Welcome to the North American Subaru Impreza Owners Club Wednesday September 20, 2017
Old 04-16-2010, 11:07 PM   #1
94EJ22TImpreza
Member#: 237375
2002 Impreza WRX
Blaze yellow
Default Ej22t stock maf?
what is the stock part # and brand?
94EJ22TImpreza is offline   Reply With Quote
Old 04-17-2010, 12:20 AM   #2
dr3w
Member#: 222318
1993 RHD GC8
I believe its the 160f's. If it is i have one laying around for you.
dr3w is offline   Reply With Quote
Old 04-17-2010, 12:59 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes it is the 22641AA160, it is a common part that can be found on many Legacy's and Impreza's up to 1998 (2.2, 2.2T, 2.5).
Marnix is offline   Reply With Quote
Old 04-17-2010, 02:05 AM   #4
94EJ22TImpreza
Member#: 237375
2002 Impreza WRX
Blaze yellow
well thats the PO. i got....humm
well im looking for one i can test with to see if mine is bad....
Old 04-17-2010, 02:22 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
i have one you could use to test... maybe sale to you if needed. but im a bit south from you...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 04-17-2010, 02:43 AM   #6
94EJ22TImpreza
Member#: 237375
2002 Impreza WRX
Blaze yellow
-=Suberdave=-
Where you be?
Old 04-17-2010, 10:11 AM   #7
suberdave
Member#: 101865
88 GL-10 STi
like it says in my profile... I be in Kent / Covington, WA...
-=Suberdave=-
Old 04-17-2010, 02:03 PM   #8
curt
Member#: 165657
fast wagon, toyota
4x4, & a supermoto bike
i have a spare one if you wanted to try it. im in lake stevens, pretty close to snohomish.
curt is offline   Reply With Quote
Old 04-17-2010, 06:59 PM   #9
94EJ22TImpreza
Member#: 237375
2002 Impreza WRX
Blaze yellow
That sounds good. Im in lake stevens all the time.
-=Suberdave=-
It curt isn't willing to let his go i would like to buy yours if it just so happens to fix my issue.
Old 04-20-2010, 08:17 PM   #10
RallyColtTurbo
Member#: 16819
If I'm reading the first post correctly, the OP is looking for a stock EJ22T MAF.
IIRC the ...aa160 is the black plastic JECS MAF. Those are the ones that are common up until '98. The USDM EJ22T Legacies had the aluminum Hitachi MAF. Those only came on a few early '90-'94 Legacies. The gen 1 Legacies were built as Subaru was phasing out Hitachi and switching to JECS.
I don't have the part number in front of me here at work, but the EJ22Ts had the silver aluminum Hitachi MAF as stock.
RallyColtTurbo is offline   Reply With Quote
Old 04-21-2010, 09:36 AM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I've seen them both way. My '91 SS has the Hitachi MAF. My '93 and '94 Touring wagons had the plastic one.
Regardless, you can switch over a car with the Hitachi MAF to the JECS AA160 version. There's a "how to" over on Leggy Central.
Old 04-21-2010, 12:26 PM   #12
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Unless I'm missing something from previous posts, all turbo charged legacies 91-94 utilized the Hitachi aluminum MAF. It's part # is 22680AA170.
You can not swap MAF's on the turbo ECU's without an additional engine management setup or reprogramming of the ECU. If you handle the engine management, then yes you can swap MAF's as Matt mentioned.
Legacy777 is offline   Reply With Quote
Old 04-27-2010, 11:04 PM   #13
bcturbo
Member#: 245329
93 Subaru
Winestone
my 93 ss has an aluminum maf
bcturbo is offline   Reply With Quote
Old 05-06-2010, 12:54 AM   #14
vf11justy
Member#: 245537
88 Subaru
yes, the 93 ss's do have a hitachi
vf11justy is offline   Reply With Quote
Old 05-07-2010, 12:54 PM   #15
kleinkid
Member#: 27091
2010 STi SE
I have a '91 and a '94 Legacy SS, they both have the aluminum hibachi.
kleinkid is offline   Reply With Quote
Old 05-07-2010, 01:02 PM   #16
1994LT
Member#: 229442
2006 legacy gt ltd
regal blue
so does my 94' SS
1994LT is offline   Reply With Quote
Old 05-07-2010, 05:14 PM   #17
jdmwrx94
Member#: 211619
94 jdm wrx
red
I have a 22680 AA170 Hitachi Maf on aluminuim mounting tube. I can confirm that it wont work wlug n play with the 20g 160 maf
jdmwrx94 is offline   Reply With Quote
FS: 04 STi ecu, 83mm mega maf, stock maf sensor, Fuel line and fittings.... trbowrx Engine/Power/Exhaust 11 02-08-2009 11:55 AM
FS: WI STi Perrin FMIC, big MAF, Boost inlet, CAI extension, stock MAF hose. 05 WR Blue STI Engine/Power/Exhaust 14 10-06-2008 10:40 AM
WTB: MAF sensor and stock MAF inlet tube cyrexpl Private 'Wanted' Classifieds 1 09-05-2006 06:55 PM
WTT: STI floor mats for WRX floor mats and SAMCO MAF hose for Stock MAF elbow BLACKWRX03 North West Impreza Club Forum -- NWIC 6 09-17-2004 02:49 AM
Cut stock maf tube from stock airbox, what effects did i create? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-16-2004 02:02 PM
