Welcome to the North American Subaru Impreza Owners Club Tuesday January 16, 2018
Old 06-06-2002, 04:09 PM   #1
aleks_rs
Member#: 19217
2001 Impreza 2.5RS
Red
Question ECU reset after intake install?
I've had my RS for about a year, circa 25k miles. Finally got a Ganzflow, which is coming in the mail. The install instructions recomend reseting the ECU. However, my ECU has learned quiet a bit in the last year. For example, I raced my friends 300ZX recently (non-turbo), and while I didnt beat him, we were nose-to-nose. About 6 months ago, this same Z was leaving me in the dust (I've run my car over 100 on the freeway almost on a daily basis lately, so that must've done it). I have no engine upgrades done right now. SOO, should I reset my ECU and loose all the good things it's learned? Anyone have any experience with this?
aleks_rs is offline   Reply With Quote
Old 06-06-2002, 04:49 PM   #2
Jademonkey
Member#: 9213
2000 RS
Red
Bottom line...you don't have to reset your ECU. But it's recommended to take quicker advantage of your new intake. Your ECU will eventually learn, resetting it just speeds up the process.
Jademonkey is offline   Reply With Quote
Old 06-07-2002, 01:50 PM   #3
gypsymoth
Member#: 6072
01 Silver 2.5 RS
04 Silver WRX STi
The ECU is pretty smart. Over time it will learn new tricks and give you more HP. There is no need to reset it. The ECU will continue to learn.
As for all the remarks about the ECU learns quicker if resetted . . . I'm not so sure . . . considering that it take 3000 miles or so for the ECU to become fully effective.
Is 3000 miles quicker? 3000 miles is a long way. Can an un-reset ECU learn the same tricks in 3000 miles? I would think so.
Chieh
Chieh's Web - http://Chieh.CameraHacker.com/
gypsymoth is offline   Reply With Quote
Old 06-09-2002, 12:41 PM   #4
BugBomb
Member#: 1342
99 OBS & SUXASS
May your line be smooth
Default Re: ECU reset after intake install?
The ECU does not "learn" or adjust settings at WOT, which is what I assume you were using while racing. The open-loop fuel maps do not change, ever. The ECU simply picks a pre-set map based on sensor input. Go search the internet for "open loop" and I am sure you will find plenty of websites that state this. Whatever differences you noticed would have to come from somewhere else, like driver ability, gas, or any number of variables.
Maybe we should have a segment in the N/A FAQ about WOT and open loop.
BugBomb is offline   Reply With Quote
ECU Reset after CBE Install ETown Newbies & FAQs 16 02-15-2008 07:43 PM
ECU Reset after catback install nyngbld Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2005 10:28 PM
ECU reset after tbe install? jakmobile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-19-2004 02:48 PM
ECU reset after O2 sensor install SubaruLover Normally Aspirated Powertrain 2 09-02-2002 05:08 PM
ECU reset after up-pipe install 6starspeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-19-2002 09:03 PM
