Welcome to the North American Subaru Impreza Owners Club Sunday August 20, 2017
Old 06-28-2010, 06:34 PM   #1
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
OMGHi2U What is the best toilet guts you can buy?
My house has 3 toilets. I replaced all the guts when I got the house and since the 7ish years I've owned it I've done so time and time again. Does OT know who makes the best toilet guts??? The keywords I'm looking for with posters are:
Haute Couture
Dyson of Toilet Guts
Terribly Expensive
Give-it-hell
When nuclear war happens there will be cockroaches and your toilet guts left over
Pic is related:
Old 06-28-2010, 06:38 PM   #2
Whitford
Has never had a cavity
Member#: 97875
2017 VW GTI Sport
All I know is that the money spent on a heated Japanese toilet seat is well ****ing worth it.
Whitford is offline   Reply With Quote
Old 06-28-2010, 06:39 PM   #3
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
Get one of those self-pressurizing rocket flusher that you can retrofit in there. They force your poop into the next town over.
Kiel is offline   Reply With Quote
Old 06-28-2010, 06:39 PM   #4
teiva-boy
Member#: 22825
I have to admit, I was thinking this, this very morning as I was taking a poop.
I think the last kit I bought, cost about $7-$10 from home depot. They only seem to last me 3-5 yrs. During that time, the flapper gets nasty and slimy. Or the handle arm breaks, and the handle... wow is that cheap.
Perhaps a new fancy toilet is the answer?
teiva-boy is offline   Reply With Quote
Old 06-28-2010, 06:42 PM   #5
Silverdc
Member#: 132230
03 Sedona Variety
10.85 @ 129mph
American Standard makes a $40 kit that is all stainless steel besides the float.
Silverdc is offline   Reply With Quote
Old 06-28-2010, 06:42 PM   #6
Brad Pittiful
Member#: 34931
. Trump could use
the money!
you better get a new tank...that one is half missing
Brad Pittiful is offline   Reply With Quote
Old 06-28-2010, 06:45 PM   #7
Full_Clip
Member#: 22218
Basically the only thing that fails is the flapper. Buy one of these when the flapper fails and you install it correctly, the toilet should be trouble free for many ****s.
http://www.lower-my-energybill.com/i...ps-running.jpg
chris619
dr_wheel
Full_Clip hasn't had a leaky toilet let.
Full_Clip is offline   Reply With Quote
Old 06-28-2010, 06:52 PM   #8
rogue
Alt-Mod
Super Moderator
Member#: 7977
100% Abuse
This is relevant to my interests.
I've done the same thing as Ron. Replace, replace, replace.
Flappers failed, but also the fill valves... even the replacement units!
rogue is offline   Reply With Quote
Old 06-28-2010, 06:55 PM   #9
Brad Pittiful
Member#: 34931
. Trump could use
the money!
dump and pee at work...than you wont have to replace worn out parts
Old 06-28-2010, 06:57 PM   #10
rogue
Alt-Mod
Super Moderator
Member#: 7977
100% Abuse
Actually the one that's failed a second time is in the guest room and is rarely used.
Old 06-28-2010, 07:10 PM   #11
jds
Member#: 7991
http://www.americanstandard-us.com/i...ons/bestflush/
Not only do they flush a lot of crap (er... whatever), but they also have a ten year warranty, including internal parts.
Expensive? Check. Plan on $300+, compared to about half of that for whatever's on sale at Lowe's/HD.
jds is offline   Reply With Quote
Old 06-28-2010, 07:12 PM   #12
kage
Member#: 25101
Chapter/Region: HIIC
2002 PSM WRX Wagon
1999 Twilight Blue Miata
We have seven toilets, and I've replaced something on all seven. I've found the best fill valve is by Korky. It doesn't have the sliding piece, which is the bit that tends to break. It just has a rectangular block at the top that has an internal float valve. I've put them in four of the seven toilets, dating back to 2006, and haven't had a single problem. As for the flapper, I've been using Korky there too, but next time I might retrofit one of those hippie two stage toilet kits, because it replaces the flapper with something more akin to a plug, and the lever with two buttons. I've seen them for about $20 on Amazon. I might buy one for my next toilet repair.
Edit: http://www.korky.com/FillValve528.html
kage is offline   Reply With Quote
Old 06-28-2010, 07:13 PM   #13
Brad Pittiful
Member#: 34931
. Trump could use
the money!
did you move the guts from the one that gets used all the time to the guest room one
Old 06-28-2010, 07:16 PM   #14
rogue
Alt-Mod
Super Moderator
Member#: 7977
100% Abuse
No. Brand new guts from Home Depot.
Old 06-28-2010, 07:17 PM   #15
WC LATHE WERKS
Member#: 175549
2007 Forester STi
www.LatheWerks.com
I sat on a toilet in Tokyo that had more computing power than my PC. I could not read anything so I commanded a bunch of strange noises, but it self-warmed and douched and did some other stuff I didn't intend.
Japan holds about 50% of the population of the USA on about 4% of the land mass. They don't have the room for waste, so their products tend to last and work every time. Try to source some JDM toilet parts if you can.
WC LATHE WERKS is offline   Reply With Quote
Old 06-28-2010, 07:24 PM   #16
scoobysport
Member#: 1671
'16 WRX Sport
scoobysport is offline   Reply With Quote
Old 06-29-2010, 04:51 AM   #17
NicGordon
Member#: 24827
2008 Kia Spectra
NicGordon is offline   Reply With Quote
Old 06-29-2010, 06:56 AM   #18
mikeythejew
Member#: 141672
They do make a lifetime toilet fill valve.
It's a 5 gallon bucket. Other than that, get a Korky fill valve. .
mikeythejew is offline   Reply With Quote
Old 06-29-2010, 07:07 AM   #19
chapstien
Member#: 68284
1988 Corolla SR5
0-points
I want one of those. It's a bladder or something. Haven't found a kit yet.
Read more. Sloan Flushmate. And the sloan valve company is the best. Look down in any nice bathrool. What do you see a Regal. Possible a Royal.
chapstien is offline   Reply With Quote
Old 06-29-2010, 07:15 AM   #20
KC
Member#: 442
17 OK Sport
00 S2000
Let what? (looks at keyboard... L key and Y key are hardly adjacent)
I have 2 toilets in my house, living here for 11 years, and haven't had to replace anything in the toilets, except a leaking donut gasket on one (but that's under the toilet itself).
--kC
KC is offline   Reply With Quote
Old 06-29-2010, 08:04 AM   #21
KC
Member#: 442
17 OK Sport
00 S2000
Maybe just buy a new toilet?
http://reviews.homedepot.com/1999/211385095/profile.htm
(Be sure to read the review)
--KC
Old 06-29-2010, 08:14 AM   #22
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
I just added a half bath, remodeled another and replaced my master toilet. All three now have pressure assist toilets. They can be loud at times and they scare my guests sometimes but they will flush anything. Will have to see how long they last though.
2k2 is offline   Reply With Quote
Old 06-29-2010, 08:15 AM   #23
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
--KC
5 Fantastic Stars!
Old 06-29-2010, 08:18 AM   #24
peglegsteve
Member#: 209987
2009 Slow WRX
Slower Prius
Water closet.
You should find a way to connect an industrial shop vac to the toilet.
peglegsteve is offline   Reply With Quote
Old 06-29-2010, 08:25 AM   #25
teh POD
Member#: 90195
Originally Posted by scoobysport View Post
BAWOOSH!
teh POD is offline   Reply With Quote
Besides sex, what is the best physical sensation you have ever experienced? perret318 Off-Topic 303 07-17-2010 03:38 AM
on an '08 sti, what is the best FIT rim i can get on 265/ 35ZR/18 tires ? m_pun Tire & Wheel 7 06-03-2010 01:06 AM
What are THE BEST chassis mods you can do? g3ninfinite Brakes, Steering & Suspension 17 11-15-2007 12:23 PM
What is the best size rim that can make your rim flush with the fender? Stanley Park Rex Vancouver Impreza Club Forum -- VIC 12 04-06-2007 02:58 PM
What is the cheapest new car money can buy? ScoobyNubieToo! Off-Topic 43 08-20-2006 11:10 PM
