Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 09-14-2010, 11:18 AM   #1
DrnknZag
Member#: 138473
2017 Focus RS
Stealth Gray
Default OEM 5x100 wheel 4/2 pot clearance
I'm interested in compiling a list of 5x100 OEM rims that clear 4/2 pot brakes. I searched around a bit but oddly didn't come up with a ton.
-'07+ WRX 17"
-'04 STi BBS
-'05+ Legacy 17"
-'07+ Legacy Spec-B 18"
-'98-'01 Impreza RS 16"
-'04+ Forester XT 16"
-'06-'07 Impreza 2.5i 5-spoke 16"
-'05-'06 Saab 9-2x Aero 17"
-(year??) silver steelies 16"
-'02-'03' WRX BBS RK option 17"
Am I missing any here?
DrnknZag is offline   Reply With Quote
Old 09-14-2010, 11:20 AM   #2
totech
Member#: 161523
04+ Forester XT 16"
Subaru Silver Steel wheels 16x6.5
totech is offline   Reply With Quote
Old 09-14-2010, 12:22 PM   #3
express_wagon
Member#: 68346
2015 WRX
2006-07 Impreza 2.5i 5-spoke 16x6.5"
express_wagon is offline   Reply With Quote
Old 09-14-2010, 12:36 PM   #4
teiva-boy
Member#: 22825
Make sure to clarify which 4 pots!
The JDM units with raised lettering or the USDM units that are flatter using a sticker/stencil instead for the lettering.
The raised lettering will greatly reduce your choices in OEM wheels.
teiva-boy is offline   Reply With Quote
Old 09-14-2010, 03:17 PM   #5
DrnknZag
Member#: 138473
2017 Focus RS
Stealth Gray
Ah, I did not know that! It wouldn't be a bad to have a list clarifying which wheels can clear one or the other.
Old 09-14-2010, 06:28 PM   #6
Mr. Sociable
Member#: 176200
2011 Ford Mustang GT
Stock 17" 9-2x Aero wheels clear.
Mr. Sociable is offline   Reply With Quote
Old 09-14-2010, 06:32 PM   #7
trick3d
Member#: 202146
2018 Crosstrek
Crystal White
The 17in optional WRX BBS wheels fit the USDM 4pots with a serveral mm to spare.
trick3d is offline   Reply With Quote
Old 09-14-2010, 07:31 PM   #8
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
'02-'04 WRX wheels will with a small (3mm of the top of my head) spacer.
Byzantium is offline   Reply With Quote
Old 09-14-2010, 10:09 PM   #9
BS87
Member#: 240621
2014 Mazda 3
-'07+ WRX 17"
-'04+ STi BBS
-'05+ Legacy 17"
-'98+ Impreza RS 16"
http://forums.nasioc.com/forums/show...1520681&page=3
Although i think we should keep this thread and OP should keep a nice list in the orig. post. The linked thread is kinda scattered.
Also, OP, it should be 04 ONLY STi BBS'. 05+ is 5x114.3
BS87 is offline   Reply With Quote
Old 09-15-2010, 01:35 AM   #10
DrnknZag
Member#: 138473
2017 Focus RS
Stealth Gray
Bah! Good catch on the BBS, that's slightly embarrassing! I guess that's what happens when you post from work.
Thanks for the link too. I'll try to keep the list updated in my original post as I gather the info!
EDIT: I just realized that I actually posted in that thread two years ago!
Old 09-15-2010, 12:11 PM   #11
DrnknZag
Member#: 138473
2017 Focus RS
Stealth Gray
Updated the list....any others?
Old 09-15-2010, 05:47 PM   #12
trick3d
Member#: 202146
2018 Crosstrek
Crystal White
Im pretty sure your list is not up to date.
Old 09-15-2010, 08:04 PM   #13
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
I would like to see this list expanded to non-OEM 16's as well.
chimchimm5 is offline   Reply With Quote
Old 09-15-2010, 08:40 PM   #14
subaru3169
Member#: 55252
* pullup bar *
jdm/edm 17in wheels?? they're oem somewhere in the world
subaru3169 is offline   Reply With Quote
Old 09-15-2010, 10:18 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
not much.....I had my same wheels on BOTH and the difference was a couple mm at most
Old 09-17-2010, 01:04 PM   #16
vteckiller2000
Member#: 256425
Are you sure about this? I have optional BBS RK's on my bugeye and was told by multiple people that they would not clear the USDM 4 pots.
vteckiller2000 is offline   Reply With Quote
Old 09-17-2010, 01:13 PM   #17
trick3d
Member#: 202146
2018 Crosstrek
Crystal White
Yes I am positive!!!!!! They are on my car right now. 17 x 7 et53
for confirmation from another owner, see post 17-18
But it doesn't matter because I asked twice for the list to be updated the the OP is a bit special.
Old 09-17-2010, 02:39 PM   #18
DrnknZag
Member#: 138473
2017 Focus RS
Stealth Gray
Sorry that my life doesn't revolve around updating this thread.
However I am hesitant to add those to the list because they technically aren't an OEM rim, but a dealer option.
As for EDM and JDM rims, post up the info and I'll add it, I'm not too knowledgable about those rims.
Old 09-17-2010, 03:32 PM   #19
trick3d
Member#: 202146
2018 Crosstrek
Crystal White
You could have just said that earlier calm down pumpkin.
Old 09-17-2010, 04:01 PM   #20
vteckiller2000
Member#: 256425
Mine are +48mm offset.
Old 09-25-2010, 08:28 PM   #21
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
I'm pretty sure the optional RK's are +48
ravenlunatic is offline   Reply With Quote
Old 09-25-2010, 09:02 PM   #22
teiva-boy
Member#: 22825
Except on an FXT, with OEM 16" wheels, the 06/07 4pots work, with only about 2mm to spare. The JDM ones I do not believe would fit. So in specific cases it may not work like on an FXT. However, I bet any OEM 17" wheel would be fine.
Old 09-26-2010, 02:38 AM   #23
05-rsx
Member#: 101188
MY07 WRX Wagon
Yep, Australia and UK at least.
17x7 +55.
Standard on MY01-05 models - bugeye and peanut for us, which had the 'raised lettering' calipers.
05-rsx is offline   Reply With Quote
Old 12-19-2013, 10:09 PM   #24
harmanmute
Member#: 375787
07 WRX
Urban Metallic Silver
If this isn't a sticky, it should be. It would have saved me some money, or maybe I should work harder with the search function.
harmanmute is offline   Reply With Quote
Old 12-20-2013, 11:13 PM   #25
iluvmotocross
Member#: 362247
2006 Impreza WRX
Gray
I second this. It would have saved me money as well but I couldn't find a thread on this subject when I searched for it.
iluvmotocross is offline   Reply With Quote
WTB: Kartboy 2-Pot Adapters, 16x7 Wheels, FHI 4/2 Pot Rotors/Pads, 02 AW STI Scoop proletariandan Private 'Wanted' Classifieds 0 03-18-2009 04:17 PM
Subaru 4/2 Pot Caliper Clearance? Buggn' Out Brakes, Steering & Suspension 4 11-18-2008 06:18 PM
P1's and factory 4 pot/2 pot clearance hypoxvi Tire & Wheel 2 09-01-2008 11:01 AM
