#1 |
Vendor Sales Rating: (43)
Member#: 96479
South East
Vehicle:2006 WRX STI Obsidian Black Pearl |
![]() Hi guys,
we would like to announce that we here at kamispeed are officially a zeitronix dealer and would like to share with you some background on this great company, one of the very best choices for your tuning solutions. About Zeitronix Zeitronix has been a part of the racing scene for many years. We support race teams in US and around the world. We have been offering high grade automotive electronics available to high performance enthusiasts and wining race teams since 1998. To assure the highest quality of our products are designed using tough military standards and industrial derating guidelines. We strongly believe that consumer grade electronics has no place in tough automotive environment. Our engineering group has years of experience designing military, medical, automotive and industrial electronics. Using modern, state of the art surface mount assembly equipment and process control adds additional level of robustness to our products. All our products are designed, manufactured and fully tested in USA. We do not take any shortcuts! Warranty Our products carry 6 months manufacturing warranty. If you have problems with our product contact us, 99% of all issues can be resolved remotely. All returns and warranty repairs need to be authorized. A 10% restocking fee will apply to all returns. All returns must be received in new unused condition within 30 days of original purchase date. Shipping charges are not refundable. We do not warranty or refund sensors. Our products are fully tested and made in the USA. This year at the 2009 SEMA Auto Show, Zeitronix was very honored to receive awards for both the Zeitronix Ethanol Content Analyzer and the Zt-2 Model 2010 Wideband Datalogging System. The Ethanol Content Analyzer was the winner of a 1st Runner Up award in the "Best New Performance Racing Product" category and also received a SEMA "Global Media Award" from international journalists. The new Zeitronix Model 2010 Zt-2 Wideband System also received a "Global Media Award". Zeitronix products participated in a a field of more than 2700 new products at this years show. Here are some pictures of the Zeitronix guys at sema last year ![]() ![]() ![]()
Supports: Air/Fuel ratio as AFR/Lambda, plus RPM, Vacuum, Boost, Exhaust Gas Temperature, Throttle Position, 0-5 volt sensors, and Air/Fluid temperature sensors. Tune fuel injected and carbureted engines. Very simple installation. Connect two wires to +12V and ground and place the O2 sensor in the exhaust stream and you are ready to read AFR! Cut your tuning time in half! No matter if you have a stand alone engine management system, a piggy back fuel control or a carbureted engine. The Wideband Air Fuel Ratio Meter is a must for a serious tuner! Finally you can tune for more power, closer to the edge, precisely monitoring Air/Fuel ratio Boost, EGT, RPM and throttle position datalogging up to 9 hours of data with a blazing rate of 74 samples per seconds per graph. The ZDL software can be utilized as a real time display when using a basic Zt-2 kit without the hardware display. Fully digital, smallest wideband O2 controller and datalogging system in the world! Zt-2 is about the size of 1" thick business card. Extremely compact design for installation where space is a premium. ![]() Zt-2 Specs
The Zt-2 communicates with the PC Laptop via the serial port. The ZDL logging software records up to 9 hours of data per single file. Different screen options are available. It has a black background for easy night tuning. The logging start, stop and pause accessible from keyboard shortcuts. Excel and text data export. Win98/NT/2000/ME/XP/Vista/Windows 7 compatible. You do not need P4, P3 or even P2 laptop. We understand that you want to leave your new laptop at home and dedicate the old one to car tuning. We give you well optimized software. If your laptop is capable of running Win95 and up it is good enough for the Zeitronix logging software. The digital gauge screen option could be used when purchasing the Zt-2 without the LCD display. ![]() The EGT Sensor Zt-2 reads the exhaust gas temperature through a standard K thermocouple, the same as used by most aftermarket EGT gauges. You can retrofit your EGT probe with supplied Zt-2 style 2 pin connector or purchase a new probe from us. Moreover, we offer 8' chromel-alumel extension wire with the Zt-2 style connector in case you need to extend your EGT probe. FOR MORE INFO CHECK OUT ZEITRONIX PAGE Please let me know if you have any question regarding the products, guaranteed Quality will exceed expectations!
__________________
[CENTER] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | [B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] [B]Earn Reward Points! $1 = 2 Points (Redeem Points for $5 ~ $100 Off Your Orders)[/B] [U]Phone Number[/U]: 407-352-7024 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] Last edited by Kami Speed; 09-02-2010 at 05:07 PM. |
#2 |
Member#: 96479
South East
![]() ZR-2 Multi Gauge
The Multi Gauge works with all versions of the Zeitronix Zt-2 Wideband AFR meter and Datalogging System. The ZR-2 plugs into the Zt-2 DATA port. For clean and easy plug and play installation, power and serial data is supplied from the Zt-2 DATA port. There are no additional +12V or ground wires. The ZR-2 cable length is 5 ft (1.5m) MOUNTING OPTIONS The ZR-2 gauge is only 6/8" (19mm) thick. The back of the gauge is completely flat with cable hidden in a cavity and can be surface mounted almost anywhere inside the car cabin using a piece of Velcro or double sided tape. The ZR-2 base allows the gauge to be mounted in a standard 2" 1/16 (52mm) gauge pod. For additional mounting options the package includes 2 set screws and 2 nuts. ZR-2 gauge dimensions: Base diameter 2" 1/16 (52mm) Bezel diameter 2" 1/2 (62mm) Thickness 0.75" (19mm) Digit height 0.3" (7.5mm) ![]() ![]() ![]() ![]() ![]() Zeitronix Wideband LCD Display ![]() Display Features - Display LCD top line as: Lambda and AFR / User2 and AFR / Lambda and U2 (User2). (User2 can be setup as: Oil/Air/Water Temperature, Oil/Fuel Pressure, and Boost! - Display LCD bottom corner as Boost, Throttle Position, or User1 (0-5 volt sensor). - Display in imperial or metric units. LCD Setup Overview Yes, you can be fast without the A-pillar gauges. The LCD display gives you a stealth look and important data in high contrast digital format. The aluminum enclosure dimensions are 4.7" x 2" x 0.9" , slightly larger than the LCD display itself. The LCD fonts are bright white on a black background. High contrast LCD digits are visible even in a direct sunlight. A push of a button located on the right side of the LCD shows peak and hold maximum AFR, Lambda, EGT and Boost values. The LCD display communicates with the Zt-2 digitally through a serial interface. This allows for a clean display installation in the car, since all heavy wire connections are going to the Zt-2. The display serial cable is thin, black and easily blends with the dash. The new overlay is made from hard coated, scratch resistant material. Zeitronix DashDAQ Series II XL Display Full color, OBDII compatible Touch Screen Display for the Zt-2 Wideband AFR Meter ![]()
![]() Some videos of the Display in action >>> http://www.youtube.com/results?searc...onix+zt-2&aq=5
__________________
[CENTER] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | [B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] [B]Earn Reward Points! $1 = 2 Points (Redeem Points for $5 ~ $100 Off Your Orders)[/B] [U]Phone Number[/U]: 407-352-7024 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] Last edited by Kami Speed; 09-02-2010 at 06:02 PM. |
#3 |
Member#: 96479
South East
![]() Other products
![]() MAP SENSORS ![]() EGT ![]() Please let me know if you have any question regarding the products, guaranteed Quality will exceed expectations!
__________________
[CENTER] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | [B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] [B]Earn Reward Points! $1 = 2 Points (Redeem Points for $5 ~ $100 Off Your Orders)[/B] [U]Phone Number[/U]: 407-352-7024 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] Last edited by Kami Speed; 09-02-2010 at 05:50 PM. |
#4 |
Member#: 96479
South East
![]() PLASMA DIRECT (PAT) A revolution in ignition technology!!Okada project direct plasma for 02-08 WRX / 04-09 STi / 05-07 LGT ![]() ![]() The Plasma Direct is the ignition coil with a high power amplifier built in to it. The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM. The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines. The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved. Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go! Plasma Direct is made to a specific application. Please check Application chart to find the correct model for your car. << Plasma Direct is chosen by Japanese customers as No.1 Ignition part,most effective,most desired part. >> Highlights ***12539;100% secondary current (Spark Amperage) increase ***12539;4 Times Spark Energy Increase for the initial spark discharge ***12539;Easy installation. Only replace stock coils to Plasma Direct. ***12539;Compatible with all OEM components ***12539;Compatible with OBD-II (On-Board-Diagnostics) Dyno Result Supply high-revving power across the entire torque band.(EJ20 Turbo) ![]()
__________________
[CENTER] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | [B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] [B]Earn Reward Points! $1 = 2 Points (Redeem Points for $5 ~ $100 Off Your Orders)[/B] [U]Phone Number[/U]: 407-352-7024 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] |
#5 |
Member#: 96479
South East
![]() ![]() Cyber Speed components are created through development of technology used for competition with the record breaking Cyber Evo. Now, the benefits of our experience with racing technology are available for your vehicle, so you too can feel the competitive spirit of CYBER SPEED. Applications : Subaru Impreza WRX/STi (GDA/GDF: '03+)/ Nissan 350Z ('02+) /Mitsubishi Lancer Evolution ('03+) ![]() ![]() Hyper Force System The Hyper Force system is the next gernation high-efficiency ignition tuning and strengthening system. It works by absorbing all back electromovtive force, which aids to improve plug voltage and promote complete combustion by producting 100$ coil efficiency. Also, the hyper Force System eliminates any ignition performance loss due to descreased electrical current under heavy throttle. Since ignition efficiency over the entire revolution range improves, available torque and acceleration response improves; this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emission. Benefits: -Increased horsepower -Increased torque -Better gas mileage -Improved throttle response -Longer battery life -Improved battery efficiency -Reduced emissions ![]() These are in stock and ready to with the corresponding harness! ![]() ![]() The new Hyper Voltage GT System is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. GT Version provides both function and stylish appearance; units are designed to universal to fit any vehicle, with mounting brackets and one (1) additional grounding cables. Benefits •Multi-Range Rev. Performance (Low-Mid-High) •Increased horsepower •Increased torque •Increased throttle response •Improved fuel efficiency •Brighter headlight •Reduced audio noise •Improved battery efficiency •Longer battery life •Best to works with optional Hyper Ground Wire System ![]() Hyper Ground System The H.G.S. Cyber Speed Version is custom-tailored for the best fit and best performance in your vehicle. Giving your car a more efficient ground will help to pull out its full performance potential. The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals. Designed to exceed stringent OEM specs for heat resistance and durability, these cables are the absolute best available. Cyber Speed Version kits have pre-determined mounting points to ensure the best performance and the cleanest installation. Applications : Subaru Impreza WRX/STi (GDA/GDF: '03+)/ Nissan 350Z ('02+) /Mitsubishi Lancer Evolution ('03+) ![]() Benefits: -Increased horsepower -Increased torque -Better gas mileage -Improved throttle response -Quicker engine starts -Brighter lights -Reduced emissions -Reduced audio noise ![]()
__________________
[CENTER] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | [B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B] [B]Earn Reward Points! $1 = 2 Points (Redeem Points for $5 ~ $100 Off Your Orders)[/B] [U]Phone Number[/U]: 407-352-7024 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] Last edited by Kami Speed; 09-02-2010 at 06:47 PM. |
#6 |
Member#: 96479
South East
![]() Ttttt
__________________
#7 |
Member#: 96479
South East
![]() bumppp
__________________
#8 |
Member#: 96479
South East
![]() bump!
__________________
#9 |
Member#: 96479
South East
![]() ttttt
__________________
#10 |
Member#: 96479
South East
![]() ttttttttt
__________________
#11 |
Member#: 96479
South East
![]() ttttttt
__________________
#12 |
Member#: 96479
South East
![]() bump!
__________________
#13 |
Member#: 96479
South East
![]() tttttttttttt
__________________
#14 |
Member#: 96479
South East
![]() Bumpp
__________________
#15 |
Member#: 96479
South East
![]() tttttt
__________________
#16 |
Member#: 96479
South East
![]() bumppp
__________________
#17 |
Member#: 96479
South East
![]() bump!
__________________
#18 |
Member#: 96479
South East
![]() bump!
__________________
#19 |
Member#: 96479
South East
![]() bump!
__________________
#20 |
Member#: 96479
South East
![]() bump!
__________________
#21 |
Member#: 96479
South East
![]() bumpp
__________________
#22 |
Member#: 96479
South East
![]() bumppp
__________________
#23 |
Member#: 96479
South East
![]() bump!
__________________
#24 |
Member#: 96479
South East
![]() bumppp
__________________
#25 |
Member#: 96479
South East
![]() ttbtt
__________________
Sun Auto on Sale-Okada Projects Free Spark Plugs-Gauge Packages $499 | Gruppe-S | Gauges & Electronics | 63 | 07-30-2008 10:57 PM |
E-Auto // Okada Projects Coil Packs! | EAuto | Vendor 'Group Buy' Classifieds | 80 | 10-11-2007 04:58 PM |
okada projects question | yeahovah | Newbies & FAQs | 17 | 09-07-2007 11:19 PM |
OKADA PROJECT High-Power Coilpacks | EAuto | Engine/Power/Exhaust | 35 | 08-27-2007 01:14 PM |
FS : Project Mu Pads and Sun Auto Hyper Grounding System | wrxtreme2 | Private 'For Sale' Classifieds | 15 | 07-03-2006 10:05 PM |
