Welcome to the North American Subaru Impreza Owners Club Saturday November 25, 2017
Old 10-12-2009, 05:40 PM   #1
clockworx05
Member#: 226619
2009 Impreza WRX
Grey
Default My AUX not working?
I just bought a 09 WRX and when i plug in the AUX i get nothing... Any Ideas?
When I Plug in, and press AUX it does nothing.
clockworx05 is offline   Reply With Quote
Old 10-12-2009, 05:47 PM   #2
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
yeah... brand new... dealership! Get your money's worth....
couchflambeau is offline   Reply With Quote
Old 10-12-2009, 05:49 PM   #3
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
After you plug your aux device into the car's aux jack and you press the AUX button on the radio, does the radio's display show that it has switched to the aux input?
Do you have another cable you can try? Are your sure your aux device is outputting sound?
It's not uncommon for the aux jacks to fail (usually when someone bends the plug sideways in the jack too hard). If you're sure your MP3 player and cable are working, have your dealer fix it (should still be under warranty).
SVXdc is offline   Reply With Quote
Old 10-12-2009, 05:55 PM   #4
clockworx05
Member#: 226619
2009 Impreza WRX
Grey
Let me ask this, is there a difference between an audio cable and auxiliary cable?
It says "CD/AUX", but when i press it, nothing happens.
Old 10-12-2009, 05:58 PM   #5
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Not really. Both names can be ambiguous. In this case, you're looking for a cable that has a 3.5mm (or 1/8" diameter) stereo plug at one end (to fit the car's aux jack) and the appropriate connector at the other end to fit your aux device (usually another 3.5mm plug for most MP3 players).
Old 10-12-2009, 06:00 PM   #6
clockworx05
Member#: 226619
2009 Impreza WRX
Grey
Here's the kicker, ready?
It has IPOD hookup in the center console too, would that disable the AUX?
Old 10-12-2009, 06:00 PM   #7
clockworx05
Member#: 226619
2009 Impreza WRX
Grey
I dont have an IPOD or else I would do that, lol.
Old 10-12-2009, 07:23 PM   #8
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
That means either the aux jack is broken, or the interconnect harness underneath is disconnected (or has a damaged wire).
Normally, when you plug a 3.5mm plug into the aux jack, a little switch senses the plug and tells the radio to enable the aux button. Then when you press the CD/AUX button, the display should show "Aux".
With nothing plugged into the aux jack, the CD/AUX button will only switch to CD mode.
No. There's an iPod interface module that plugs into a different port on the back of the radio. So the aux input (3.5mm jack) should still work.
Old 07-17-2010, 05:15 AM   #9
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Did you ever resolve this?
I just installed a 2007 STi HU (C-124) with AUX and nothing happens when the iPod is connected I press CD/AUX. The iPod and auxiliary cable is functioning properly since it plays in my dad's 09 Outback.
eurospek is offline   Reply With Quote
Old 07-24-2010, 10:12 PM   #10
txsubie23
Member#: 252981
2007 wrx
wrb
having the same issue here on my 07... might take it to the stealership since it's under warranty
txsubie23 is offline   Reply With Quote
Old 07-25-2010, 01:22 AM   #11
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
I resolved my problem. Pop open the AUX box. The harness inside (the wire exiting the box) wasn't even plugged in. Probably when the seller was taking it out, he pulled too hard. All is well now and I love this HU. One of my best mods yet.
Old 07-31-2010, 11:37 PM   #12
txsubie23
Member#: 252981
2007 wrx
wrb
i pulled my shift boot off and looked in behind there...it's missing the section of the harness that goes from the HU to the aux input...
apparently they had an aftermarket HU installed bc there are two other dead end plugs back in there
Old 08-01-2010, 04:27 AM   #13
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
See this for the aux interconnect harness your 2007 originally had,
and see this for how to order a replacement (if that's the piece missing, and nothing else was hacked up).
What do the dead-end plugs look like?
3200DVD aux audio input not working NCORWRX Car Audio, Video & Security 4 05-04-2010 10:16 PM
Is my Avcs not working properly ? Sammidavis Engine Management & Tuning 6 06-26-2009 11:31 AM
Why is my Javascript not working in Mozilla? perret318 Off-Topic 5 03-02-2004 03:23 PM
('93-'01) why is my signiture not working?? Rubasu Impreza Forum 1 07-27-2001 08:07 AM
OT: Some pictures of what I work on when I am not working on my RS. paultg New England Impreza Club Forum -- NESIC 15 07-06-2001 06:48 AM
