Welcome to the North American Subaru Impreza Owners Club Tuesday September 25, 2018
Old 06-27-2002, 11:07 PM   #1
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
Question Got CEL code 440, Emission System Control
Anyone know of this type of a code?
Name sounds like it has something to do with the exhaust gas release valve system.
Pulled it on a palm.
Thanks,
~Evan
Evan J. Kelly is offline   Reply With Quote
Old 06-27-2002, 11:12 PM   #2
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
There's a recall. It appears the computer pulls up CEL's having to do with the emission control system. They need to reprogram it.
garface is offline   Reply With Quote
Old 06-27-2002, 11:35 PM   #3
garface
Member#: 1581
MY00 RS/STi7
2000-2001 MY 2.5L Legacy and outback with auto transmission
2000-2002 MY 2.2 & 2.5L Impreza models with manual or auto transmission
2001-2002 MY 2.5 L Forester
"The On-Board Diagnostic System, which is part of your vehicle's engine control system and contained in the Engine Control Module, is designed to monitor your vehicle's engine/emission control system. If a problem is detected, the "Check Engine" warning light/Malfunction Indicator Lamp, located on the instrument panel, will illuminate and alert the driver of the need for vehicle service.
The Engine Control Module software logic for the circuit that controls the front oxygen (air/fuel ratio) sensor in your vehicle may have been programmed incorrectly during production. As a result of this condition, the "Check Engine" light may illuminate without cause. It will be necessary to have the ECM software reprogrammed to correct this condition."
Old 06-28-2002, 04:54 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
actually IIRC the P0440 is the purge control solenoid failure code which also warrants an ECM reflash.
jeremy
Old 06-28-2002, 12:01 PM   #5
Evan J. Kelly
Member#: 11172
2000 GC8 RS Coupe'
Question Thanks for the info
huh...
Well, I'm out of warranty now.
Is it a recall?
or do I have to pay?
Old 06-28-2002, 05:08 PM   #6
Jademonkey
Member#: 9213
2000 RS
Red
jeremy
Isn't that only for WRX's?
Jademonkey is offline   Reply With Quote
Old 06-28-2002, 05:12 PM   #7
garface
Member#: 1581
MY00 RS/STi7
It's a recall, you shouldn't have to pay.
Old 06-28-2002, 06:04 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you dont have to pay for recalls.
its for any obdII car, all obdII codes are the same, its a standerdized system required by the gov't.
P0440...I can check but I think its evap system leak, did you fill up with your car running?
Jay
Old 06-28-2002, 06:10 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
440 seems to be a manfacture specific DTC, cause I dont see it in any of the ford books I have access too, all i got is p0442...
hrmm..
Jay
Old 06-29-2002, 02:51 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
ummm...any car can get an ECU flash for a certain problem and this happens to be a bulletin NOT a recall
Old 09-01-2002, 04:02 PM   #11
Mapplex
Member#: 20315
1997 Impreza L
hunter green
I drove 90 miles to Autozone today and they pulled the exact same code on my '97 L. Does anyone know what my options are?
Shaun
Mapplex is offline   Reply With Quote
Old 01-20-2008, 03:02 PM   #12
jimsaco
Member#: 165784
1998 Legacy Outback
Green
I'm pretty cheap and I just had my 98 Outback throw this code. It was related to the evap system, which had not been in a ready state. I had been trying to get the evap to go ready for about two weeks. I checked all the hoses that were easy to get to and tried 3 different gass caps that I got from the boneyard. No, luck. This A.M. I was in Walmart to get wiper blades and next to the blades were NEW gas caps. I figured I should try a new one just to be sure it wasn't the cap. Drove about 40 miles today and guess what!! No codes evap is ready. Man, those gas cap are finickey.
jimsaco is offline   Reply With Quote
Old 02-04-2008, 12:03 PM   #13
misstenacity
Member#: 104063
2000 Impreza Outback
It could still come back later because your tank is currently full - I pulled this info from a service technician's guide (italics/underline mine):
"The testing of this system is only
conducted once per drive cycle and
only under very specific conditions:
The fuel tank must contain less than 9.6
gallons of fuel.
The fuel temperature must be less than
113F.
Engine speed must be over 1500 RPM.
Vehicle speed over 28 MPH.
Throttle position must be mid-range.
Intake manifold vacuum must be
equivalent to cruising vacuum.
455 seconds must have elapsed since
engine start."
So... if your tank is kept full, you can avoid triggering the test in the first place (a strategy I am soon to use to pass my emissions - ha!).
Andrea in ABQ
misstenacity is offline   Reply With Quote
Old 02-17-2008, 09:29 PM   #14
seherman
Member#: 172084
Cool Codes related to misfire?
We're battling a misfire on our 02 legacy outback wagon and the CEL goes on and off fairly frequently. Are the two events necessarily related? The CEL goes on with or without the misfire, which causes bucking, stuttering, etc.
Thanks!
seherman is offline   Reply With Quote
Old 11-27-2008, 11:58 AM   #15
sureshot007
Member#: 142405
#716 Group5 S10
Thanks!
I'm having the same issue on my 97 brighton. Did you find a solution?
sureshot007 is offline   Reply With Quote
CEL code P0457: Evaporative Emission Control System Leak Detected (fuel cap) aznfoos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 06-24-2015 05:27 PM
GC8 CEL Code 24: Idle Air Control Solenoid Valve pr1nce Pre-2002 Factory Turbo Powertrain 15 01-29-2011 03:34 PM
CEL Code and emissions, please help fmauriwrx Service & Maintenance 1 02-10-2008 07:09 PM
Help CEL code 0442 Evaporative Emmission Control System Leak audioutopia Service & Maintenance 2 02-17-2007 01:59 PM
Help? CEL code 0442 Evaporative Emmission Control System Leak audioutopia Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-16-2007 07:15 PM
