Welcome to the North American Subaru Impreza Owners Club Tuesday April 20, 2021
Old 11-29-2009, 10:41 PM   #1
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Default Valve lashing
I am setting the valve lash on my 04 WRX heads. I have sti cams in them and will be using a forged piston 2.5L block with a GT35r turbo.
Lots and lots of searching has left me confused. Mick the ginge says he uses .008" intake and .010" exhaust clearance. A very well know Subaru Master Tech has told me to use .020mm intake and .035mm exhaust which calculates out to .008" and about .014" exhaust.
What should I do to get the quietest combo that I can get? The valvetrain is very noisy and when I checked the clearances they are all over the place (loose and tight). I just want them to make the most performance they can while being as quiet as possible.
Thanks.
CoolRex is offline   Reply With Quote
Old 11-29-2009, 10:45 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on [email protected] 30psi--spinning
I agree with mick you should shoot for .008 int and .010 exh +/- .002 and you should be quiet and get the maximum performance out of the cams.
john 1badSTI is offline   Reply With Quote
Old 11-29-2009, 11:01 PM   #3
Agile Auto
Member#: 91335
it's all about you exhaust valve material and cams. Both of them right. One give you clearances for aftermarket valve-train and another for OEM.
You would not have noise if you go with either. It's always better to be on the loose side. However if I were you I would set them at 0.008" and 0.012"
Good Luck,
Artie
Agile Auto is offline   Reply With Quote
Old 11-29-2009, 11:03 PM   #4
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Thanks. Now I just to find a set of feeler gauges that go .005 - .014ish in .001 increments! Can't find them at any of the parts stores so I may have to order from Matco. If anyone knows where I can get a set of feeler gauges for a decent price at or near the .005" - .014" range in .001" increments let me know!
Old 11-29-2009, 11:05 PM   #5
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Hmmmm well everything is stock WRX 2.0L stuff with the exception of 2.5L STi cams.
So here we have conflicting info yet again. What would be your reasonings for the greater exhaust clearance than what Mick and others (Ron at Raw uses .008 and .010 as well)?
Old 11-29-2009, 11:13 PM   #6
Agile Auto
Member#: 91335
Did not mean to confuse you. I use 0.010 (exhaust side)on all aftermarket cams. And I use 0.012 (exhaust side) on stock OEM cams.
Hope this helps.
Artie
Old 11-29-2009, 11:35 PM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I've always done 0.008" intake regardless of valve or cam. I usually run 0.010" exhaust but 0.009", 0.011", 0.012", 0.013", 0.014" all work.
mick_the_ginge is offline   Reply With Quote
Old 11-30-2009, 06:45 AM   #8
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
What's the main reasoning for running .010", .011", .012", .013", 0.014" on exhaust with OEM STi cams? Is there any benefit to running it tighter (.010") vs a little looser (.012")?
Old 11-30-2009, 12:33 PM   #9
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
I also use .008 int and .01 exh. I've learned the hard way that incorrect valve lash causes fun stuff to go on.
I have bc cams and they recommend .006 int and .008 exh. I feel that is too tight and will run oem spec.
NITROS is offline   Reply With Quote
Old 11-30-2009, 03:06 PM   #10
jason miller
Member#: 158313
2003 WRX
Sorry to interject with valve newbness, but did you have to change any of the buckets to run those sti cams?
jason miller is offline   Reply With Quote
Old 11-30-2009, 03:08 PM   #11
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Yes I'm going to have to change some of them. How many is yet to be known as I haven't lashed them. I just got the tool today from NAPA so I'll measure them all precisely tonight and see how many of my buckets I can salvage.
Old 11-30-2009, 07:54 PM   #12
Maxwell Power
Member#: 190729
too loose will damage the buckets, too tight can possibly burn valves.
Loose means less power because you make the cam smaller in both duration and lift
Tight means quite and more power because the cam is larger.
8 and 10 for solid cams
8 and 12 for hollow cams seems to do the trick.
all are +/- 0.001"
Maxwell Power is offline   Reply With Quote
Old 11-30-2009, 08:14 PM   #13
Maxwell Power
Member#: 190729
04WRX comes with shimless buckets which are the same as the STi. Shimless buckets are always the recommended route as they are much more reliable in high rpm applications.
He will need to change the buckets that are worn or do not yield the proper lash. Using new buckets is always recommended, but I've re used buckets on my own engines on many occasions. A proper, thorough inspection is important. Check for dimples in the center of the bucket or uneven wear patterns. Don't forget to check the side of the bucket in addition to the top. the side does a lot of work as well. Scored buckets should be replaced and the head should be lightly buffed to ensure it's smooth for the next bucket.
Old 11-30-2009, 10:29 PM   #14
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I think I'm gonna go .008" and .011". I can reuse more buckets that way. My intake is dead on minus one bucket. Exhaust I got .011 on 3 of them. The others I'll have to replace. I had to mix and match and swap buckets all around but thanks to a handy excel spreadsheet that made it easy.
Old 12-01-2009, 12:37 AM   #15
jaironsti
Member#: 203699
06 STI
dont mean to sound like a dumb newb, but how do you set the lash with the buckets? set the cams in the heads and measure with a feeler gauge. if you have to change a bucket for a different thickness to get the desired lash, do you have to remove the cam and swap them out or is there a easier way for this. I will be doing this soon and This would help alot!
jaironsti is offline   Reply With Quote
Old 12-01-2009, 12:46 AM   #16
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You have it right
Put the cam in, measure the clearance between the back side of the cam lobes and the buckets, write them all down.
Pull the cams out, pull the buckets out, and use a micrometer to measure the bucket thicknesses
Using the actual clearance and actual thickness you measured, calculate the required thickness to get your desired clearance
At this point you should have 16 bucket thicknesses that you need, if you can re-use some of your buckets (with rearranging of course) then you can, and the rest you have to order at $18/ea.
Old 12-01-2009, 01:45 AM   #17
jaironsti
Member#: 203699
06 STI
this is what I figured. Also, any chance you can do this with the heads on the bench and not bolted to the motor? sorry if this sounds ridiculous. thx
Old 12-01-2009, 02:18 AM   #18
davis10
Member#: 70011
No reason you can't do it on the bench.
davis10 is offline   Reply With Quote
Old 12-01-2009, 06:37 AM   #19
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Do NOT do it on the bench. Mine were vastly different after they were bolted down.
Old 12-01-2009, 10:17 AM   #20
Member#: 51961
2005 STi
2012 WRX
Right
Your clearances will all change once you torque the head on the motor, so you need to do your measuring then.
Old 12-01-2009, 10:27 AM   #21
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Yeah mine changed as much as .003" in many places. And when you do them don't simply hand tighten the cam caps. You 'HAVE' to tq them to the right specs (14 ft/lbs for inside caps and 7 ft/lbs for the cap at the gear).
Hand tqing the caps can change the values another .002". That was my second mistake. First mistake was bench clearancing them.
I've learned A LOT this month!
Old 12-01-2009, 11:11 AM   #22
richy_21
Member#: 58670
2005 got muuuuu?
what did you valve lash sound like?
richy_21 is offline   Reply With Quote
Old 12-01-2009, 11:22 AM   #23
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Like loose valve buckets. Tick tick tick tick tick. LOUD. At first thought it was injector tick.
Old 12-01-2009, 11:27 AM   #24
richy_21
Member#: 58670
2005 got muuuuu?
Is it noticable when blooping the throttle too or heavy accelerating?
Old 12-01-2009, 11:29 AM   #25
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
It's noticeable at idle and any other time engine is running.
DOHC valve lash BG5 Normally Aspirated Powertrain 2 07-25-2001 02:32 AM
How To: Setting Valve Lash on SOHC EJ25 stimpy Normally Aspirated Powertrain 3 06-06-2001 03:58 PM
Where did you people get your valve lash done? dcoty Normally Aspirated Powertrain 3 06-06-2001 12:45 AM
Suby dealers wont do my valve lash (cams) dcoty Normally Aspirated Powertrain 5 05-21-2001 08:50 PM
