Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 07-24-2010, 05:23 AM   #1
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Default ProRack Whisp Bar Custom Install with Pics 02-07 Impreza
Take off old rack and clean area to be worked on, I left mine a little dirty as I had 3m protecting my car from the old rack.
The Clips just slide I used a clip puller screw driver to slide it forward or back as one side it's the opposite.
Just a 13/64 drill bit drill at a 90 degree angle to car then use a M6 x 1.o tap, its soft metal so push hard to start the tap.
The bit can be used to drill the weather stip as well make sure to drill up wards so you don't damage the car.
dasnowman is offline   Reply With Quote
Old 07-24-2010, 05:25 AM   #2
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Wow didn't expect that the stock bolts that come with the roof mount kit were too freakin short, had to redo a few steps, 60mm are to long 45-50mm would have been better.
I also put a 10mm nut on the Grubscrew to make it more solid and from backing off.... thread lock would work too as the nut pushs up a little on the weather strip.
Old 07-24-2010, 11:57 AM   #3
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
nice!
100_Percent_Juice is offline   Reply With Quote
Old 07-24-2010, 01:02 PM   #4
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
that is an awesome write up... ive been wantin to do this for awhile.... wrx = sexy with roof rack
white guys wrx is offline   Reply With Quote
Old 07-25-2010, 04:15 AM   #5
lovin' it
Member#: 236710
2010 WRX Five Door
WRB!
Excellent!
lovin' it is offline   Reply With Quote
Old 07-26-2010, 12:29 AM   #6
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Thanks Guys.
Old 07-31-2010, 03:41 AM   #7
stiguy86
Member#: 230632
2006 Forester XT
got any pics of the inside of the feet? where the grub screw goes through, and what kit did you end up using (size)?
stiguy86 is offline   Reply With Quote
Old 08-11-2010, 03:09 AM   #8
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
I modified the roof mount kit so a red wing knob holds on the base rack.
Old 08-11-2010, 05:00 AM   #9
stiguy86
Member#: 230632
2006 Forester XT
got it. nice thinkin'
good job on the install... i would consider picking up some body plugs to cover the holes in the weather stripping if you decide to take the studs out... it'd look alot better imo.
nice write up though, give me enough confidence to do it now!
Old 08-11-2010, 08:42 AM   #10
waynlewis
Member#: 219948
07 Sti
I want your garage
waynlewis is offline   Reply With Quote
Old 09-28-2010, 06:15 PM   #11
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Yes body plugs are a good idea when rack is off, but keep in mind I would reccomend using a nut on the grub screw as it feels a lot more solid with it, and you would have to take the trim off to get at it.
Ya no problem post some pictures up here when you get it done and on.
Originally Posted by waynlewis View Post
I want your garage
Me TOO that is at my work's garage, my garage at home is ok but I still find myself doing work on my car at work after work.
I thought I would bump this up as the ski/board season is coming and some people may have not sceen this option.
Old 09-29-2010, 12:45 AM   #12
stiguy86
Member#: 230632
2006 Forester XT
my new STi ended up falling through, i bought a ZR-2 instead.. (i needed more off-road :P ) i still might do somthing similar on my cap..since i do still have all the STi hardware... we'll see..... ill probably just install tracks on it.
Old 10-18-2010, 12:05 PM   #13
vinncent_25
Member#: 48355
2004 STi
i completed my install of the whispbar this weekend.
it wasn't said on here, but the rack show is the s16 whispbar with the roofmount kit 323.
the only thing i'd have to add is to drill very close to the inside of the weather strip. i drilled closer to the middle and had to do more cutting to get the hole to line up. otherwise, the install is pretty painless. if you keep everything organized and measure twice it shouldn't take more than an hour.
vinncent_25 is offline   Reply With Quote
Old 11-04-2010, 06:56 PM   #14
JPM Coachworks
Member#: 190108
2008 WRX STI
LR
I love this setup. Was thinking of going Yakima (http://forums.nasioc.com/forums/show...1851555&page=2) but I think Im hooked on these. This video is great http://www.whispbar.com/hearthedifference
JPM Coachworks is offline   Reply With Quote
Old 12-02-2010, 02:30 PM   #15
visibiliti
Member#: 211987
2004 STi
I am pretty new to the whole roof rack thing, but I have read up on the original q-clip custom mount thread, the new revised setup 2nd gen thread, and this thread. I have the following question about roof racks:
What is the purpose for getting pass-thru tower racks instead of flush? If I get the flush whispbar base rack, will I be able to put the attachment on that holds 4 snowboards? It is still wide enough right? What is the point of the pass thru and it extending just a few inches on each side above your door?
Thanks guys!
visibiliti is offline   Reply With Quote
Old 01-19-2011, 04:26 AM   #16
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Thanks guys!
Should pm instead of posting but the through bar gives you more room to put stuff... I had two bikes plus a Thule Spirit box on so needed the extra length... Also I like the look of the through bar better looks more like a wing vs a roof rack but some like or think the flush mount is cleaner.
Old 01-19-2011, 10:47 PM   #17
Sideways_STi
Member#: 258679
2008 STi Hatch
Lightning Red
good form! am thinking of doing this to the girlfriends 2.5i
Sideways_STi is offline   Reply With Quote
Old 03-12-2011, 02:01 PM   #18
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Hi everyone this set up is a Whispbar S16 with Fitting Kit 323 Permanent Mount and like I mentioned before 60mm grub screws are required as well. All this stuff should be stocked at Rack Attack.com
Old 03-12-2011, 02:02 PM   #19
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
sweet thanks for the reply my good man
cueballsi is offline   Reply With Quote
Old 03-12-2011, 02:08 PM   #20
cueballsi
Member#: 202736
1992 Civic VX 40MPG
Ordered all my stuff from rackattack.com .... waiting for the man in brown.....
Old 03-12-2011, 04:13 PM   #21
cueballsi
Member#: 202736
1992 Civic VX 40MPG
Old 03-17-2011, 02:43 AM   #22
cueballsi
Member#: 202736
1992 Civic VX 40MPG
drilled and tapped brackets... waiting for rack
Old 03-18-2011, 08:17 PM   #23
cueballsi
Member#: 202736
1992 Civic VX 40MPG
Default thanks again
INSTALLED! Used 50mm Grab screws, or set screws. Used Stainless JAM nuts too, thinner than the regular nuts, didn't push up the gutter as much.
www.mcmaster.com
M6 x1.0 X 50mm 92015A560 http://www.mcmaster.com/#catalog/117/3062/=bhq924
M6 x1.0 JAM nut 93935A335
I found this stuff at a local specialty fastener shop but these are some suggestions
Also used this to remove the gutter... MONEY! http://www.harborfreight.com/5-piece...set-67021.html
Old 09-29-2011, 05:18 PM   #24
acroflyer
Member#: 295713
07 Impreza
Grey
Awesome job on the racks guys! I am thinking of doing this on my 07 Impreza, but I want to use the the Whispbar Flush Bar... Any idea which size I should order?? or where exactly to measure? Thanks
acroflyer is offline   Reply With Quote
Old 11-05-2011, 08:00 PM   #25
rumorco
Member#: 299007
2005 Subaru WRX STI
Alpine White
Default Yakima FatCat
Originally Posted by cueballsi View Post
Will the fatcat fit on this?
rumorco is offline   Reply With Quote
FS: (CO) Custom fit sun shade for 02-07 Impreza cleatis Interior/Dressup/Audio & Security 1 07-27-2009 11:33 PM
Custom-made KartBoy shifter w/linkage for 02-07 Impreza 5MT 4URABUS SCIC Private Classifieds 3 10-12-2008 08:59 PM
AZP Installs Staged Security Installs for 02-07 Imprezas/Foresters AZP Installs Interior/Dressup/Audio & Security 8 09-09-2008 08:41 PM
harness bar 02-07 imprezas subaru3169 Suspension/Brakes/Handling 12 03-18-2008 11:22 PM
Cusco carbon fiber rear strut bar 02-07 Impreza Subaruist Suspension/Brakes/Handling 17 01-15-2007 06:38 PM
