Welcome to the North American Subaru Impreza Owners Club Friday December 15, 2017
Old 11-18-2009, 02:11 AM   #1
Mecka20000
Member#: 176162
MY02 Jesus Once Told
Me, "Numbers Sell"......
Cool 02 WRX w/ATP GT35R Cosworth 2.2L Stroked v7 EJ207
Full JDM V7 Sti Motor Code: EJ207DW4CR MY02 Built w/ Cosworth 2.2L Stroke kit +.50 Bore, Iron Sleeved Short Block, Hot tanked block and head. Kit included C/R 8.5:1 (Piston Part #20003687) 92.5mm pistons, 23mm Piston Pin & Circle clips (Rings part#20003607) Cosworth High Performance Piston rings set w/ 79mm High balanced New STi Forged Crank & Forged Con H-Beam Rods (Rod Part #20002587),Cosworth Ultra High Performance Tri Metal Size 1 Main & Rod Bearings.
-JDM V7 Heads Rebuilt and refreshed with supertech light valves +1mm over intake/exhaust. New titanium retainers and dual valve springs with supertech valve guide seals. 5angle port. Coated.
V7 Spec C ECU w/Functioning AVCS Open source tune @ Cobb SoCal E85 tune.
Redline set from the stock 8250 to 8500 Fuel cut
Cosworth 1.1mm Metal Head gasket
Cosworth timing Built Guide
ARP Head Studs
ATP GT35R Tial 44mm w/ 1.4 bar springs EWG with custom dump pipe to atmosphere
KartBoy Light Crank pulley
2008 Sti High flow oil pump
83mm HB Speed Custom Big MAF intake
Perrin 3" Turbo Inlet
Injectors FIC1650cc
LFR7AIX Spark Plugs
Koyo High Performance Radiator + Youll get the stock rad
MFactory Oil catch can
Prodrive Boost Solenoid
HyperFlow FMIC
TurboXS RFL BOV
Magnetic oil Plug
AMS side mount light drycell battery
SPT Anthracite oil cap
Transmission:
Stainless Steel Clutch line
KartBoy Short Shifter with Bushings
IA performance KPH to MPH converter for the V7 Sti prodrive Cluster
JDM V7 STi 6speed transmission/suretrec LSD with Sti drive shaft and STi Axels
R180 rear diff.
Cusco engine & trans mounts
ACT 6 puck Sprung clutch
ACT Xtreme Clutch plate
Suspension and Brakes:
Cusco Comp-S Coil overs w/Front&Rear Cusco camber plates.
STOPTECH ST43 Front BBK with Street pads and Porterfield R4 track pads
Brembo Rear STi calipers with R4 pads
Motul Brake fluid
Stainless Steel brake lines
Sti Front And Rear Strut bars
Cusco rear Adj. Swaybar 20-23mm
KartBoy solid Front/Rear Endlinks
H-Brace
Exhaust:
Helix ver1 Bellmouth with 02 Bung hole
QTP Electronic cutout
Catless exhaust
2.75 inch piping all the way from the bellmouth to the Stock rear muffler
Exterior:
STi front grill
JDM MY02 STi Hood Scoop
JDM front bumper rail
Redline All black quicklift hood struts
Custom Painted Black Cherry Purple
Interior:
Full Jdm V7 Sti interior w/V8 Sti Rear back with passthrough
Sti Center Shift console
Sti Blue carpet
Jdm Prodrive V7 Sti Gauge Cluster
Jdm red Hazard
OEM carbon interior trim.
AEM UEGO Wideband gauge
Blitz FATT DC IV Full Auto Turbo timer
Genome STi Defi Boost Gauge, w/ Genome Defi Ver.1 control
AC works perfecto!
Rims:
5Zigen Forged Lug nuts
17x7.5 Rota Subzero Flatblack TOYO Ra1 tires 235/40/17
Tune of the above coming soon 1/2013
Old Dyno Tune Below
Event: Dyno pull
Ambient Temp: 75-85 F it was warm in the shop.
Elevation: 10-45 above sea level
Weather: Hot in the Shop on the dyno, but it was slightly cool [email protected] F
Tires: Potenza RE92 215/35/17
Car: 2002 WRX
Tuner: Jon @ HB Speed
Dyno Info: Dyno Dynamics
Peak HP at RPM: 463 @ 7400
Peak Torque at RPM: 383 @ 6200
Baseline hp/tq for a stock on same dyno: 2009 STi Dyno @ Average 235whp/230TQ
Target Boost: 27-28psi
Target AFR: 11.0
Fuel: 100LL AVGAS Leaded, .5g/ per Litre
crappy video better then nothin,
02+WRX+w%2fGT35R+2.2L+Cosworth+EJ207
Wheres the Turbo????!!
Mecka20000 is offline   Reply With Quote
Old 11-18-2009, 02:22 AM   #2
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Tuned with the cutout open? That has to be a blast to drive.
slowmike is offline   Reply With Quote
Old 11-18-2009, 02:50 AM   #3
jason miller
Member#: 158313
2003 WRX
Crikey. If you had used a rotated turbo setup and slightly higher compression pistons, this would pretty much be my dream setup. Amazing car.
jason miller is offline   Reply With Quote
Old 11-18-2009, 02:56 AM   #4
Mecka20000
Member#: 176162
^^ thats next..but im goin with 2.6L and rotated Twin Scroll 40r. after im tired of this setup for a while.
Old 11-18-2009, 03:16 AM   #5
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
good luck on that tranny lasting??? after i did my atp 35r a few weeks on beating on it all it took to kill my drive put shaft and take out my 2nd and 3rd gear..i had the same cyro treated RA gears also..
bmxhotsauce is offline   Reply With Quote
Old 11-18-2009, 03:36 AM   #6
Mecka20000
Member#: 176162
^^ thanx for the heads up, MFactory gears coming soon. got an extra blown 5spd sitting in the garage for it.
this is the third tranny btw ive rebuilt, so its getting old.
Old 11-18-2009, 12:05 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Looks great!
You rev to 8500!?!?! That is awesome.
...in car video??
All I can say to that is to keep an eye on my build thread...
CKxx is offline   Reply With Quote
Old 11-18-2009, 01:02 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i didnt think they were rated very high.
Just do the 6 speed swap and get it over with. Check with millenium auto a vendor here on nasioc.
They sell kits for 02 wrx's....mine was ~$3800 shipped for an 06 STi 6 speed, r160 rear diff housing with 3.9 gears installed, sti 2 piece driveshaft, shifter linkage, etc. Everything to bolt it up to your car and retain the stock axles and brakes.
Plus the close ratio 6 speed will make a big turbo more fun to drive.
I actually had it installed at HB Speed. Good peeps.
Old 11-18-2009, 01:50 PM   #9
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
^ i agree with phatron, the 5 speed was not designed for power. The 6 speed was... plus, the 6 speed's ratios were designed with a 8000rpm rev limit in mind. Those gears are made to keep the car in power. you've spent so much on that build/turbo setup, dont cheat yourself or your ride by going soft on the tranny.
I want to see more from the car including a video!
All4bSpinnin is offline   Reply With Quote
Old 11-18-2009, 06:10 PM   #10
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
are you worried about your o2 sensors with running that leaded gas all the time?
Old 11-18-2009, 09:36 PM   #11
Mecka20000
Member#: 176162
only got 1 wideband sensor in the exhaust, thats pretty much it, besides the blue AVGAS is .5g/L blue in color compared to the older .8g/L Green in color. I havnt seen any threads on Nasioc about somebody actually using 100LL as a daily so i figure i would start. I know i know ill get bad 02's and im catless so im ok with that.
Ya good lookin Phatron on that 6 speed swap , i was thinking of that. BUT....ive been hearing good things about the MFactory gears equal to PPG sooooo... idk, im 1 grand shy of 3K so ill make sure to give it better thought, i would love a 6 speed non-dccd, OH my what a hard choice. I still have Brakes and rims and cage to think about next after the drivetrain. SOOOOO much $$$$, LOL but it pays to play . And i love this game.
Old 11-19-2009, 03:23 AM   #12
rexblake
Member#: 178426
2010 S4
Gray
You running stock bearings in that engine? I have a V7 short block and trying to figure out what's safe to run for rpm, it's capped at 8k right now.
rexblake is offline   Reply With Quote
Old 11-19-2009, 04:01 AM   #13
Nuke209
Member#: 108089
2003 WRX
NF Performance
See how the powerband looks first.
Nuke209 is offline   Reply With Quote
Old 11-19-2009, 04:06 AM   #14
jamal
Member#: 71875
very nice. glad to see this thing get a real tune on it.
jamal is offline   Reply With Quote
Old 11-19-2009, 04:18 AM   #15
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
how long do they last for you???
Old 11-19-2009, 05:05 AM   #16
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
I noticed the same thing live near a small airport myself and plan on using 100LL also.
domestic_abuser is offline   Reply With Quote
Old 11-19-2009, 04:52 PM   #17
Mecka20000
Member#: 176162
went through three , 1st stock didn't last past the jdm engine swap at 280whp, the second on jdm ra gears broke second and main @ 300whp, 3rd trans broke at 355awhp, same gears with cusco tarmac center diff shattered second and chewed up cusco diff bad, Now im on the Newer Cryo Rallispec RA gears, 1 through 4th and new cryo main, and new viscous center diff. Now i have sworn off all drag, LOL to make this trans last at least at least a month till i figure out what to change too, the 6 Speed sounds tempting,
Old 11-19-2009, 04:55 PM   #18
Mecka20000
Member#: 176162
Default Bearings
The v7 ej207 in stock form ran too 8250 Fuel Cut, all day everyday, and no im on Full cosworth internals now, including bearings etc etc.
Old 11-19-2009, 04:57 PM   #19
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
cool cool, I was wondering when this thing was gonna be done, congrats, glad to hear its running so good, still selling it? or did you decide to keep? if you said above, sorry didnt read past the first post
KB'izzle is offline   Reply With Quote
Old 11-19-2009, 05:03 PM   #20
Mecka20000
Member#: 176162
hey, KB.
Yup still for sale, no nice offers yet so ill keep it up for sale till i get a tempting price.
In the mean time, ill just keep building it up until i run out of momentum and cash, LOL
Old 11-19-2009, 05:11 PM   #21
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
I'm in the process of selling my ra gear tranny now.. then im going to a 6spd swap... but good luck man you car looks sick..
Old 11-19-2009, 10:10 PM   #22
CatfaceType-R
Member#: 81102
nice ass motor and it looks great
CatfaceType-R is offline   Reply With Quote
Old 11-21-2009, 04:24 AM   #23
Mecka20000
Member#: 176162
Thank you for the complements guys i appreciate it.
Old 12-10-2009, 04:23 AM   #24
labelskate
Member#: 100512
2005 S2000
Grand Prix White
that turbo mounts in the stock location right?
labelskate is offline   Reply With Quote
Old 12-10-2009, 11:09 AM   #25
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
I had a JDM V8 6-speed which had DCCD...and I can't tell you how many times I tried getting my hands on a V7 instead, even offering straight-up trades. I loved my transmission, but I prefer the AP Suretrac and the non-DCCD setup of the V7 anyday.
One of my friends locally has a V7 EJ207 with a 20G setup...makes around 370whp Dynojet on pump gas, and he has a PPG straight-cut box in it. It has long gears, but combined with his huge redline, it's a blast...pulls through every gear.
Maybe it's because I had a really torquey 2.5 setup, but if I were to do it all over again, I'd go built 5-speed/R180. The 6-speed is nice, but longer gearing isn't necessarily a bad thing, plus the reduced weight and drivetrain loss is nice.
Depends on what you want.
Yes
zeropsi is offline   Reply With Quote
FS:02 WRX w/Cosworth 2.2L Stroked V7 EJ207, 500+AWHP Mecka20000 SCIC Private Classifieds 170 05-10-2014 03:02 AM
02 WRX w/Cosworth 2.2L Stroked V7 EJ207, 0 miles on build 22k OBO Mecka20000 SCIC Private Classifieds 43 03-15-2010 06:46 AM
Cosworth 2.2l stroker r0nzar Built Motor Discussion 5 11-13-2009 07:27 PM
how hard is it to swap a 5mt WRX tranny into a 4AT 2.2L impreza L? evorev Transmission (AT/MT) & Driveline 3 01-26-2004 06:15 PM
do WRX headers bolt on the 2.2L NA 96 block crk4 Normally Aspirated with bolt-on Forced Induction Powertrain 14 12-05-2003 05:56 AM
