Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 08-07-2010, 12:22 AM   #1
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Default Liquidsk8s JDM STi Bugeye journal.
I decided to make a new thread detailing my Bugeyes history..... a long road full of both win and fail. All work has been done by myself.... many long frustrating nights but completely worth it.
Here are the cars current specs and a few photos for the moment. This isn't the end result yet either as I have a good amount of work that I plan to do over the next year. The photos/specs will be updated as I progress with the build.
This is how it sits right now.
UPDATES:
8/13/10 ACPT CF driveshaft!
9/13/10 CF engine pieces and DYNO test run!
10/31/10 Titanium heat shield!
2/23/11P&P throttle body, phenolic spacers etc!
5/09/11 S204 strut dampers!
5/19/11 Removal of subframe, new trailing arms!
7/20/11 Blouch 2.5XTR-TS turbo, AMR inlet, EBCS!
7/29/11 DW 1300's and Prova CF intake snorkel!
8/02/11 JDM STi Titanium strut bar!
11/01/11 More engine parts!
11/03/11 NEW WHEELS!
10/16/12 New Parts and Aerosim CF roof!
8/13/13 Installed Carbon roof and other goodies!
8/29/13 STi S204 Carbon Seats!!
11/08/13 STi S203 Titanium Exhaust!!
4/10/14 New parts, Koyo rad etc
4/10/14 Installing new parts, nearly done!
CURRENT SPECS:
Engine/drivetrain:
05 JDM STi v.8 EJ207 longblock
Full JDM STi chassis harness from front to rear of car converted to LHD
Blouch 1.5XTR-TS 56.5mm Turbine, 71mm wheel 49lb, Ball Bearing Garrett CHRA
Process West TMIC
Hayward & Scott JDM downpipe
Custom midpipe
STi S203 Titanium catback exhaust
JDM STi 6spd
R180
APS 70mm CAI
AMR aluminum turbo inlet
KOYO Aluminium Radiator (converted to new style)
STi radiator hoses
DW300 Fuel Pump
ID1000 Injectors PNP
STi Intercooler spray system (included in stock wiring)
MOROSO dual catch can setup
Grimmspeed 8mm phenolic spacers
Grimmspeed EBCS
Grimmspeed MBC
Grimmspeed P&P Throttle Body
COBB MAF Hose
Coolant Tank Insulators
Killer B Oil Pickup Tube and Baffle
Litespeed titanium heat shield for turbo, with DEI gold wrap on inside
Omni 3 Bar MAP sensor
Grimmspeed Oil Cap
NRG Carbon Fiber hood struts
Exedy stage 1 HD clutch (470lbs tq atw)
Exedy 13lb flywheel
Cusco engine/tranny mounts
TIC tranny crossmember bushings
Goodridge steel braided clutch line
Beatrush Forged pitch mount
ATI Harmonic Damper Pulley
DEI Titanium wrapped Headers/Up/Downpipe
Perrin Uppipe Blanket
Perrin Downpipe Blanket
DEI Titanium Turbo Blanket
Dressupbolts titanium engine bolts (purple)
LNR Carbon Fiber Alternator cover
Prova Carbon Fiber Ram Air Intake Duct
APR Carbon Fiber Radiator Shroud
Carbon Fiber intake shield/box
Shorai 4.9lb Lithium Iron Battery
Brakes/suspension/wheels
RCE T2 400/350 13.5"F/R ride height, -2.5 front camber 1/8th toe out, -1.5 rear camber 0 toe 5 degrees castor.
RCE Lowering front camber plates
GTWorx rear camber plates
RCE front/rear swaybar kit 25.5/28.5 Front, 25.5/27/28.5 rear
Prodrive GC-010E 18x8 5x114.s +43
STi caster adding control arms with whiteline inner bushing
Brembo GT front brake kit
STi rear brembos
JDM S204 f/r strut dampers
JDM STi "pink" pillowball trailing arms
Forester STi aluminum lateral links with pillowball mounts
Whiteline ALK (race)
Grimmspeed MC brace
Stoptech front rotors
Girodisc rear rotors
Hawk pads
Titanium brake shims (front and rear)
SS brake lines
Q-Rack Steering Rack 11.5-1
Kartboy endlinks
Kartboy swaybar spacers
TIC Fender Cowl Braces
TIC Every bushing they make
Whiteline Roll Center Adjusters
RAYS 50mm Lug Nuts Blue
Interior
S204 Carbon Fiber seats (alcantara + leather)
S204 rear seats (alcantara + leather)
05 JDM STi Steering Wheel
JDM STi v.8 guage cluster (260kmh)
Defi BF in amber (boost, oil temp/pressure) plus control unit
05 STi center console with full HVAC setup (plasti dip black)
JDM STi titanium shift knob (not the piston looking one)
Blacked out interior (Alcantara headliner, carpet, floor mats, pillars)
Black leather door cards
STi chrome door handles
Boston Acoustic RC620 6.5" component fronts (powered by the amp)
Boston Acoustic RX47 4" rear door speakers
Alpine ILX-007
JL XD500/3v2 500W amp
JL 10W3v3-2 10" Sub
JL rbc-1(remote level control)
Alpine Rear back up camera
Hands Free phone setup
Interior/trunk LED lights
Red LED conversion for 05 dash
Black S204 HVAC dials
08 WRX USB/AUX media console box (custom fit)
Brownbread sound deadening and closed cell foam throughout car
Exterior
JDM STi black HID's
JDM STi grille
Prodrive front lip with S204 lip under it
22B wing replica
JDM STi hoodscoop
Aerosim carbon fiber roof
Carbon fiber rear trunk, painted WRB
STi fog covers
JDM STi Transmission aero panel
05 STi rear bumper with OEM fender flares
PIAA Silicone wiper blades (drivers is the Forza)
PIAA Horns
HKS Kansai CF rear diffuser
WRX painted side skirts
HTAutos PU side skirt extensions
Official weight:
2903lbs with 1/4 tank of fuel and no rear wing/subwoofer. Also no water in the intercooler spray tank. 3130lbs with driver and wing/sub/full intercooler spray.
Estimated HP:
With the old VF37 (converted to PE1825) I did a dyno test to figure out issues. The car made just shy of 300whp BUT was very slow to spool and had high MAF temps which together created a lack of TQ/HP. This test was on 93 octane at sea level and I had 1 CAT.
Performance:
The last time I did the 1/4 mile it had the VF37 with exhaust/intake/intercooler on the stock ROM and 93 octane (not smart), and weighed around 3400lbs. It did low 13's @ 110.5mph with traction issues.
Since then we have dropped almost 500lbs and probably added 150whp. I'm not big on the drag strip, but my guess would be mid to high 11's at 120mph +/- 2mph. Which seams reasonable considering a nearly identical setup is running low 12's at 117mph but weighing near stock. It's bench racing at it's finest lol.
New mods since the last dyno run:
ACPT CF driveshaft
Lighter wheels/tires
P&P throttle body and phenolic spacers
Removed bottleneck in exhaust
PW TMIC with proper shroud and DEI gold heat tape
DEI turbo blanket, header/up/downpipe wrapped
ID1000's and E85
Blouch 2.5XT-R-TS (Old version, equal to the 1.5XT-R-TS)
APS CAI (with DEI intake cool cover)
AMR turbo inlet
Exedy flywheel/clutch
Lost 80+ lbs of rotational weight.
With these new mods I expect to make around 380-400whp on E85. I also expect really quick spool for a 2.0.
And now for the history of the car.
Here was my first experience with a WRX back at an auto show
I purchased the car back in 2005 with a lot of work already done to it. It had the front brakes, different suspension (DMS), the OEM body kit, rear wing, leather etc. The car was still running the stock WRX engine/tranny but with a larger intercooler/intake/TXS RFL/VF22/MRT exhaust/Morretes. The owner claimed 280whp...... but I highly doubt that now. Here are some pics from the owner I purchased it from.
As you can see...... it's come a LONG way since then.
LIQUIDSK8S is offline   Reply With Quote
Old 08-07-2010, 12:24 AM   #2
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I drove this setup for 4 months before hitting the first bit of fail. I let a friend drive it (me in car) to show me how he launches it....... 1st gear fine....2nd gear BOOM. After a couple weeks of reading I decided to go with a set of gears from gimmiegears (I don't think their around anymore). This worked great for another couple months until the EJ205 let go with a cracked ringland. The car was on the tune from the prior owner, who had blown the motor and had it replaced before selling it to me. In hindsight I should have gone for a new tune. What to do next?
After another couple months of searching/saving/thinking I grabbed a full v.8 drivetrain and had a shop install all of it. This was a HUGE improvement over the 205 with the VF22.
Old 08-07-2010, 12:25 AM   #3
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Old 08-07-2010, 12:25 AM   #4
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
This setup lasted a little over a year until a ringland cracked....... I made the mistake of not having the car tuned for 93 octane.... my stupidity in believing a few people who said I didn't need to. This time I decided to go a different route by doing a hybrid swap. I had a new 257 sent to a reputable builder who put in a set of Mahle pistons and a micro polished/drilled crank to match my JDM heads.
Just my luck....... fedex dropped this block in shipping and we assumed it would be ok.... we were wrong. Within 1k miles the crank seized solid. These were 1k break in miles with no boost. The block was checked and they found micro cracks in the block from when it was dropped. After this fiasco I was strapped for cash and needed a cheap option...... the shop had a slightly used 257 which I got for cheap........and my luck keeps getting better...... low psi in one cylinder right away.
Old 08-07-2010, 12:27 AM   #5
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
At this point I came extremely close to parting out the car and moving on. Most sane people would have thrown in the towel by now. I decided to give it one final chance. I found another full v.8 drivetrain for a great price that I couldn't ignore. Thanks to nasioc I was able to part out the old drivetrain and completely cover the cost of this new one. For this swap though, I decided to do all of the work myself as it came with the full wiring harness....... I entered a new level of crazy. This process took a lot longer than expected...... due to wires missing (had to order from the japanese dealer through rallispec) and not having the time due to work.
I finally got the wiring finished....... only to find out one of my morettes were stolen from the back of my shop . Couple weeks later I fell into a new job in NYC which left 0 time for working on the car which is in FL . This was last fall. After a ridiculous wait I finally came accross a set of JDM HID's and a front grille and was able to finish the car
Took the car out for a quick spin and it is GREAT! It looks like the shop who did my AVCS wiring sucks at life though....... as it is clearly working now and it's like the car has come alive. It needs a tune though, so I haven't had a chance to push it, that will be later this month when I'm back in FL..... then comes the collection of parts for my plan. Here's a hint at my plan...... 400-450whp and 2800lbs with great response.
There are still three issues I need to resolve though, which shouldn't be difficult. The DCCD switch and cluster are reversed in that "locked" on the scroll wheel shows up as the lowest setting on the dash and vice versa. Then the little issue of the gas light not getting a reading from the tank, I think I know why so it should be an easy fix. Lastly.... the one I'm not sure of..... the airbag light is on despite everything being connected.....I'll look into it. Here is the thread I had about the swap http://forums.nasioc.com/forums/show....php?t=1480973
Till then here are the pictures from the wiring swap, enjoy.
Old 08-07-2010, 12:28 AM   #6
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Old 08-07-2010, 12:30 AM   #7
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Old 08-07-2010, 12:31 AM   #8
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Old 08-07-2010, 12:32 AM   #9
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Old 08-07-2010, 12:32 AM   #10
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Old 08-07-2010, 12:43 AM   #11
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
And some video of when I started it last year...... before realizing my headlight was stolen.
Old 08-07-2010, 12:46 AM   #12
clbd39
Member#: 104078
2013 WRX
wow very nice, can't wait for the end i bet huh?
i hope mine will end up with a 257 someday
clbd39 is offline   Reply With Quote
Old 08-07-2010, 12:55 AM   #13
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
EJ25 Hybrid, 314HP- 280tq
Bugeyecandy.
BugeyedWREX is offline   Reply With Quote
Old 08-07-2010, 01:22 AM   #14
subaru3169
Member#: 55252
* pullup bar *
yaaa i would've given up already
but g'luck with solving the little issues
subaru3169 is offline   Reply With Quote
Old 08-07-2010, 01:36 AM   #15
Cusson
Member#: 95695
2018 STI Limited
Pretty legit build. Car looks great!
Cusson is offline   Reply With Quote
Old 08-07-2010, 05:44 AM   #16
Hokie-wrx wagon
Member#: 87194
I'm glad you stuck with it. The car is beautiful!
Hokie-wrx wagon is offline   Reply With Quote
Old 08-07-2010, 08:47 AM   #17
AirForceBugeye
Member#: 202445
2002 Impreza WRX
Midnight Black Pearl
That's a lot of motors...
Glad it's all workin' out dude.
AirForceBugeye is offline   Reply With Quote
Old 08-07-2010, 11:14 PM   #18
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Thanks for the support guys, it's been a long journey and it's not going to be too much longer until I'm finished with my plans for it. Just a matter of sourcing the parts I want and finding the time to get down to FL.
Old 08-08-2010, 01:35 AM   #19
riosseb
Member#: 162984
2005 Scoob
car looks great! i want your seats lol
riosseb is offline   Reply With Quote
Old 08-08-2010, 01:45 AM   #20
spinnaker226
Member#: 214359
2005 WRX
^my thoughts exactly. and steering wheel
spinnaker226 is offline   Reply With Quote
Old 08-08-2010, 10:05 PM   #21
larful
Member#: 227838
2007 WRX
jeeez that was a mess of wires, how do you find out where they all go
larful is offline   Reply With Quote
Old 08-08-2010, 10:25 PM   #22
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I've always been pretty good at taking things apart and putting them back together...... with a few extra bolts leftover
At first I just took my old harness and layed it next to the new one to figure out what went where...... then trial and error on a few lil things (headlight wiring). I then took the US STi wiring diagrams and compared them to mine and used them to wired up the DCCD to the ABS control unit etc etc..... it hurts just thinking about it
Here are some more pics of how I painted the carpet black and repainting the rotors.
The painted calipers turned out ok...... but I feel like having them powdercoated along with the front calipers
Old 08-08-2010, 10:31 PM   #23
Flat4TW
Member#: 200456
0295 WRX
leather seats and sunroof! you got one special bug eye.
Flat4TW is offline   Reply With Quote
Old 08-08-2010, 10:43 PM   #24
kscasper13
Member#: 143711
2002 2.5, 6 speed
APS Bugeye
lookin good man,
you gonna make it to the South Florida Cruise Sept 4th? i just finished a rediculously tedious swap my damn self....
http://forums.nasioc.com/forums/show....php?t=1992472
i'm in fort laudy
Kevin
kscasper13 is offline   Reply With Quote
Old 08-08-2010, 11:51 PM   #25
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Originally Posted by kscasper13 View Post
lookin good man,
i'm in fort laudy
Kevin
The car should be ready...... the problem is if I will be busy with work in NY . I was reading your thread a couple weeks ago, crazyness all the crap you had to go through.
Thanks, but the sunroof is gonna get axed for a CF roof.... tired of the leaks with the sunroof
FS/FT: KOJI bugeye headlamps, jdm sti bugeye dash trim wrxmyers Tri-State Area Private Classifieds 60 01-05-2010 03:59 PM
04-07 STi Splitter/Bellows with a JDM STi Bugeye Scoop? Superorb Interior & Exterior Modification 15 07-26-2009 07:36 PM
sti rear seats, jdm sti bugeye headlights, ver1 front lip, etc skate enjoi MWSOC Private Classifieds 14 08-05-2008 12:11 PM
MD: JDM STi bugeye HIDs, converted to LHD, w/leveling switch boneriffic Exterior/Styling 6 08-13-2006 10:56 PM
looking for 1 JDM STI bugeye headlight palmerx141 Private 'Wanted' Classifieds 0 04-28-2005 06:44 PM
