Welcome to the North American Subaru Impreza Owners Club Thursday May 25, 2017
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 02-23-2010, 07:21 PM   #1
Imprezme05
Member#: 120924
2006 WRX Lmtd Wagon
Should be IMPREZme06
Default Should I machine the rotors?
I had RacingBrake rear pads installed after 68,000 miles on the stockers. I had the fronts machined and pads replaced around 33,000 miles. Do I need to machine the rears since majority of the weight and stopping power is on the fronts?
If so, who does SWIC recommend for machining?
Thanks,
Chris
Imprezme05 is offline   Reply With Quote
Old 02-23-2010, 08:29 PM   #2
BoostInc
Member#: 176520
1994 Legacy SS
black and mud
yes machine them, it will only cause more problems in the future if you dont. Any basic auto store or shop should be able to cut them and not **** them up. napa does a good job or any little mom an pop shop should do it to.
BoostInc is offline   Reply With Quote
Old 02-25-2010, 09:11 AM   #3
thegreg
Member#: 105429
2004 WRX STi
Machine the rotors if you are replacing the pads, or if they are getting glazed. Approx 80% of your braking, if mostly stock, is done on he front brakes. Rears really only engage under emergency stops.
If the rotors are getting glazed, but pads have still decent life, you can cut the rotors and scuff up the pads to get a rough surface on them again.
Matching the surfaces of the rotors and brake pads is the key to good safe, efficient braking.
thegreg is offline   Reply With Quote
Old 02-25-2010, 09:12 AM   #4
thegreg
Member#: 105429
2004 WRX STi
Old 02-27-2010, 02:31 AM   #5
Clur
Member#: 238257
2004 Wrx
San Remo Red
RESURFACE!!!!.. besides obvious reasons already stated.. your brakes will tend to squeak later on if not resurfaces.. takes like 2 hours... drop them off go eat or take a nap..
Clur is offline   Reply With Quote
Old 02-27-2010, 08:27 PM   #6
Imprezme05
Member#: 120924
2006 WRX Lmtd Wagon
Thanks, works for me! Any good places that are less than a Stealership out there???
Old 02-28-2010, 06:00 PM   #7
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
if the rotors are not grooved or anything and you can feel warping in the pedal or steering wheel then I would always suggest trying garnet paper first, as typically a rotor never actually warps.
dan az is offline   Reply With Quote
I should have powdered the boys today GodWhomIsMike Off-Topic 19 06-04-2010 04:08 PM
Changing Brakes. Should I replace the rotors. Visco212 Brakes, Steering & Suspension 3 11-03-2006 07:02 PM
Should I replace the rear rotors? DVN428 Brakes, Steering & Suspension 2 05-15-2005 01:41 AM
When to machine the rotors? Papa_Gorgio Brakes, Steering & Suspension 6 04-19-2005 03:17 PM
what's the worst that happens if you replace pads without machining the rotors? rex n effect Brakes, Steering & Suspension 5 08-04-2003 03:26 PM
