Old 10-18-2009, 10:16 PM   #1
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
Default Standing Mile: 2.5L + GT40R goes 189.092mph
Event: Texas Mile
Ambient Temp: 76 degrees Fahrenheit
Elevation: ~ 164 feet above sea level
Weather: clear and sunny, humidity 46%, headwind of 8mph
Track and Conditions: Concrete/air strip, fairly smooth
Tires: Hankook Ventus 225x45x18
Car: 2004 STi
Tuner: Brad at EngineLogics
Dyno Info: Dynodynamics
Peak HP at RPM: 571 at ~7K RPM, uncorrected, approximately 85' above sea level
Peak Torque at RPM: 504 at ~5.7K RPM uncorrected
Baseline hp/tq for a stock on same dyno: 225hp, 220TQ for 2.5L STi
Target Boost: 28psi
Target AFR: ~11.8
Fuel: VP C16 117 Octane
Engine/Power Modifications:
EngineLogics Engine / Heads
EngineLogics Fuel Rails
Kelford 272/272 non-AVCS Cams
75lb springs / 1mm oversized valves
1600cc injectors
Aeromotive FPR
Fuel Lab 105gph exterior fuel pump and EngineLogics Surge Tank
-10 fuel line from surge tank to the fuel rails
Perrin FMIC
Full Race 4088R 1.06a/r Twin Scroll
Ford 4.6L Mustang DBC throttle body
JDM Spec C Intake Manifold
Link G3+ Engine Management
Aluminum Racing Radiator
C&R 30lb Radiator Cap
Driveline Modifications:
Carbonetics Twin Disk Clutch
Carbon Fiber Propeller Shaft
Stock 6 Speed Transmission
Cusco 1.5 Way Rear Diff
Perrin Rear Diff Cover Plate
DSS Rear Half Axles
Cusco 1.5 Way Rear Differential
Kartboy Short Shifter
Suspension Modifications:
TiC / AST Coilovers (two clicks from full soft)
Whiteline Max C Camber Plates (-2 degree in front, -1 degree in rear)
Cusco Front Swaybar
Poltec Front Endlinks
Perrin Rear Swaybar
Perrin Rear Endlinks
DBA Two Piece Drilled / Slotted Front Rotors
DBA Drilled / Slotted Rear Rotors
EBC Yellow Stuff Pads
Goodridge SS Brake Lines
Other Modifications:
Kirk Racing 4 Point Roll Bar
Home made aluminum front air dam
Carbon Fiber Rear Diffuser
Speed Tape
Wipers and Mirrors removed
Wingless trunk lid
Beatrush Front Underpanel
Short and sweet, '04 STi ran 189.092 mph at the Texas Mile, a new Texas Mile mark for Subaru. Another run at the Texas Mile this weekend and the car exceeded my expectations once again. Hats off to Chris and Brad at EngineLogics for their fine work under a very, very tight schedule; they did excellent work as usual and provided a safe tune that did what we wanted. Big thanks to Full Race for pulling the kit together on short notice - fitment was excellent and it performed very well, and still has more room. A little background on the car and history at the Texas Mile:
March 2007 - 156 mph
stock engine / Perrin 35R/Perrin FMIC/225x45x17 tires/93 Octane / 24psi
October 2007 - 170 mph
stock engine / Perrin 35R/Perrin FMIC/225x45x17 tires/112 Octane Race Gas/rear diffuser/28psi
March 2008 - 169 mph / wingless and same set up as October 2007 Mile
March 2009 - 182 mph / wingless / EngineLogics Engine / Perrin 35R / C16 /27psi/
Changes for the October 2009 Mile:
Full Race GT4088R with 1.06a/r (wrapped header and UP)
-10 Fuel Line from the surge
2.5Qrt Surge Tank (mounted behind the drivers fog cover)
Fuel Lab 105gph fuel pump
Hankook 225x45x18 tires
Modified passenger fog cover with coolant duct to turbo
Dyno Charts
My Perrin 35R vs the 40R:
In Car Video:
Car Photos:
beaviscih is offline   Reply With Quote
Old 10-18-2009, 10:17 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
sweet
Old 10-18-2009, 10:33 PM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Impressive stuff! Looked very uneventful..Very stable... At first,I was curious as to why I could not hear the usual siren sound that comes at speed..I then realized that the mirrors had been pulled.
I wonder though... would it have been legal to have aero mods such as the wheel covers on this car?
jigga is offline   Reply With Quote
Old 10-18-2009, 10:33 PM   #4
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
awesome mph...glad to see you joined the 4088 club!!!
off to watch your vid
blowbyu24 is offline   Reply With Quote
Old 10-18-2009, 10:39 PM   #5
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
No wheel covers allowed, but I wish they were because the wheel spokes do add drag.
The car was stable after I changed the suspension from firm to soft and dropped the air pressure from 45lbs to 38lbs. One of the other STi owners called the US AST distributor and they told us to turn them to soft so the springs would load properly. Friday's runs were a little scary...nasty cross wind that made the car float at about the 1/2 mile mark and when you hit the brakes. Needless to say after a few trips down the track under those conditions I shut it down for the day.
Old 10-18-2009, 10:46 PM   #6
evan_impreza
Member#: 115276
98 v9 RSTI
207 + rotated 30r
Awesome! Congrats!
evan_impreza is offline   Reply With Quote
Old 10-18-2009, 10:50 PM   #7
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
Thanks...I followed your advice and went with the 40R vs. the 42. While it doesn't doesn't help much to launch the car I used the launch control to help warm up the clutch after this run on Saturday...
Clutch slipped at peak torque. The rev limiter is set at 8k. Gear shift by RPM for the 189 run were as follows:
2nd/3rd - 7200
4th/5th/6th - 7800
Old 10-18-2009, 10:56 PM   #8
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
yeah you can hear that...well glad to hear the LC help fix the problem
did you notice much difference from 225/17 to 225/18?? pertaining to gearing length and mph?? i was thinking about going with a taller tire as well since our gearing lacks for top end runs
Old 10-18-2009, 11:00 PM   #9
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
Its hard to measure, but I felt it couldn't hurt. I was pretty much stuck with the 18's if I wanted to run the front air dam...it would have rubbed with the 17's when I hit the brakes.
Old 10-18-2009, 11:00 PM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Ah gotcha...
Any video footage of those runs with the crosswind??
I must admit,there is something surreal to me about a Subaru clocking 190mph! I wonder what the speedometer needle looked like
Old 10-18-2009, 11:04 PM   #11
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
Ah gotcha...
I'll check the tapes. I video'd every run so I should have them. You can see the car bunny hop down the track, it literally moved several feet and I had really pay attention, so I did look at much other than my RPMs. I use a HUD that I glance at when I hit the 1/2 mile mark to gauge where I am, the OEM speedo is buried, but we datalogged a 184 run and the laser speed traps were dead on.
There were several spinouts this weekend and this morning a beautiful '56 P/U rolled several times after he lost it right around the 1/2 mile mark ...http://www.dallasclassicchevy.com/Fe...r0810Raley.htm. This picture was taken by another NASIOC member (RallyGuy2K)...
Old 10-18-2009, 11:07 PM   #12
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
i guess every little bit helps
Old 10-18-2009, 11:11 PM   #13
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
the launch sucked!!! but the power and after was so bad ass... raise the 2 step and you'll be out brother
bmxhotsauce is offline   Reply With Quote
Old 10-18-2009, 11:16 PM   #14
CGM6
Member#: 146911
awesome work, congrats!
CGM6 is offline   Reply With Quote
Old 10-18-2009, 11:20 PM   #15
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
It isn't a drag race so trust me when I say that there is no need to hard launch the car. The only reason I used the launch control was to heat up the clutch.
Old 10-18-2009, 11:38 PM   #16
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
Ah gotcha...
IIRC this was a 182 run...a little loose after 1/2 mile.
Old 10-19-2009, 12:38 AM   #17
swiftwrx1
Member#: 72352
06 E85 v-mount
wht/bronzse WFC#555
very nice!
swiftwrx1 is offline   Reply With Quote
Old 10-19-2009, 02:12 AM   #18
02wrxdude
Member#: 182160
1992 MR2 N/A
Forest Green
severely impressed, wow, 190mph
02wrxdude is offline   Reply With Quote
Old 10-19-2009, 06:41 AM   #19
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
189.092... there is a big difference between that and 190.
Old 10-19-2009, 06:57 AM   #20
jamal
Member#: 71875
wow that's fast.
I wonder how much narrower, higher offset wheels, blocking off your bumper air inlet, and more lowering would gain. Also, can you flat-bottom the car?
jamal is offline   Reply With Quote
Old 10-19-2009, 09:05 AM   #21
rxw
Member#: 43669
2006 STi
Interested in the Full-Race 40r kit.... got a dyno graph?
rxw is offline   Reply With Quote
Old 10-19-2009, 10:24 AM   #22
H.K. Phooey
NASIOC T-Shirt Crew
Member#: 35509
2010 SuperChargedJag
Pewter
Well done Bill, I started a thread in the motorsports section.
whoops...
H.K. Phooey is offline   Reply With Quote
Old 10-19-2009, 10:59 AM   #23
toneekay
Member#: 185126
2005 STI
AWDtuning feels like sex!
189 in a standing mile; VERY impressive Beavis! :P
toneekay is offline   Reply With Quote
Old 10-19-2009, 11:27 AM   #24
beaviscih
Member#: 123362
'97 E36 M3 351W
FTW
I do and will add them to the first post tonight.
Old 10-19-2009, 11:34 AM   #25
bgod
Member#: 100274
Simply awesome. I've done a closed course run on the salt flats with a small group and would love to do this one day.
But it's seriously scarey how unstable these cars can feel at speed.
Any ideas of maybe how to keep it more planted? Any more aero upgrades in the future?
bgod is offline   Reply With Quote
Quarter Mile: 2.5L + Cobb stage 2 First trip to strip...FAIL FloridaGatorsJWett Proven Power Bragging 107 01-28-2011 02:48 PM
Quarter Mile: 2.0L + 18g goes 12.7sec @ 105mph BONFIRE074 Proven Power Bragging 23 06-07-2010 05:03 PM
Standing Mile: 2.5L+GT4088R Goes 191.1mph beaviscih Proven Power Bragging 30 05-09-2010 08:29 PM
Quarter Mile: 2.5L + Cobb stage 2 13.4 @ 102.66mph subadupa Proven Power Bragging 44 03-28-2010 02:47 PM
Quarter mile: 2.5L + gt35r goes 11.45 @ 120 on wastegate boost! with video jays05 Proven Power Bragging 68 03-22-2010 09:06 AM
