Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 06-05-2010, 08:30 PM   #1
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Default DIY: trailing arm bushings (1 piece Energy Suspension and 2 piece Super Pro)
Here is how to install 1 piece Polyurethane front trailing arm bushings (w/o sleeve) without using the press. Took me total ~20 min to install both bushings.
Things you need:
- Energy suspension 1 piece "RED" bushing w/ grease. Grease that comes with Energy suspension is really sticky and is not easy to clean...
- Tools painted in black are part of front bearing replacement kit I purchased from Harbor freight for $80.
- You should be able to source similar tools from Home Depot...
Energy suspension bushing is probably 100x stiffer than stock bushings.
Replace the bottom flat plate with another one with flushed center once it's no longer possible to tighten the nut (32mm).
Time to install the sleeve:
Here is a link to 2 piece rear trailing arm bushing installation (post #28)
http://forums.nasioc.com/forums/show....php?t=1931924
Old 06-05-2010, 08:53 PM   #2
LitespeedPerformance
Member#: 242368
^^^Nice work!
LitespeedPerformance is offline   Reply With Quote
Old 06-05-2010, 08:57 PM   #3
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Thanks - I will be posting pictures once I install your rear chassis bridge. Have you shipped it out yet?
Old 06-05-2010, 09:11 PM   #4
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Not really the best method out there, but if you have no access to the press I found this method to be the easiest to remove the stock bushings...
Time to spray paint!
Old 06-05-2010, 09:11 PM   #5
Member#: 242368
Yes it shipped, I'm surprised you don't have it yet actually. PM Monday evening if you hadven't received it.
Also have the 2 piece Super Pro in the rear trailing arm position - relatively easy install, big improvement.
Old 06-05-2010, 09:15 PM   #6
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
I'm curious, why not Super Pro 2 piece bushings front and rear?
That seems like a much simpler solution.
Steve Nastoff is offline   Reply With Quote
Old 06-05-2010, 09:28 PM   #7
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
In fact, I bought Energy suspension bushings set (F+R) thinking it's 2 piece in design, but fount out that only rear bushings are 2 piece design.
Also, Energy suspension bushings are much cheaper...
Energy suspension front and rear bushings = $45 shipped.
Super pro front and rear bushings = ~$120 shipped
Old 06-05-2010, 09:43 PM   #8
Steve Nastoff
Member#: 52052
03 Subaru WRX
I went with the Super Pro front and rear and I am very happy, which is why I was curious about your choice.
I guess that you can't go wrong with either brand.
Old 06-05-2010, 09:48 PM   #9
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
I believe all Super pro bushings are made in Australia.
Old 06-05-2010, 11:58 PM   #10
punker39
Member#: 221065
2004 wrx
blue
I have front whiteline bushing on the way, dose this help with my down shift shudder i have? just wondering? ive pryed on the trailing arm and i can get the front bushing to move quite a bit but not the rear bushing so much. Should i get the rear bushing also? I know the front are shot.
punker39 is offline   Reply With Quote
Old 06-06-2010, 12:48 AM   #11
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Not sure if it would help with shudder you have, but keep us posted of results.
You should get the rear bushings as well since it only takes 20 min to install 2 piece bushings...
Is this what you ordered?
http://turninconcepts.com/product_in...oducts_id=1033
Old 06-06-2010, 07:39 PM   #12
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Car feels more responsive when turning with these bushings installed.
Next set of bushings I will be installing will be lateral link bushings, which seems to be the bushings that make the most amount of difference.
Old 04-02-2011, 12:33 AM   #13
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Method I used in #4 to remove stock bushing- anyone knows what the best way to remove stock bushing is from front control arm bushing mount?
Old 04-02-2011, 05:15 AM   #14
fastwrx25
Member#: 126441
03 bugeye
no idea, but what brand bushing you gonna go with this time?
fastwrx25 is offline   Reply With Quote
Old 04-02-2011, 11:01 AM   #15
chadr111
Member#: 37718
02 TS, (too Slow)
black
This is the only bushing I have not replaced. It has a metal sleeve too right? Does the bushing have voids in the rubber like the forward trailing arm?
I ask because instead of drilling the trailing arm bushing I was able to wiggle the blade of a hand held coping saw through one of the voids and re-assemble the saw. Then just cut the rubber along the inside diameter, dis-assemble the saw and remove. If there are no voids maybe drill one hole to get the blade through. Still had to cut the sleeve out with a reciprocating saw though. Short of a press I don't know what else to do.
Please update us with your results.
chadr111 is offline   Reply With Quote
Old 09-10-2014, 02:30 AM   #16
beaconhillkilla
Member#: 174710
1997 Outback
The $400 Special
I want to resurrect this thread from the dead in order to post a cheaper way to install the large bushing for those attempting to do this. I tried using a ball joint press (rental from OReilly), and when that failed to work I stumbled across this thread. What threw me off was the cost of the Harbor Freight bearing replacement kit so...I made my own.
Went down to Tacoma Screw and had the guy throw me something together. (it's a Northwest company that sells, among other things, lots and lots of screws) Its the same design as OP's, but the total cost was 7$ Also, there isn't any need to "pull" the metal sleeve for the new bushing through like OP did if you don't want to...just hit it with a mallet a few times and it'll go right in.
http://i.imgur.com/Tf3MEeJ.jpg
http://i.imgur.com/VqzyJE6.jpg
http://i.imgur.com/plRFZyu.jpg
http://i.imgur.com/jw596FS.jpg
http://i.imgur.com/tGVfwyN.jpg
The only issue is that since this bushing hangs out of the sides of the sleeve, the flat washer only works up to a certain point. To compensate for this in order to pull the bushing the rest of the way through I used one of the metal sleeves from the ball joint press kit I had borrowed from OReillys. If you don't have access to one of these kits, I'm sure you can jerry rig something to work. You're car competent enough to have gotten this far after all.
http://i.imgur.com/lDtkNvK.jpg
http://i.imgur.com/cJVHkR8.jpg
Dirty but functional.
beaconhillkilla is offline   Reply With Quote
Old 03-06-2015, 10:55 PM   #17
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
That's definitely functional. HF bearing kit wasn't too expensive. I think I paid around $80 back in 2010.
FS: MD STI lateral links, trailing arms, and Super Pro Trailing Arm Bushing boyracer_05 Suspension/Brakes/Handling 10 04-16-2010 12:46 PM
fs:new superpro front control arm bushings + front trailing arm bushings $35 shipped fastwrx25 Suspension/Brakes/Handling 8 11-19-2007 07:53 AM
NEW Superpro Trailing Arm Bushings (front bushings on the trailing arm, not the hub) fastwrx25 Suspension/Brakes/Handling 5 11-13-2007 02:40 PM
Trailing arm bushing orientation schnell Brakes, Steering & Suspension 1 02-07-2003 09:54 PM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 11:37 AM
