jugs only usually-- (NOT THE LOW EMISSION VERSION labeled DELO 400 LE) Rotella T IF YOU FIND IT IN the SAE-SL rated version of the oil.... do not use the SM version.... Expensive but good oils: Amsoil Royal Purple Joe Gibbs Racing Mineral and Synthetics (more ZDDP than any other oil) Rotella T 5w40 SAE- SL rated only (not all of it that you find is SAE-SL, some is SM) I don't care for blended oils, and the above oils are what I recommend usually... I also don't recommend any oils lighter grade than 10w40 for built engines... which usually run more clearance than stock engines, therefore, they require a thicker viscosity oil.... The JOE GIBBS RACING oils are absolutely the best oils I have ever seen or used in built engines.... They are the nastiest smelling and stickiest-slickest oils, whether using the synthetic or mineral oils... I use the Rotella 5w40 FULL SYNTHETIC in my stock engine with 157,000 miles on it, and it works great..... again, it comes back to clearances and ambient air operating temperature along with the average oil temperature operating ranges |
10-07-2009, 10:22 AM | #11 |
Member#: 146056
Vehicle:2004 Subaru WRX STI Blue |
Using RP 10w40 with no issues.
10-07-2009, 10:35 AM | #12 |
Member#: 183674
Vehicle:2009 BMW 335i LeMans Blue |
Rotella T 15w40 seems to be the best oil for me.
What Grade engine Oil to use | Carl Wrx | Newbies & FAQs | 45 | 07-22-2008 12:25 AM |
What weight oil to use in 97-98 2.5liter? | 2slofouru | Service & Maintenance | 3 | 11-22-2005 11:37 AM |
What type of oil to use on high mileage car? | txl146 | Service & Maintenance | 5 | 02-04-2005 11:01 AM |
What oil to use in tranny and diff (Redline)? | WRBLUEWAGON | Transmission (AT/MT) & Driveline | 1 | 06-20-2002 10:58 AM |
What brand of oil to use in RS? | Vigorous | Newbies & FAQs | 3 | 12-08-2001 04:03 AM |
