06-22-2010, 10:28 PM | #1 |
Member#: 83651
NESIC
Vehicle:08 Legacy Spec B DGM |
dropped off pistons to the machine shop/
okay so my block is being bored .20 and I gave them the pistons today. Do I need to tell them anything about the forged pistons etc ? Not that I would know squat but am okay sharing information.
06-22-2010, 10:37 PM | #2 |
Member#: 149114
make sure you gave them the spec sheet that was given with your pistons. I also hope you dropped it off at a machine shop that is familiar with subarus.. boring and honing a subaru case (emphasize on case) is much different from an Inline or V style motor... cases need to be bolted together, torque plates need to be torqued to spec, etc.. if this is not done, true clearances cannot be guaranteed.
06-22-2010, 10:51 PM | #3 |
Member#: 83651
NESIC
okay cool....that was in there....they are familiar with subarus. how many hours are required to complete a short block build
06-22-2010, 10:52 PM | #4 | |
Member#: 149114
It ranges shop to shop, obviously you do not want a rushed job and at the same time you do not want it to take months. |
06-22-2010, 10:57 PM | #5 |
Member#: 83651
NESIC
I will be able to run the OEM headgaskets right?
06-22-2010, 10:58 PM | #6 |
Member#: 149114
Yup. OEM all the way.
06-24-2010, 01:40 AM | #7 |
Member#: 249522
International
Vehicle:2005 Impreza wrx STI obp |
make sure you decide on your piston to wall clearance depending on your boost levels and power goals.
06-24-2010, 12:48 PM | #8 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
this^
if you dont plan on going huge tell them you want the lowest ptw clearance recommended by the manufacturer. |
06-24-2010, 01:02 PM | #9 |
Member#: 246586
Vehicle:2002 WRX Black |
what about like 400 whp? what is the PWC you wanna run?
06-24-2010, 01:40 PM | #10 |
Member#: 83651
NESIC
so all this will be on the piston spec sheet right?
More motors off to the machine shop :) | reddevil | Built Motor Discussion | 2 | 04-15-2008 11:46 PM |
Got my rotating assembly back from the machine shop! | Splinter | Vancouver Impreza Club Forum -- VIC | 53 | 07-07-2007 06:32 PM |
While I've still got time in the machine shop... camber plates | Really_Soaked | Brakes, Steering & Suspension | 1 | 10-07-2005 12:13 AM |
Back from the machine shop! | Wedge | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 12-01-2003 10:33 PM |
Accident!!Do I need to take the turbo off before taking the car to the repair shop? | Andrew | Bay Area Impreza Club Forum -- BAIC | 37 | 08-01-2001 05:20 PM |
