Welcome to the North American Subaru Impreza Owners Club Sunday September 24, 2017
Old 06-18-2010, 04:23 AM   #1
Cstmboxermotorsports
Member#: 103340
1992 RHD WRX
Default EJ20G overboost/fuel cut after Apexi intake
I installed an apexi intake on my 1992 WRX
Now I hit like 1.1 bar and the car is falling on its face. The most I ever hit pre intake was .9 bar (creeped to that)
Not sure why its doing it, if anyone could help that would be awesome
PS:
Car is stock except for 3" turbo back and the intake.
Cstmboxermotorsports is offline   Reply With Quote
Old 06-18-2010, 06:07 AM   #2
ncarn8
Member#: 71419
PS:
What turbo are you running? Have you douvle checked all your wastegate control lines are correct?
ncarn8 is offline   Reply With Quote
Old 06-18-2010, 09:28 AM   #3
Member#: 103340
1992 RHD WRX
16g, its stock. and yes
Old 06-23-2010, 10:37 AM   #4
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
I cannot give you a technical reason behind your issues, but it happens a lot on the G with the Apexi intake.
I think the MAF cannot handle it, on my old ride I went back to stock box, reset the ECU, and things were fine!!
DuoMaxwell is offline   Reply With Quote
Old 06-23-2010, 12:08 PM   #5
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
^^ Agreed too much flow prolly
sense of nature is offline   Reply With Quote
Old 07-07-2011, 08:11 PM   #6
250R
Member#: 118646
2004 Dubyaroxorz!
Would an AVCR solve something like this? Same issue here.
250R is offline   Reply With Quote
Old 07-08-2011, 01:44 AM   #7
pmugabi
Member#: 280926
Yes, a boost controller would fix this
pmugabi is offline   Reply With Quote
Old 07-14-2011, 09:01 AM   #8
luka
Member#: 194742
1993 Impreza WRX JDM
hey dude, you're hitting overboost fuel cut, you have a few options
1) use a resister (not sure what value(s) though)
2) use a silicon diode in-series with the signal wire. that will drop
the signal by 0.7V. any surplus store will have these
3) use a Zener diode around 4.7V along with the silicon diode and that
will prevent any fuel cut (dangerous in case you really do over boost)
4) Discount the MAP vac line entirely (won't throw codes)
5) get Rob's ECU Tune
I'd suggest 5) since you'll get a lot more than just no more fuel cut but if you're budget then 2). A diode is better than a resister since a resister's voltage drop will depend on the current while a silicon diode will always be 0.7V. I assume you want to install it with (+) side going towards the ECU and (-) going to the MAP sensor.
luka is offline   Reply With Quote
Old 07-15-2011, 09:01 AM   #9
watchthisspace
Member#: 273336
Firstly, reset your ECU, then go what everyone has suggested
watchthisspace is offline   Reply With Quote
Old 07-18-2011, 12:02 PM   #10
luka
Member#: 194742
Cstmboxermotorsports, any luck buddy?
Old 07-20-2011, 07:10 AM   #11
1995REX
Member#: 201655
2001 TT Legacy GT-B
You could use and HKS FCD (Fuel Cut Defender) they are out there and allow you to dial up how much you want to push past stock i had one before i went to Robs 550 Tune it did the trick for the few months i used it.
1995REX is offline   Reply With Quote
Fuel Cut After Motor Swap mtskibum16 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-27-2010 08:55 PM
Overboost + fuel cut after tune = Bad JdMS13 UTEC 8 05-06-2010 12:37 PM
ej20g hesitation/fuel cut problems grasshopper2.5rs Pre-2002 Factory Turbo Powertrain 33 12-23-2009 05:09 AM
Overboost fuel cut Zackbo Engine Management & Tuning 1 05-21-2004 11:45 AM
Fuel cut after right turns? WRXavier Warranty Issues & SOA Problems 5 04-16-2003 09:10 PM
