03-22-2010, 07:02 PM | #1 |
Member#: 36447
RMIC
Vehicle:Heav en for the weat her & Hell for company |
Rebuilding an EJ257 with forged - E85 ok?
Hey all. My '04 STi's motor recently popped, and I'm in the process of a rebuild. Going with forged pistons (likely CP's) but had a question on break-in.
I've been running E85 for the last 6 months or so, and read somewhere that because E85 burns cooler you can't break in a new engine with it, as the piston rings won't seat properly. Anyone know if this is true? Secondly, does boring/honing the cylinders and putting in forged pistons require a break in period? Basically, I'm wondering if I need to run the new pistons on 91 till they're broken in and then switch back to E85. Cost is an issue, unfortunately, and I'd really rather not get tuned two more times if I can avoid it. Thanks for any help.....
03-22-2010, 07:41 PM | #2 |
Member#: 163648
Vehicle:2002 WRX V9 6mt R180 Brembos |
I have a friend who went thru two motors both died on break in using E85 and rottela for oil....btw they were built by a Subaru rally god... He built my motor too, and I have not had one problem. I used gasoline+valvoline 10w30 for 900 miles of break in... After that I switched to E85 + amsoil 5w40 been running strong for 12,000 miles. And it's abused heavily....
03-22-2010, 07:43 PM | #3 |
Member#: 120912
South East
I would. There is lots of debate on it, but the general thought is that you stand a greater risk on E85 of washing the walls.
03-22-2010, 07:46 PM | #4 | |
Member#: 108089
Vehicle:2003 WRX NF Performance |
03-22-2010, 08:01 PM | #5 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
http://forums.nasioc.com/forums/show....php?t=1781008
don't do it! I went through hell. Don't break in the car on E85 there is chance that you rings will not seat. and rotella T is excellent |
03-22-2010, 08:47 PM | #6 |
Member#: 163648
Did you ever see the deep scratches on juks cylinder walls after that whole deal, maybe it was all the E85s fault for washing the rotella off but either way I will never combine E85 and rotella t or whatever he used ...Amsoil treats me well
03-22-2010, 10:35 PM | #7 |
Member#: 98000
Vehicle:05 sti e85@420hp |
Had nothing but great luck with Rotella w/e85. The few UOA's looked good to boot.
Washing out the rings during break-in on e85 does seem to make sense though. |
03-22-2010, 10:42 PM | #8 | |
Member#: 102236
South East
Vehicle:2006 Legacy Spec B 355whp/360wtq |
03-22-2010, 11:09 PM | #9 |
Member#: 36447
RMIC
My tuner and engine builder are one and the same, but we haven't gotten that far into the conversation just yet, as he's away on business and I don't wanna be a hassle.
I've just read some scary tales about breaking in on E85, so thought I'd get the groups concensus. Somewhat ironic timing - motor went after I filled the tank and three 5 gallon cans with E85 while en route to the gym. Like $60 worth of E85 & five minutes later < BOOM >. Life's a bitch sometimes, huh? Lol. |
03-22-2010, 11:13 PM | #10 |
Member#: 133146
03-22-2010, 11:21 PM | #11 |
Member#: 36447
RMIC
I had just filled the tank + bought an additional 15 gallons of E85 when the engine went. Just seemed like God was chuckling in my general direction, had nothing to do with the tune/fuel, etc.
03-22-2010, 11:57 PM | #12 |
Member#: 108163
Vehicle:2005 STI OBP |
This thread brings nightmarish flashbacks of maxed out credit cards...
You shouldn't have to pay for two tunes. He'll probably just put a break in tune on it, next time I do it, I'll do that part with gasoline. Once she's broke in go back to E85 and crank up the boost. Good luck. FWIW it was recommended to me not to mix Rotella conventional with E85, but who knows. All I know is I'm going to do it as different as possible from the last two attempts Last edited by Juks; 03-23-2010 at 12:04 AM. |
03-23-2010, 12:26 AM | #13 |
Member#: 36447
RMIC
He's a really fair and good guy, honestly. I'm just trying to educate myself as much as possible along the way.
He just tuned me about 6 months ago for the E. If nothing else I'm proving a very loyal customer thus far. |
03-23-2010, 12:56 AM | #14 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Well, 3-400 miles into a "new" motor started up on E85....
runs fine..... no blowby or spun rods.... yet..... |
03-23-2010, 10:36 AM | #15 | |
Member#: 108089
Seems the rest are still running fine here |
03-23-2010, 10:40 AM | #16 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
Just don't be a pansy when breaking in your engine and E85 will be fine. Rings need boost to seal. If you have a good tune on E85 already then that's great.
Now remember that my car is not a daily driver but this is what I do as a break in. Warm car up, high idle for 20 mins, stop, flush and change oil. Onto the dyno for pulls under load at progressivly higher rpms at wastegate boost. Let off at end of rpm and let engine coast back down. Do this for about 25-50 miles on the dyno until I am doing runs under load to close to redline. I can tell when the rings seat as the amount of oil smoke out the back drops off under decel. The key is boost and variable RPM's |
03-23-2010, 11:56 AM | #17 | |
Member#: 133146
03-23-2010, 01:47 PM | #18 |
Citizen Mick
Member#: 27646
NWIC
03-23-2010, 01:58 PM | #19 |
Member#: 36447
RMIC
While my EGT probe is tapped into the downpipe (not ideal, I know) I saw temps go down nearly 200 degrees from 91 octane to E85. It surprised me, even though I was expecting to see some drop.
But yeah, my tune on E85 felt really good while the car was running. My tuner/builder has tuned lots of Subies on E, and built quote a few engines that are doing well, so I'm hopeful everything works out. |
04-05-2010, 08:47 AM | #20 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
Just found this thread. I'll get you a break in map for pump gas so you can break it in that way. When trying to put a lot of miles on an engine in short amount of time it helps to run pump gas. Juan had a bunch of problems, but I'm not convinced E85 was the culprit. A local customer of mine broke his engine in on E85 recently and had absolutely no problems. Did you find someone to get the engine out of the car and to me, or are you going to have me do the whole thing?
EJ257 With forged CP pistons *Used | jainuss | Engine/Power/Exhaust | 19 | 02-26-2010 12:03 PM |
FS-EJ257 functional short block with forged internals | E85 WRX | Engine/Power/Exhaust | 19 | 01-10-2010 04:06 AM |
FEELER: EJ257 longblock with forged pistons | AwdBoostCreep | Engine/Power/Exhaust | 23 | 08-21-2009 12:14 AM |
Breaking in an engine with forged internals | rip_sti_ra | Built Motor Discussion | 11 | 06-06-2007 10:20 PM |
EJ25 with an EJ257 ??? | Kripski | Subaru Conversions | 5 | 11-22-2004 05:05 PM |
