Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 06-10-2002, 06:21 PM   #1
PeterJ
Member#: 14727
2002 impreza RS
Default What does a stroker kit do?
Does the kit replace the crank so the bottom of the connecting rod travels in a larger circle? Does piston diameter and connecting rod length change? Does it increase displacement and or compression ratio? No specific info in a search... Anyone?
PeterJ is offline   Reply With Quote
Old 06-10-2002, 07:36 PM   #2
Tangmere
Member#: 572
A stoker kit is generally a replacement crank with offset or smaller journals, this increases the stroke of the piston, thereby increasing the displacement of the engine. Sometimes machine work is required to make room for the increased swing of the rods. Increasing your bore will give you a larger displacement too, but you're limited to how much you can overbore by the thickness of your cylinder walls. Increased compression is more a function of the design of the piston, you can gain a few points of compression by milling the heads, the downside to this is that you decrease the clearance between the piston tops and the valves. But all that would be taken into consideration by the machine shop.
MRT sells stroker kits. Do a search on their website, they'll definitely be more helpful than me.
Mark
Tangmere is offline   Reply With Quote
Old 06-11-2002, 06:02 PM   #3
PeterJ
Member#: 14727
2002 impreza RS
Hey thanks Mark, I'll try the MRT site again. You just gave me more info then I found there the first time. Does any one here have a stroker kit? Do they increase torque but reduce your rev limit?
Old 06-12-2002, 01:49 PM   #4
2.5GTL
Member#: 5082
1998 Legacy GT Ltd
You can find several manufacturers of stroker kits at www.subarureview.com
You might be able to find more info at each of the manufacturers sites.
Jason
2.5GTL is offline   Reply With Quote
what does a Intercooler Really do ? ninetalesnwf Newbies & FAQs 14 05-12-2001 11:38 AM
What does a Turbo Timer do? WR-REX Normally Aspirated Powertrain 3 04-24-2001 06:18 AM
What does the JCS TCII do? RebelINS Normally Aspirated Powertrain 4 03-29-2001 04:53 PM
what does a sway bar do? christurismohk Newbies & FAQs 3 01-10-2001 09:56 AM
