Welcome to the North American Subaru Impreza Owners Club Wednesday October 5, 2022
Old 03-29-2010, 06:27 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default Rob eprom chip with fmic - REVEIW -
About a week ago i was on school break for a week and i decided to put my car down for a lil bit..
i installed my
FMIC
swapped out KOYO for stock RS rad/fans
relocated battery to the trunk
installed 550 yellow injectors (with the adapter collars)
lil things here and there.
the on ramp home from swapping the ECUs was amazing.. my car use to experience BRUTAL heat soak (with slanty and no scoop), i dont know what my car would feel like with ONLY the FMIC, and i feel it helps out alot.
well i am very happy with what i got and i cant wait till the next dyno day to see what happens.
Some people claim to have more lag with a FMIC. but i dont feel it that much, if at all..
im just running what the ECU has the boost set to, 16psi. i havent put on my MBC yet. i haven't even been able to get higher then 6000RPMs yet.
thanks Rob for working with me on such short notice.
azn0boi04 is offline   Reply With Quote
Old 03-29-2010, 08:01 PM   #2
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
any advice/comments on your fmic install? I was reading up on the thread from rs25.com but I'd really like to hear from an EJ20G owner.
sizzflair is offline   Reply With Quote
Old 03-29-2010, 08:12 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
just have something to cut pipes with, and a file
follow the directions on the turbo U-shape pipe, and the hot side it pretty easy.. the cold side gave me the most problems... but with a cutting wheel and air compressor everything works out. even a sawzall works. i just dont have one (might be easier with that) ... it took me 2 days.. idk its hard to give tips, it can be done as long as u have time and NO ABS!
DONT forget to spray the cuts, so no rust.
Old 03-30-2010, 10:07 AM   #4
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
i installed my
FMIC
please tell me you didnt do that.....come on RS hoods are really cheap..and the best part is they come with scoops ...I would have drove without a hood or something
Cbgrandtheftauto is offline   Reply With Quote
Old 03-30-2010, 11:56 AM   #5
sizzflair
Member#: 94268
2010 Exige S240
which FMIC did you go witH?
Old 03-30-2010, 12:01 PM   #6
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
RS hoods are like 250.. anyways i knew i was going to put on a FMIC so i just roughed it for a lil while, and i like my car to look "kinda sleeper"
bumper is still waiting to go on.. weather has been bad.. so i look like a wannabe drifter
Old 03-30-2010, 12:42 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
I was wondering if you put the skin back on....I think that will change your time estimate a bit
Thanks for the nice comments. I hadn't heard from you so was worried it blew up on the ride home. How bad is the boost spiking on the stock boost control? Did you see the knock indicator flicker at first then go away. Have you tried the launch control?
-Rob
rob is offline   Reply With Quote
Old 03-30-2010, 02:06 PM   #8
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
-Rob
i have mechanical prosport gauges and i have a hard time reading the boost level when WOT, the boost gauge needle moves up the higher the rpms. idk its hard to explain, there way different then my brothers elec Defi.
the only time i use the launch control was in the parking lot with u... i never launched it off the line..
Old 03-30-2010, 02:44 PM   #9
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
What transmission you runnin??...if it's the stock L or RS 5sp watch the 2nd gear shift after a 2 step launch...it will go boom....I know...I did it.
well it wasn't with launch control...my rev limiter is my launch control
Old 03-30-2010, 03:24 PM   #10
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
its the 20g wrx tranny
Old 03-31-2010, 09:21 AM   #11
marshal.
Member#: 227140
1994 WRX
red
Im also pretty curious as to which FMIC you went with, as i am seriously considering getting one now that the motor is out.
marshal. is offline   Reply With Quote
Old 03-31-2010, 11:29 AM   #12
Gerkins31
Member#: 52337
Me too.
Gerkins31 is offline   Reply With Quote
Old 03-31-2010, 12:33 PM   #13
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well its a CXracing Ebay FMIC...its really good to my knowledge... i mean there arent really any FMIC made for GCs... but i got this one used from a guys with a RSti. and had some stuff already cut to fit.. but YES cutting will be involved..
but for 265 shipped is not bad.. some Cores cost more.. anyways.. i have a really good write up on it..
FMIC EBAY listing go get the idea (mine isnt that shiny)
RS25 DIY
and for this write up. u can skip all the way down, at least u guys better know how to take off the bumper.
the hole near the fender is bigger on mine ahah its hard to eye ball where its going. and cut the part it says to "bend" near the bottom.no big deal
and make sure u wipe/rinse/air blast the inside of the pipes.. or your getting metal flakes in your engine.
It shows in the writeup that he an keep his Fogs... i have not put on my RS bumper and i can not confirm.
took me 2 days.
Old 04-08-2010, 03:11 PM   #14
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
I'm interested in how much power you are putting down. I have basically the same mods as you but with UEL aftermarket headers.
JDMFLCL is offline   Reply With Quote
Ebay GF8 Eprom chip, is it good one? tschencito Engine Management & Tuning 2 06-02-2008 01:31 PM
So can you use JC Sports Torque chip with 4EAT? Hyper Normally Aspirated Powertrain 4 11-24-2003 10:29 PM
Anyone here know about eprom chips and security? mattjk Off-Topic 2 11-24-2003 04:52 PM
Last time for bid to locals: proECM chip & FMIC DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 5 11-04-2002 11:30 PM
Vishnu chip with TXS harness Scuby Snacks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-25-2002 07:31 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
