Welcome to the North American Subaru Impreza Owners Club Sunday April 30, 2017
Old 01-21-2010, 08:54 AM   #1
DOHC_Holiday
Member#: 82006
1999 Forester
"Black-13"
Default DOHC block (O-ringed), SOHC heads: Which Head Gasket?
I am in the process of turboing my Forester, and I have a built engine going in. It's a DOHC block from a 98 Impreza (JE pistons, forged rods) that I am paring with a set of SOHC heads (from a 2001 Legacy GT). The block has been O-ringed.
When I put all this together, which head gaskets do I want to use? DOHC or SOHC? Do you match head gaskets to the block or the head?
DOHC_Holiday is offline   Reply With Quote
Old 01-21-2010, 06:55 PM   #2
DOHC_Holiday
Member#: 82006
1999 Forester
"Black-13"
T.t.t.
Old 01-21-2010, 08:45 PM   #3
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
what do you mean its o-ringed--did you install ductile sleeves? can you post pics because it would not be very efficient to oring the aluminum lip on a stock block.
john 1badSTI is offline   Reply With Quote
Old 01-22-2010, 09:12 AM   #4
DOHC_Holiday
Member#: 82006
1999 Forester
"Black-13"
Originally Posted by john 1badSTI View Post
... to oring the aluminum lip on a stock block.
That is exactly what I have.
Old 01-22-2010, 12:52 PM   #5
VIsubi
Member#: 187834
06 2.5i impreza
Red
I think he means the metal ring which is a metal o-ring per say. Should be a problem other than cooling issues..hondas have this issue with swapping heads and blocks ports line up but not all line up. I'd stick with what it is. What you could do is get a thinner stronger..more or less copper or the like head gaskets and bump compression a bit..spray the gasket with gasket bond a few times before..that will help with cracks later down the road.
VIsubi is offline   Reply With Quote
Old 01-23-2010, 11:12 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I'm assuming this built block has custom, low CR pistons? With the stock pistons, you would have to use the thick DOHC gasket, because the pistons actually protrude from the deck slightly at TDC. With custom pistons that may no longer be the case, but I would still think that the thicker DOHC gasket would be the safer bet.
Which Head Gaskets ej257 to 2001 sohc Joncas Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-25-2005 01:28 AM
Which head gasket for EJ257 swap SPESHAL Subaru Conversions 6 06-02-2004 12:34 PM
Which head gaskets? Tattoo Collector Normally Aspirated Powertrain 1 11-15-2002 04:24 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 11:08 AM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 11:40 AM
