Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 05-06-2012, 10:41 PM   #1426
bboylocob
Member#: 151809
2007 WRX
Mine does that and I have the same motor. When I asked Phil about it he said that its probl. The start up map. All was good. Wideband was on Target . And that is from two widebands. Comp. Was perfect and all. It only does it at certain times. Like at certain coolent temps. Just never had time to work on it.
bboylocob is offline   Reply With Quote
Old 05-06-2012, 10:44 PM   #1427
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Wait, your's does what? Run rich at startup or foul the plugs on one side of the motor?
Again to confirm, my passenger side plugs look perfect and my drivers side look very very black.
dexterous is offline   Reply With Quote
Old 05-06-2012, 10:46 PM   #1428
dexterous
Member#: 23553
2014 WRX - Daily
I would also like to add that when the motor blew last year I had the injectors tested by witchhunter injector service and all four came back perfect.
Old 05-06-2012, 11:02 PM   #1429
bboylocob
Member#: 151809
2007 WRX
Runs rich at times during start up. Sorry. Yea I got the point that one side fouls out on urs. Check Ur map for each injectors pulse. Make sure they all match.
Old 05-06-2012, 11:12 PM   #1430
dexterous
Member#: 23553
2014 WRX - Daily
Ok, thats what I though.
Yes, I already checked both the injectors and the spark trims just to be sure. I am also going to be checking the grounds tomorrow as Phil says the drivers side coil packs share a common ground.
Old 05-06-2012, 11:14 PM   #1431
bboylocob
Member#: 151809
2007 WRX
Yea they do I forgot about that. Def. Check that.
Old 05-06-2012, 11:14 PM   #1432
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
How well is your engine grounded?
shilohb is offline   Reply With Quote
Old 05-06-2012, 11:21 PM   #1433
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Well it looks like you ancerd that as I was asking
Old 05-07-2012, 08:56 AM   #1434
dexterous
Member#: 23553
2014 WRX - Daily
All the stock grounding is in place and I dont have any modifications to any of that. If it were an ignition thing, wouldn't the motor run poorly and have drivability issues?
Old 05-07-2012, 09:24 AM   #1435
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Dammitt!!! hope it is nothing serious. I am sure you will gt it sorted out. slowgenious, there's a guy on craigslist that sells food grade drums for cheap. UDS is my next project.
Tenacious Bee is offline   Reply With Quote
Old 05-07-2012, 09:39 AM   #1436
vicious_fishes
Member#: 158864
2003 SOHC destroker
it should be having that with your fuelling problem...
is it both plugs each side? i.e left side is lean, right side is rich? i was going to guess that one/two of your injectors might have taken a dump.
vicious_fishes is offline   Reply With Quote
Old 05-07-2012, 09:50 AM   #1437
MRF582
Member#: 48219
. Always drive
the race line .
What could cause something like this? Here's a pict of my passenger side plugs:
I a pretty sure that its not a tuning related issue. Here's a list of the ideas running through my mind:
-Pinched fuel return line from the drivers side rail
-Debris stuck in both of those injectors
-Electrical issue causing problems with both of those coil packs
-Some kind of issue with the cams/head/valves on that side
-Timing belt issue
A "Pinched fuel return line from the drivers side rail" would cause that side to run rich not lean! You say your passenger side spark plugs are fouled?
Also, does your Hydra always run in open loop fueling mode? Or does it run closed loop at low loads?
And this is the problem with running split fuel distribution. More points for failure. Having a global fueling problem is much better for the engine than a partial fueling problem.
MRF582 is offline   Reply With Quote
Old 05-07-2012, 09:54 AM   #1438
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Thanks Bee, Dude Tom you cant be serious?!!!! I know you had those injectors checked, maybe get them checked again? Maybe flakey coil packs?
slowgenius is offline   Reply With Quote
Old 05-07-2012, 10:30 PM   #1439
dexterous
Member#: 23553
2014 WRX - Daily
Yes, I did have them fully checked.
Old 05-07-2012, 10:33 PM   #1440
dexterous
Member#: 23553
2014 WRX - Daily
Shek,
You're absolutely correct. I was so pissed when I was writing my post from last night that I got it all wrong. Here are the actual facts:
The passenger side plugs look good
The DRIVERS side plugs look really black
I feel that the drivers side fuel return line could possibly be pinched.
Old 05-07-2012, 10:38 PM   #1441
dexterous
Member#: 23553
2014 WRX - Daily
A co-worker showed me this after I told him about my car today. It kind of makes me feel that maybe my issue isn't so bad.
Old 05-07-2012, 11:57 PM   #1442
bboylocob
Member#: 151809
2007 WRX
Hey a few of those rods look like they can be reused...lol
I'm sure Ur block is fine. Just do some checking. And findout if its on every start up or certain coolent temps. Also if its happening when u are driving also.
Old 05-08-2012, 10:58 AM   #1443
cpturbo
Member#: 49175
2004 STI
If it were my car, then the first thing that I would do is consult Phil by email.
I would really re-examine your fuel routing. I would send the injectors to RC engineering. I would check the timing belt to make sure the marks line up on the crank and all cam pulleys. I would verify spark in the spark plugs.
Good luck
cpturbo is offline   Reply With Quote
Old 05-08-2012, 11:15 AM   #1444
kakarot09
Member#: 182375
08 Sti
Wrbm
If it seems not to be super rich on one bank after driving it but it is after idling it could be that those two injectors flow more at that low pulse width. So at idle that bank will idle rich while the other is lean. If so you should be able to swap injectors and see it change cylinders. They're relatively large injectors and when you get that big the low pulse width flow is usually not that great. One of the reasons that ID's are nice is that he matches the injectors based on that low pulse width. I wish all the injector manufacturers did that.
kakarot09 is offline   Reply With Quote
Old 05-14-2012, 11:17 AM   #1445
Maxwell Power
Member#: 190729
Cam timing or hydra are the most likely culprits.
Couple questions:
Did you use anything adjustable in the cam timing department?
Parallel or series fuel lines?
Maxwell Power is offline   Reply With Quote
Old 05-14-2012, 09:23 PM   #1446
dexterous
Member#: 23553
2014 WRX - Daily
When you say adjustable are you talking about things like manually adjustable cam gears? If so, no. Everything there is 100% stock. I have parallel fuel lines.
Old 05-14-2012, 11:40 PM   #1447
cinnaman
Member#: 298063
2005 legacy 2.5i
DIP
This. Would help eliminate a lot of possibilities. I would be interested to see the result.
cinnaman is offline   Reply With Quote
Old 05-15-2012, 12:45 AM   #1448
Maxwell Power
Member#: 190729
that or the crawford adjustable timing idlers. I used them before and found them to be more detrimental. I had 20 psi difference in compression from one bank to the other which resulted in one side being more rich than the other.
Try series fuel lines. I realize that this is not likely the cause of your issue, but there is a lot of evidence that support series rails on our cars being better than parallel.
Old 05-15-2012, 01:10 AM   #1449
eg33GC
Member#: 206851
56 Belair
Pro Street
could you please elaborate?
some of us simple folk could use some info
eg33GC is offline   Reply With Quote
Old 05-15-2012, 01:31 AM   #1450
TwinscrollGT35R
Member#: 256810
Have you checked the coils on that side? Check them when they are cold, then heat them up with a heat gun and keep checking. See if they drop. I do think its odd that both on one side are hurting. Did you check the ground that is next to the fuel rails? Is it tight? Is it there? working?
You are also using the correct spark plugs right? Are you checking gaps?
What FPR are you using? What fuel pump are you using? What is the fuel pressure set at?
Have you tried to put a fresh set of plugs in and log the ecu?
You can always move stuff around and see if the problem follows..... But I think at this point its better to get a volt meter out and start checking things. Why risk hurting a good motor.
TwinscrollGT35R is offline   Reply With Quote
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 08:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 10:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 05:06 PM
