08-31-2010, 01:09 PM | #1 |
Member#: 119777
Vehicle:2013 BRZ SWP |
06 Saabaru 18G-XT 341whp/326wtq on an Uncorrected DynoJet.
Event: Dyno Pull
Location: P&L Motorsports (Chicago, IL) Ambient Temp: 95 degrees Fahrenheit Elevation: 600 feet Weather: Hot, 36% Humidity Tires: 245/40/17 RE-01R Tires Car: 2006 Saab 9-2X Aero (2.5L) Tuner: Jorge Dyno Info: DynoJet Transmission: 07 STI 6 speed Gear: 3rd Peak HP at RPM: 341.5 Uncorrected Peak Torque at RPM: 326.30 Uncorrected Baseline hp/tq for a stock on same dyno: ~210-220whp (Stock STI) Target Boost: 20psi tapering to 18psi Target AFR: 12.0 Fuel: 93 Octane from Shell (Sitting in the tank for over 2 weeks) Power Mods: EJ255 w/ 100mm CP Pistons (~8.8 CR) ACL Bearings ARP Headstuds GSC S1 Cams (266/266) Supertech Valvetrain Blouch 18G-XT 8cm (Coated Exhaust Side) Spearco TMIC Tial 44mm External Wastegate GT-Spec Headers and Uppipe (Wrapped) TurboXS 4" Downpipe (Wrapped) P&L Street Exhaust TGV Deletes P&L HiFlo Intake Samco Turbo Inlet GM BCS Deatschwerks 850cc Injectors Walbro 255lph Fuel Pump Drivetrain Mods: Exedy HD Clutch OEM Flywheel Kartboy Short Shifter and Bushings Group N Engine and Transmission Mounts Suspension Mods: Endura-Tech Coilovers Whiteline Front and Rear Sways w/ Kartboy Endlinks
08-31-2010, 01:39 PM | #2 |
Member#: 152685
NESIC
Vehicle:2016 Forester XT DGM |
Why only a 3rd gear pull, shouldn't it have been in 4th with the 6 speed?
08-31-2010, 02:15 PM | #3 |
Member#: 119777
Hot day, static air. But yes, it would have made a bit more power and spooled sooner in 4th.
08-31-2010, 02:18 PM | #4 |
Member#: 167462
SCIC
Vehicle:2003 wrx sedona red |
07 6 speeds have longer gears, more like the 5 speed.
numbers look good OP |
08-31-2010, 10:21 PM | #5 |
Member#: 44836
Vehicle:1999 Fozzy silver |
hows it feel?
08-31-2010, 10:42 PM | #6 |
Member#: 113666
Vehicle:60' all over you |
id pass on the 18g....
08-31-2010, 11:32 PM | #7 |
Member#: 42933
Vehicle:03 WRX (ej257 swap black |
my sentiments exactly, opposite. the 18g isn't the 18g anymore. These new big wheels and hotsides change things a little. For example the 16gxt is supposed to be 42lbmin ( old 20g is 44lbmin) and the 16gxt is the one that you can't get the 10mm hot side on. Last year's popular opinion that the 2.5 engine needs at least an 18g at the very least if upgrading from stock, i think things have changed. These new units are more efficient (i suspect) and bigger. The Ratio of flow from the compressor to the turbine has gotten smaller, and the size of both has grown.
09-01-2010, 01:39 AM | #8 |
Member#: 119777
I'm starting to suspect a boost leak, it's spooling at least 700rpm slower than my TD05 20G 8cm did.
It's a billet 43 lb/min wheel, where as the 20g was a standard 44 lb/min. |
09-01-2010, 01:59 AM | #9 |
Member#: 89752
SCIC
Vehicle:08 STI SWP |
I've been saying this for a while now, but the new "miracle" billet wheel turbo are more hype than anything else. 341whp on a cammed motor with an EWG and with full boost after 4000rpm is nothing special at all. As the OP has already noted his old 20G spooled better I typically see similar power with 20G's running IWG on stock motors.
They are simply bigger comp wheels. They make more power than their "old" namesakes but spool slower. Wow... the laws of physics are actually real ?!? Whodathunkit? |
09-01-2010, 02:08 AM | #10 | |
Member#: 119777
09-01-2010, 02:50 PM | #11 |
Member#: 119777
Couldn't find any boost leaks, no cracks or leaks in the exhaust either.
Anyone want to take a wild guess why this turbo is spooling nearly 1,000rpm slower than my TD05 20g 8cm did? |
09-01-2010, 02:52 PM | #12 |
Member#: 219756
Vehicle:06 WRX TR OBP |
Nice power. Wish I made that much.
09-01-2010, 03:04 PM | #13 |
Member#: 147579
Rare is the Blouch billet wheel turbo that doesn't spool late, sad but true, even the small ones. You even have all the "right" mods for earlier spool. They do make good power though, you just have to wait for it.
09-01-2010, 03:19 PM | #14 | |
Member#: 119777
Compared to my Blouch TD05 20g 8cm, I picked up maybe 10 horsepower on the top end but don't think it was worth the delay in spool. If something is mechanically wrong with the turbo it'd be an easy explanation, but if it's working properly and spools like this I'm quite disappointed by it. |
09-01-2010, 03:21 PM | #15 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
09-01-2010, 03:27 PM | #16 |
Member#: 119777
This exact same setup was spooling a TD05 20g 8cm well before this 18G-XT 8cm. On the road in the 3rd gear it would hit 17psi by 3100 rpm (with a 5 speed). Currently on the road in 4th gear (07 6 speed) it's not spooling till almost 4000 rpm. Obviously weather and humidity are partly to blame, but is it possible for those two variables to affect spool by 700 rpm?
Again, only changes were the turbo and 6 speed. Everything else has remained the same. |
09-01-2010, 03:30 PM | #17 |
Member#: 21392
Vehicle:2018 E63S AMG MB Black/MB |
subscribed
09-01-2010, 04:24 PM | #18 |
Member#: 119764
Vehicle:2006 STi WRB |
Spool looks slow for the 18G-XT. I added some graphs from EFI Logics tuning the 18G-XT.
09-01-2010, 05:16 PM | #19 |
Member#: 130990
NWIC
Torque seems relatively low for a 2.5 in comparison to hp. Usually it's reversed. I can't imagine your tuner would turn down the torque for your built setup. Seems weird.
Also, I think it's strange (looking at the graphs) that a built motor running E85 and FMIC does not kick ass on the much more stock pump gas setup -- a few more hp, and a lot less tq! Maybe you should try a 10cm^2 hta68. |
09-01-2010, 05:28 PM | #20 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 EJ207 S204 Wagon |
Why is the OP dyno graph/pull uncorrected?
09-01-2010, 05:47 PM | #21 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Because the chart is from P&L and they always report uncorrected numbers.
Corrections are more for N/A, They tend to "over-correct" turbo cars. RiftsWRX (Jorge) has comments throughout PPB about his take on the corrections, no need to re-hash. |
09-01-2010, 11:37 PM | #22 |
Member#: 245237
Vehicle:2007 Subaru STi |
I have seen a 500 rpm differents in spool from a 3rd to 4th gear pull on an 07 STi with a GT30R. But still for a 18g with a build engine and higher comp pistons.
06 WRX Blouch EVO 3 w/ 8cm vs TD05-18G XT which one? | konmann | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 06-14-2010 12:39 PM |
Anyone have a dynojet chart of a Green/SZ49/Dom 1 on an ej205? | jason miller | Proven Power Bragging | 0 | 12-05-2009 05:39 PM |
Anyone have a dynojet chart of a Green/SZ49/Dom 1 on an ej205? | jason miller | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 12-05-2009 04:01 PM |
Does a 06-07 cruise control button work on an 04? | WrexT | Interior & Exterior Modification | 4 | 07-08-2008 06:54 PM |
Intercooler y-pipe on an 06 WRX the same as Forester XT... | SilverSubaab | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 12-28-2006 04:04 PM |
