Welcome to the North American Subaru Impreza Owners Club Saturday September 22, 2018
Old 10-20-2009, 01:05 PM   #1
IIdiceII
Member#: 90438
Default removing or releasing pin from engine harness connector
I have to repair two wires coming off of one of the two big main harness connectors next to the battery.
car is a 2002 wrx 5mt. I know you can take the pins out but i cant figure out how
two wires on the big black square plug behind the battery are in need of repair.
I took the big white locking thing off the front but cant get the damn pin out. heres a pic of the two wires im talking about.
I know you can get a specific tool for this application but i dont know what tool I would need.
the connector is the female side of the plug which goes to the bulk head harness.
IIdiceII is offline   Reply With Quote
Old 10-20-2009, 03:46 PM   #2
IIdiceII
Member#: 90438
bump ttt
Old 10-20-2009, 04:26 PM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You would need a pin extraction tool of some sort like this, I would say.. http://www.xpcgear.com/molexextract.html
But that is just a best guess, those are sealed connections so I don't know the exact mechanics of the pins..
Old 10-20-2009, 06:40 PM   #4
AlexTRD
Member#: 135627
2005 WRX td06-20g
ej207/02 wrx/s4/C32 AMG
After you take out the white thingy theres still little black tabs locking the pins in. I used a really small allan wrench to pop off the locking tabs, even then you need to pry on the back of the wire moderately hard to pull them out.
AlexTRD is offline   Reply With Quote
Old 10-20-2009, 07:02 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
jewlers screwdrivers are usually a good bet on things like this if the proper tool isnt available
Old 10-20-2009, 07:21 PM   #6
JVD
Member#: 213130
Ya usually just a jewelers screwdriver.
Probably has a little release on the pin side of the plug. Each pin should have it's own separate one. They usually suck to do, but you'll get it.
JVD is offline   Reply With Quote
Old 10-20-2009, 07:51 PM   #7
IIdiceII
Member#: 90438
I tried all the tools i have. tiny tiny tiny ass screwdrivers, bent bobby pins, sewing needles
I cant get the locking tab to release.
and subaru has about 5 or 6 terminal release tools that you can buy. theyre like 30 bucks each and im not sure which one i need.
aaahhhh!
Old 10-20-2009, 08:58 PM   #8
AlexTRD
Member#: 135627
2005 WRX td06-20g
Like I said I got away with doing this with a really small allan wrench, you dont need the specialty tools. Try prying the locking tab and pulling the wire out at the same time. Even after i released the tabs I had to yank the wires out pretty damn hard. You gotta repair the wires anyways, so don't be afraid to show them who's boss.
Old 10-20-2009, 09:03 PM   #9
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
Geeze, jewelers screwdriver? Just use a T Pin. I use a pick, but the set cost me $35 off the Snapon truck.
You have to disengage the lock on the pin itself, and then it will slide out (if there's crap in there, YANK it out and hope to god the wire doesn't break). You should be able to cut the wire and fix it with a new pin then.
Chi_San is offline   Reply With Quote
Old 10-20-2009, 11:44 PM   #10
IIdiceII
Member#: 90438
Id like to save the pin so i can just pull the wire out, throw some solder and tape it up.
i was just hoping there was a secret special trick i didnt know about!
Old 10-25-2009, 12:10 AM   #11
IIdiceII
Member#: 90438
motha ****a...finally got it out.
anyways. im hoping nasioc comes through on this one.
I want to replace the section of wire on those two exposed wires as well as the terminal.
you can buy replacement terminals with pigtails here...
http://subaru.spx.com/DisplayByCateg...px?id=5&page=8
problem is, I have no clue which one i need.
it could be any one of the RK-TFA- tool numbers.
if anyone knows. PLEASE TELL ME!
Old 10-25-2009, 12:59 AM   #12
Chi_San
Member#: 53558
2005 Baja Turbo
Take it to a dealership. That's about the only thing I can even think of suggesting.
Old 10-25-2009, 02:40 AM   #13
IIdiceII
Member#: 90438
take my car? it wont drive with those pins out. one is for the throttle position sensor. i can barely even rev the car with it disconnected.
im hoping someone has done a swap and has replaced one of these pins lol.
otherwise im gonna have to go to a junkyard or something and cut off a connector.
Old 10-25-2009, 10:46 AM   #14
Chi_San
Member#: 53558
2005 Baja Turbo
I meant the pin. Get a ride from a friend or something.
Old 10-25-2009, 11:58 AM   #15
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
What does the pin look like???
Typically these connections are grouped under "molex" connectors.. Check DigiKey or Newark electronics for all sorts of pins... watch the specs..
Old 10-25-2009, 01:54 PM   #16
IIdiceII
Member#: 90438
the pin looks like every other damn pin
I had it next to a pins from the crank sensor plug, knock sensor plug, bcs plug. and its different. its smaller. the dealers around here are retarded and would never know what i was talking about. if you dont have a part number for em, theyre lost.
Old 10-25-2009, 02:15 PM   #17
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
Your local dealer should have a "Subaru Terminal Repair Kit" which comes with all of those different terminal sizes in there. If you take it in and talk to someone at least semi-competent they can match it up with whats in the kit, if theyre nice they might even give you the one you need since they get like 30 of each one.
carnz-pj-410 is offline   Reply With Quote
Old 10-25-2009, 03:57 PM   #18
IIdiceII
Member#: 90438
yea ill give that a try. thanks for the help
Old 08-13-2013, 02:47 PM   #19
fullCircling
Member#: 290547
here is a subaru .pdf that has pics of the part numbers for the terminals, as well as the tools.
http://techinfo.subaru.com/proxy/607...4760668812.pdf
fullCircling is offline   Reply With Quote
Old 10-27-2013, 04:59 PM   #20
Profoxcg
Member#: 169036
2015 STI
Does anyone know which tool for this connector?
Profoxcg is offline   Reply With Quote
Loud Tapping or Clicking Noise From Engine! Ekeenan86 Normally Aspirated Powertrain 9 08-18-2013 04:14 PM
How do I remove the Torque converter from engine? reddevil Transmission (AT/MT) & Driveline 2 07-07-2011 06:46 PM
Help!! Engine forward Clutch Swap -Remove fork release pin?? monkfish Transmission (AT/MT) & Driveline 9 02-20-2010 09:17 PM
04 impreza engine harness connectors rst4me Engine/Power/Exhaust 0 02-19-2007 10:09 PM
ECU pins and engine harness pins??? MK19_ Electrical & Lighting 3 04-21-2005 07:10 PM
