Welcome to the North American Subaru Impreza Owners Club Saturday May 26, 2018
Old 06-16-2002, 12:58 AM   #1
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Default For those with Cobb or Ganzflow CAI..
Today I plugged the fender hole in front of the intake and seemed to have a reduction in power? I was thinking that just having cold air would be helpful but it seems to strangle the intake. I have removed the little orange thing underneath the passenger side turn signal and left it open. Has anyone got any numbers behind this?
Poppa smurf is offline   Reply With Quote
Old 06-16-2002, 02:51 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
I made note in my GanzFlow instructions that you need the air to flow from inside the fender into the engine bay to pull more cool air into the fender from outside, and when you plug the holes in the fender going into the engine bay you can reduce flow of fresh air into the fender from the outside.
ImprezaRS dot com is offline   Reply With Quote
Old 06-17-2002, 01:06 PM   #3
kickin_81
Member#: 16679
2004 Forester XT
Did you just plug up the big hole or all the little holes along with the big one? I also run a Ganzflow with the big hole plugged with racers tape, because I read that if the big hole is left open it will allow warm engine bay air to enter the fender. Of course, it'd be minimized if you took off your two air vent scoop plates and hood scoop plate.
kickin_81 is offline   Reply With Quote
Old 06-17-2002, 01:41 PM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
You should be able to plug just the big hole, just not all the little holes that assist airflow.
Old 06-17-2002, 02:13 PM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I've got the stock plastic plug in the front hole with my Cobb and it seems to run just fine, no stangulation at all.
CosmoTheCat is offline   Reply With Quote
Old 06-17-2002, 02:31 PM   #6
Silverscooby27
Member#: 9124
2014 335i xDrive
Originally posted by horatio102
I've got the stock plastic plug in the front hole with my Ganzflow and it seems to run just fine, no stangulation at all.
Ditto. (almost)
Silverscooby27 is offline   Reply With Quote
Old 06-17-2002, 07:44 PM   #7
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I have a previous gen GanzFlow, that uses the rear hole, and just left the stock plug in the font hole. Doesn't seem to cause any strangualtion, either, but I've never tried it with the plug removed. Kinda curious now, might do that and see if I notice a diference.
HondaH8er is offline   Reply With Quote
Old 06-18-2002, 08:54 AM   #8
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Default Re: For those with Cobb or Ganzflow CAI..
Okay, this is kinda strange...
I have a 99, so I never had that plug to begin with. I put the intake on in August, then someone had an extra plug, so they gave it to me (in October). I put I on and felt like I lost power, but thought it must be due to faulty butt dyno...
I guess I should take it off after all this time and see if I am speedier...
DanzBorin is offline   Reply With Quote
Old 07-03-2002, 08:57 PM   #9
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
So has anyone tried it with the hole uncovered? Or what about taking out the passager side turn signal? I think larry Ganz had that for his RS-T with a dryer vent IIRC
Old 07-05-2002, 11:57 AM   #10
Puckaveli
Member#: 1518
00 2.5RS
I have ran obd-2 tests with the fender open and closed and with the bumper vent in and out and the intake still pulls in the same amount of air and the temps were +- 3 degrees.
Puckaveli is offline   Reply With Quote
Old 07-07-2002, 02:15 AM   #11
BrianX
Member#: 1923
2000 2.5RS
BRP
I installed a cobb intake 2 weeks ago. I have a MY00, so my front fender hole was plugged. It seemed to really loose power or flatten out @ 5k with the hole plugged.
I unplugged the hole and it seemed to be a better, but I didn't do a full ECU reset to really make it think about it.
The flatness could be timing getting turned back because the cobb is soooooooo loud though.
BrianX is offline   Reply With Quote
An easy fix for those with erratic or flicking EGT gauges. B16A2NR Electrical & Lighting 0 01-27-2008 01:33 PM
For those with wives or SOs. Capt Crunch Off-Topic 28 01-21-2008 08:57 AM
Question for those with COBB Stage 2 Danbob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-30-2005 10:51 PM
For those with Tivo or..... MikalsWRX Off-Topic 9 11-09-2004 01:39 PM
For those with Cobb 2.5? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2004 01:49 AM
