Welcome to the North American Subaru Impreza Owners Club Monday September 25, 2017
Old 10-07-2010, 10:51 PM   #1
JJ21
Member#: 254987
2007 Impreza 2.5i
Obsidian Pearl Black
Question Getting the most out of an N/A engine?
Alright, so i'm just looking at options on increasing the performance/power output of my '07 impreza. I'm relatively new to this, so any help would be appreciated. Also, I'm sorry if there are already stickies on this topic.
I'm trying to stick more with add ons/swap outs instead of replacing/modifying parts of the engine like the piston heads etc.
Obvious things that come to my mind...
Tune
CAI/SRI(although there have been reported problems with them messing up the fuel/air mixture. Not sure how though. Might just leave it out.)
Exhaust(but what? Again, I'm pretty new to this.)
Suspension(not engine related, but help improve handling. But again, what exactly?)
Anything I am missing? Just thought I'd get some of your opinions/recommendations! You are all such a big help!
JJ21 is offline   Reply With Quote
Old 10-07-2010, 11:13 PM   #2
nairbmik
Member#: 220259
09 2.5i
SSM
Honestly, search. There have been tons of threads that ask this same thing, and they all have great information in them.
nairbmik is offline   Reply With Quote
Old 10-07-2010, 11:26 PM   #3
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
JJ21,
You heard right about the CAI, however..
I drove from CT to FL to tune some cars and I did quite a few N/A's. Down in FL, I tune a kid who happened to put a 3" maf diameter'ed intake on his car. The air/fuels were in the 17's for most of the pulls until they dipped 15.0 at redline. Now, if you know anything about N/A tuning, that is absolutely horrible for a car.
Tuning solves this, as the maf scaling can be moddified as well as target fueling with a larger intake. A few ponies can definitely be had here.
From what I have seen tuning in the N/A world:
-headers (no cat)
-CAI
-cat deletes
-tune
All should be done together for the biggest difference in feeling and performance.
If you willing to get into the motor, delta cams make these cars shine. I had an 08 N/A with cams that It tuned that would run neck and neck with stock 2.5l wrx's.
If E85 is available, high compression pistons, delta cams, and the mods above will give you a REALLY peppy car.
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 10-07-2010, 11:40 PM   #4
JJ21
Member#: 254987
2007 Impreza 2.5i
Originally Posted by PhatBotti Tuning TKR View Post
JJ21,
-headers (no cat)
-CAI
-cat deletes
-tune
-Mikey
Cool stuff.
Any recommendations in the way of
-headers (no cat)(what are these)
-cat deletes(what are these/this)
Also, what is involved with switching the cams?
Not sure how I feel about switching the pistons. I guess that might be a future project. There's a family friend that has a car garage with the means to lift the engine(if that is needed).
Old 10-10-2010, 12:56 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
JJ21,
Keep in mind that MAF Scaling does NOT fix the resonance that causes the extreme rich condition on the low end when you use a CAI/SRI with a MAF-based car. So it's not like MAF scaling suddenly makes the intake perfect.
Old 10-10-2010, 01:10 AM   #6
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
uhhh, what? I never see any rich conditions with the 3" intakes. All I see is cars so lean they want to turn off
Old 10-10-2010, 01:11 AM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Read the stickied thread on the major problem with CAI/SRIs and the MAF-based Subarus. If you're not aware of that problem already, it's kinda scary that you've been tuning cars for money.
Old 10-10-2010, 01:25 AM   #8
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
With all due respect, I've read your sticky.
I commented on a 3" maf housing. While you speak of a rich condition down low, I was pertaining to when the car owner does a pull on the stock map and hits high 14's low 15afr at redline pulling 5 degrees of timing with the IAM already knocked down.
Isnt that a bit concerning as well?
Old 10-10-2010, 09:12 AM   #9
littlec
Member#: 208934
09 2.5i
To the op, your best bet for now is to carry speed through corners. Tires and suspension is where you will get bang for your buck. Engine mods on our cars really won't give you much in terms of power. Cost benefit just doesn't make sense.
What exactly do you plan to do with the car?
littlec is offline   Reply With Quote
Old 10-10-2010, 12:10 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Oh, definitely, but you made it seem as though running lean on top were the only thing going wrong.
Old 10-10-2010, 01:49 PM   #11
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
JJ21,
-Mikey
this subject has been beat to death and had cinder blocks strapped to it and thrown into the hudeon river. Why would you want to run a SRI or non OEM CAI....? Why? A hybrid intake with WRX trumpet is far superior. Flows just as good. IAT are excellent, and its very cop friendly....in other words you don't sound like a honda stop praising the CAI. You should know better!
Subyroo2.5 is offline   Reply With Quote
Old 10-10-2010, 02:00 PM   #12
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Suby,
No praise here, if it was up to me I would simply do a drop in filter. I believe in the stock airbox.
I tuned a car last sunday that that made 356whp with the stock box, maf was just shy of being maxed.
-Mikey
Old 10-10-2010, 03:33 PM   #13
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
JJ21,
-headers (no cat)
-CAI
-cat deletes
-tune
-Mikey
Suby,
-Mikey
Recommending is the same as praise.
Old 10-10-2010, 05:44 PM   #14
royalnewjersey
Member#: 250954
2013 WRX Hatch
^^^ to be fair... he merely commented on the fact that headers, CAI, cat deletes, and a tune should all be done at the same time.
He never said that he recommends doing any / all of them.
royalnewjersey is offline   Reply With Quote
Old 10-10-2010, 05:57 PM   #15
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
If that is the case why did he reply at all?
Old 10-10-2010, 06:17 PM   #16
royalnewjersey
Member#: 250954
2013 WRX Hatch
Agreed.
I wouldn't run CAI with a 2.5i. Headerback, Air filter, Stock air Box, Tune, Done.
Then put your money into suspension.
Old 10-10-2010, 06:47 PM   #17
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
Trade for wrx...... lol
trxdam is offline   Reply With Quote
Old 10-10-2010, 09:31 PM   #18
RaineMan
Member#: 256727
2007 2.5I Wagon
Honestly, the equal length stock exhaust manifolds on the 07 2.5i are pretty efficient. Many people go to unequal length headers to get more boxer rumble, but you don't really gain any performance with that selection.
If you want some gains without a lot of trouble, start with a hybrid intake and a 2.25" cat-back with a high flow muffler like Magnaflow or something similar. You can get a tune later for more gain.
RaineMan is offline   Reply With Quote
Old 10-10-2010, 10:07 PM   #19
GrundleJuice
Member#: 165749
you really shouldn't do any intake mods, even a hybrid, without at least rescaling the MAFv table. a muffler will do zero for performance... its a sound only mod. the factory headers are not actually EL on any n/a impreza, although the 06+ headers are pretty good.
Old 10-10-2010, 10:07 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Have you measured the pipe lengths? There's something like 1.5" difference between the runs. That's not EL in anything other than a marketing brochure.
Old 10-10-2010, 10:13 PM   #21
cmiovino
Member#: 134005
2004 WRX Premium
Typical response.
Old 10-11-2010, 06:09 AM   #22
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Old 10-11-2010, 10:40 AM   #23
PA-Outback2000
Member#: 161832
2000 Outback Limited
stromung catback exhaust.
suspension- strut bar(s), swaybar(s), end links, anti-lift kit, lateral links and steering rack bushings if u really want, and coilovers. i would look at cusco, whiteline, tein, ksport, kartboy. if u have any questions on specific parts, just post.
PA-Outback2000 is offline   Reply With Quote
Old 10-11-2010, 11:11 AM   #24
RaineMan
Member#: 256727
2007 2.5I Wagon
They are more "equal" than the UEL headers that people buy. It's a relative term.
Old 10-11-2010, 12:37 PM   #25
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Your engine doesn't think so. The phasing either is right or wrong.
How to get the most out of your vf39 turbo ? Sausage Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 02-14-2008 05:58 PM
getting the most out of the 4eat zacks62fairlane Transmission (AT/MT) & Driveline 2 02-13-2008 12:44 PM
How to get the most out of 0-100kph? accelguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-07-2006 01:23 PM
getting the most out of the tuner pro ride5000 Engine Management & Tuning 4 08-27-2004 06:26 AM
Help me get the most out of AWD lettucemanatee Newbies & FAQs 14 09-03-2003 02:17 AM
