Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 06-03-2002, 01:07 AM   #1
ImpresiveWRX
Member#: 6117
2000 Impreza 2.5RS
Silverthorne Metallic
Default The most power increase for $800
I have a my00 rs with only one engine mod. a home brew cold air intake. I got about $800 to blow on upgrading. Any suggestions on what to get for the most power?
ImpresiveWRX is offline   Reply With Quote
Old 06-03-2002, 01:47 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Cobb NA/Turbo Cams
Old 06-03-2002, 01:53 AM   #3
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Full exhaust system, (Headers, High flow CAT, midpipe, muffler)
The cams won’t react as good without the right flow through the engine.
Burnout is offline   Reply With Quote
Old 06-03-2002, 02:45 AM   #4
Kostamojen
Member#: 2272
2018 Type-RA 196/500
1999 OBS Camo Wagon
MRT full exhaust + pulleys comes out to around $800
Worth about 15hp+ or so...
Old 06-03-2002, 09:48 AM   #5
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
the MRT full exhaust is priced at $600??!!!
rupteur7000 is offline   Reply With Quote
Old 06-03-2002, 02:20 PM   #6
tonytiger
Member#: 3844
1993 Legacy 1.8
The cams definetly. EJs' have so mild cams. Cobb according to their web page have very nice ones. I'd love the more aggressive ones than the spicy cams or what are they called. Somebody said to me: Changing cams isn't worth it, if there is no sacrifice on the lower RPM. Well
What's the RPM limit on EJ25? If I remember correctly it's somewhere like 7000 and the peak power from the stock is at 5600?! If so there is a lot of RPM's to use. Power is proportional to the RPM. The problem is to get the torque to the higher RPM...
Cams are great for it.
tony
tonytiger is offline   Reply With Quote
Old 06-03-2002, 04:03 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
then explain to me why the cams make the biggest wheel HP increase over your intake/header back system
the spicy cams are NOT to be used in a car that does not have some kind of engine management, they move the peak power up by 500 rpm and you'll need to do valvetrain work and also get a re-mapped ecu.
the stock RS valvetrain will float @ 7200 RPM
Just my $.02
jeremy
Old 06-03-2002, 07:14 PM   #8
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Front and rear strut tower bars, bigger rear sway bar, and solid swaybar endlinks. Maybe even stonger sway bar mounts. Get the handling nailed down first, so you can handle the power you add later.
But, if you already have handling/suspension mods, and just want power/performance stuff: proECM, short shifter, exhaust (not even going to suggest one, but I do like my Stomung), K&N or Amsoil filter.
HondaH8er is offline   Reply With Quote
Old 06-03-2002, 08:39 PM   #9
Reciprocity
n00b Moderator
Member#: 1165
2012 dcrawford died
for your sins
Tighten the nut behind the wheel.
NC
Reciprocity is online now   Reply With Quote
Old 06-03-2002, 11:27 PM   #10
obyone
Member#: 16523
NC
Yup...most people forget that one. Too bad the majority of the nuts out there are still loose.
obyone is offline   Reply With Quote
Old 06-04-2002, 03:24 AM   #11
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
$560 I thought, not including shipping
Old 06-04-2002, 04:00 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
NC
that too, gotta fix the loose nut behind the wheel
Old 06-04-2002, 05:19 AM   #13
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
tony
Fuel cut happens at 6250, so peak power isn't that far off at 5600.
Most power for $800? Nitrous. But I'd never do it.
I would however like to do cams.
CosmoTheCat is offline   Reply With Quote
Old 06-04-2002, 11:10 AM   #14
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
A RS buddy of mine is planning to order the Spiceys from Cobb. It is recommended that you raise the redline to take full advantage of those aggressive cams but not mandatory. "Torque peak moves up approximately 600 RPM and Horsepower peaks at the stock redline."
HndaTch627-Please back up this statement "the stock RS valvetrain will float @ 7200 RPM "
IIRC and article or post from Trey Cobb regarding his research on the stock valvetrain was that he determined the stock internals (valvetrain included) would be safe up to about 7500 rpms. He then made a statement along the lines of "I wouldn't go above 7200rpm just to be safe". He also said something about the intake manifold beeing a big hinderance when stretching to those higher rpms. Let me see if I can find that article.
MY99 2.5GT is offline   Reply With Quote
Old 06-04-2002, 11:17 AM   #15
proecm
Member#: 12081
If you want the most HP/$ there is simply nothing that beats nitrous. End of story. There are some good kits that have been run for an extended period of time that seems to be reliable as well.
Give it a shot, (pun intended).
/David
proecm is offline   Reply With Quote
Old 06-04-2002, 12:48 PM   #16
imprezive
Member#: 746
cobb intake and cobb cams
imprezive is offline   Reply With Quote
Old 06-04-2002, 02:37 PM   #17
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
do me a favor put those spicy cams in and then spin it that high...i'd like to see what happens you guys are forgetting that this is a LONG stroke motor, you MUST take rod speed into account. but then agian i'm not trey cobb so i know nothing about subaru's
Old 06-04-2002, 02:52 PM   #18
CosmoTheCat
Member#: 3409
98 My FMIC
I think he's banking on people upgrading lots of other bits internally (heads, valvetrain, pistons, rods, etc) if they're going to bother raising the rev limiter. Or at least, it used to be somewhat cost-prohibitive for the average joe to do so (standalone ecu used to be the only way, no? But now apparently we've got people reprogramming stuff four a couple hundred bucks).
Anyway, I'm going to avoid the spicy. Who knows... I may feel rich some day and actually shell out for forced induction.
Old 06-04-2002, 03:30 PM   #19
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Mrt full exhaust if you plan to stay naturally aspirated because of it's ease of installation.
Cobb mild cams get you 14 Hp on a STOCK engine and with a full exhaust and intake more power can be had. I still suggest exhaust/intake first. Just because they are easy to install. IIRC the mrt full exhaust made 14 Hp over stock too.
If you plan on going Forced Induction then keep saving.
-Chav
Chav is offline   Reply With Quote
Old 06-04-2002, 06:02 PM   #20
kickin_81
Member#: 16679
2004 Forester XT
NC
Alright, now where is this? Steering wheel or wheel well? I'm one of them who hasn't done it. Thanks.
kickin_81 is offline   Reply With Quote
Old 06-04-2002, 06:20 PM   #21
Reciprocity
n00b Moderator
Member#: 1165
2012 dcrawford died
for your sins
It's easiest to see when you angle the rear view mirror towards the drivers seat.
NC
Old 06-04-2002, 06:27 PM   #22
obyone
Member#: 16523
"You've just been n00b-ed.
Old 06-04-2002, 06:43 PM   #23
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Calm down, its all right
What I ment was that the cams will not produce as much power compared with a car that had a full exhuast sytem and intake.
I didn't say that a full exhuast would make more power than cams.
Old 06-05-2002, 10:00 AM   #24
kickin_81
Member#: 16679
2004 Forester XT
Great... I went up to the homeplate for the team and struck out. Someone had to make a stand.
Old 06-05-2002, 11:05 AM   #25
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
/David
yes, i have it, and i can take down stock wrx's, its close against wrx's with intake and exhaust. its fun, try it!
of course i would MUCH rather have that much power n/a or turbo/super. but theres no way i would have got that much power gains that cheaply without nitrous.
jasona is offline   Reply With Quote
What year USDM STi produces the most power on the stock turbo and engine? Red Rexx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 46 05-13-2008 10:02 AM
the most powerful handgun in the universe! incorporeal Off-Topic 115 05-29-2007 09:15 PM
the most powerful man in the universe! Rock_Strongo Off-Topic 30 12-30-2005 12:56 PM
the most powerful battery powered light you currently own Caddy Daddy Off-Topic 37 05-13-2004 02:45 PM
New H6 the most powerful 3.0l 6 cylinder NA in the world? fenix General Community 31 09-10-2003 12:47 PM
