08-02-2010, 07:03 PM | #1 |
Member#: 180640
E. Canada
Vehicle:2000 Drag RSTi 8.96 @ 163 |
282 NON-AVCS Cams (who sells them?)
Been looking for some cams for my build.
Looking for some 282 cams in particular. Been looking around on Kelford, GSC and BC's websites but can't seem to find the 282 in non-avcs that would fit a ej257. Anyone have any idea who makes them? Thanks -Ben
08-02-2010, 07:34 PM | #2 |
Member#: 33458
Vehicle:Your BOV sounds lame 93 RX7+09 Forester |
Kelford makes 2 difference 282* NON-AVCS cams.
Look up the: 199-G, and 199-L |
08-02-2010, 09:56 PM | #3 |
Member#: 180640
E. Canada
I was looking at those earlier. But would ej20 cams fit in a ej257?
08-02-2010, 10:24 PM | #4 |
Member#: 71875
BC sells the same cams for both applications. You just take the set screws out of the oil passages if you want to use avcs.
08-02-2010, 10:35 PM | #5 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
there is no comparing bc cams with kelford,Kelford cams are waayy better.
08-03-2010, 12:29 AM | #6 | |
Member#: 33458
As for the original question, the EJ20 and EJ25 cams are going to have a different lobe separation angle designed for the time spent at TDC of the specific crank being used. I use a 75mm crank (EJ20) and thus picked a cam designed for an EJ20. If you are using a 79mm crank (EJ25) you are going to need to talk to a tuner/nerd who can tell you whether or not using a different LSA is going to be an issue. You could always buy an AVCS cam and have a machine shop tap and plug the AVCS holes. This would be pretty easy for any shop. (You can DIY also, but I personally wouldn't go into my garage and drill holes in a NEW $1000 cam set) |
08-04-2010, 01:02 PM | #7 | |
Member#: 52631
Vehicle:2004 WRX WRB |
If you decide to run non-AVCS cams in AVCS heads you will need a cosworth cam position sensor bracket and you will use non-AVCS cam seals. |
08-04-2010, 06:03 PM | #8 | |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
The cam centerline is the same for the exhaust cams whether they are 257 or 205 specific, the centerline for the 257 intake cam is variable due to AVCS and usually 113 for most of the 199 series Kelford cams. The only difference really in specs between the 205 and 257 variety would be the AVCS option. Whether they are 205 heads or 257 heads they can be fitted with either cam and made to work. EDIT: this is for single AVCS 257 cams ^^^ |
08-04-2010, 07:14 PM | #9 |
Member#: 180640
E. Canada
Thats what i thought. I have seen a lot of people puting ej257 cams into an ej20 head without any problems except for having to tap another hold for the cam gear to fit correctly.
It would think that using ej20 cams in a 257 would work with minor modification as well. Kelford 282 EJ20 non avcs cams are in stock. But the 282 EJ257 AVCS cams are not in stock until september 20th. Just want to know if i would get the same result with eitherwrx or sti camshafts if in not running avcs in my ej257. On the fence about which of these Kelford cams to go with: Can someone explain the difference between the two besides each having a different lift. http://www.camshaftshop.com/home?pag...category_id=64 http://www.camshaftshop.com/home?pag...category_id=64 Last edited by mtcs; 08-04-2010 at 07:23 PM. |
08-04-2010, 07:39 PM | #10 |
Member#: 77470
the L cams are a little more aggressive and have more lift and need cyl. head modifying due to the size of the lobes.The g cams are a drop in and will net close to the power potential of the L cams but without all the added machining expense.The L cams will be a little harder to dial in the idle on due to the aggressive ramp and duration.
08-04-2010, 07:53 PM | #11 | |
Member#: 180640
E. Canada
08-04-2010, 09:14 PM | #12 |
Member#: 32669
SCIC
Kelford makes more that one 272 cam. 272 is just an "advertised" duration and has nothing to do with the many other cam specs so not all "272s" are equal.
08-04-2010, 09:26 PM | #13 |
Member#: 77470
^^^^exactly what is the true tell off the aggresiveness of the ramp is what the duration is at .050,this tells you how fast the valve is actually being opened.And yes with the smaller lift of the g's they should just drop in with no clearancing.
NON AVCS cams and EJ257 heads ADJ cam sprockets | saintluciascooby | Built Motor Discussion | 12 | 01-23-2012 09:12 PM |
F/S Cosworth 275/275 wrx non avcs cams | evokillerchris | Engine/Power/Exhaust | 4 | 04-15-2009 08:41 AM |
Possible to get STi ECU to pick up non-avcs cam signal? | LeeC | Engine Management & Tuning | 1 | 07-07-2008 10:10 AM |
Non-AVCS Cams in STI Heads | SloRice | Built Motor Discussion | 3 | 10-07-2006 03:18 PM |
Headers/Exhaust/Cams who has them and dyno'd them | Silky | Normally Aspirated Powertrain | 14 | 04-13-2001 09:07 AM |
