Welcome to the North American Subaru Impreza Owners Club Thursday December 14, 2017
Old 05-14-2010, 12:24 PM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default Element Tuning GT65 Bolt On Turbo, Hydra EMS, E85 fuel, 532whp, 07 STI 2.5
This is really impressive for a bolt on turbocharger running E85 and pump gas. On this tune the customer swapped out the header and it appears we lost some bottom end power over the old but peak power stayed about the same (on pump gas). All the dyno plots on this tuning session had the "blips" where the WG opens and I just noticed this time around the dyno was set to 150 instead of 120 so that could have something to do with it.
Numbers
Dyno: Dyno Dynamics @ Pina Motorsports, WA
Tuner: Phil Grabow Element Tuning
Wheel HP: 532whp UNCORRECTED
Wheel TQ: 513wtq UNCORRECTED
Target Boost: 26 psi
Target AFR: 11.5
Fuel: E85 and 92 Octane pump gas
Ambient Temp: 50
Elevation: 0
Initially I tuned the car with DW 1000cc injectors but for E85 we stepped up to RC 1600cc with the base fuel pressure set to 50 psi but the regulator diaphragm failed so we had to replace the regulator with an Aeromotive A1000 (don't waste your money on anything else!). We also swapped in a TurboSmart BOV to better manage peak boost pressure and not blow open.
Car Info
Year: 2007
Engine Management: Element Tuning Hydra EMS
Turbo: Element GT65 Bolt On
Intercooler: APS
Meth Kit: None
Injectors: RC 1600cc, Bosch 044 Fuel Pump, A1000 regulator
Engine: Element Tuning Rods, CP Pistons, Cosworth cams, stock block and bore.
Intake/Inlet: Magnus, APS
Headers: AMR
Uppipe: AMR
Downpipe: ?
CBE: Invidia
Other:
The Element GT65 Bolt-on really shined on E85 fuel especially given the car didnít have anything done to the heads but a set of cams.
Thanks,
Phil Grabow
Element Tuning
Element Tuning is offline   Reply With Quote
Old 05-14-2010, 01:22 PM   #2
CosworthSTI77
Member#: 195473
2007 STI
Dam that color looks sharp ! Great dyno numbers Phil that E85 is amazing. I want to play DYNO OR NO DYNO !
CosworthSTI77 is offline   Reply With Quote
Old 05-14-2010, 04:01 PM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Is that a bunch of surge on spoolup?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 05-14-2010, 04:10 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
-- Ed
No all the cars were doing this ranging from bolt-on turbochargers with stock engines to twin scroll kits with the works. I think it's the dyno ramp being set to 150 instead of 120 like I had used previously. All the cars I had tuned in the past but this time around we were either using different fuels, slight mods, or larger injectors.
Old 05-14-2010, 08:12 PM   #5
john 1badSTI
Member#: 77470
04 sti [email protected]
on [email protected] 30psi--spinning
nice job Phil but I think it would be a good idea to swap out those worm gear clamps on the intercooler couplers to t-bolt clamps just to be safe.
john 1badSTI is offline   Reply With Quote
Old 05-14-2010, 08:17 PM   #6
CatfaceType-R
Member#: 81102
definitely with that kind of power I would be using tbolt clamps, I would use them anyway if I had a fmic regardless of power
CatfaceType-R is offline   Reply With Quote
Old 05-15-2010, 02:55 AM   #7
DSM_Outback
Member#: 56345
93 Swapped L
Green
Is this Carter's car?
DSM_Outback is offline   Reply With Quote
Old 05-15-2010, 04:33 PM   #8
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
phill why are you using there retarded dyno?
Bariga is offline   Reply With Quote
Old 05-16-2010, 03:15 AM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
there is spelled THEIR.
Old 05-18-2010, 02:06 PM   #10
Element Tuning
Member#: 54918
673 WHP Element
Not sure why you would say that as many use the Dyno Dynamics. Also this dyno was tested by one of the "Tuner" magazines in a comparison test against Dynajet and more reading lower than others and higher than some so it's right in the middle. I'm not a huge fan of the Dyno Dynamics as other dynos are easier to use but Pina Motorsports has been great to all the people I've tuned there. So many had problems with their cars and Andre always offers to work and fix there cars often finding solutions to difficult problems. The price is fair, we typically book up an entire week, and he stays as long as we need.
Old 05-18-2010, 11:21 PM   #11
16G4ME
Member#: 69792
05' wRxElementTuned
HydraW/Hydramist & GT65
+1 to that Andre is so helpful. After having several conversations with him I can really tell he enjoys what he does. I was happy with the numbers my car spit out on this dyno
16G4ME is offline   Reply With Quote
Element Tuning: Hydra, Hydramist, 624 whp 07 STI 2.5, 35R Element Tuning Proven Power Bragging 39 07-21-2010 02:36 AM
Element Tuning GT65 Bolt On, Hydra, [email protected] psi, 07 STI 2.5 Pump Gas Element Tuning Proven Power Bragging 15 06-16-2010 02:45 PM
Element GT65 bolt-on, Hydra, Hydramist, 494 whp Element Tuning Proven Power Bragging 22 08-27-2009 04:56 PM
FS:cobb v2 accessport 07 sti 2.5 Crow-sti07 Tri-State Area Private Classifieds 1 01-06-2008 08:55 AM
Element Tuning GT65 Turbo Kits and TurboXS Holiday Packages continue! WorldOne Engine/Power/Exhaust 59 02-15-2007 06:03 PM
