Welcome to the North American Subaru Impreza Owners Club Friday September 30, 2022
Old 10-23-2010, 08:55 PM   #1
69subaru360
Member#: 159682
1995 WRX
2015 F150
Default EJ20G dragstrip results with Rob's chip + now with dyno
I ran my car at the dragstrip today at the evo vs wrx shootout. It's a 95 coupe with 95 wrx ej20g engine, trans and rear diff. It was 2690 lbs on the scale today with me and and a 1/2 tank of gas. So I'm 170 so the car is about 2500 or so dry. Temp was about 60 degrees and traction was decent.
Go fast stuff is fmic, uel header, cone filter, walbro 255 fuel pump, 04 sti yellow 550 injectors, hallman mbc, evo 8 bpv, GD wrx coilpacks, bosal divorced 2.75" downpipe, 02 wrx midpipe, remus 2.5" axleback. I did have a 3" surewin turbo back exhaust on it for a while, but it was too loud and I took it off, I might be giving up 5-10 whp there but oh well, it attracted too much attention with the loud exhaust.
Timeslips-
It's really close to needing to shift to 5th in the 1/4. First run I did shift to fith and went [email protected] with a 1.79 60'. Next run I ran out 4th and went [email protected] It spun a little and the 60' was only 1.85. I also went a 12.8 when they dumped the tree on me and I didn't have full boost on the launch. I think it would run 12.5 with a 1.7 60' and finishing in 4th. The numbers back that up.
110 mph at 2690 lbs works out to 285 whp. Not bad at all.
This is about the best it can run now. At 18 psi, it maxes out the MAF at 4.98 volts at the top of 3rd and 4th gear. So right now it's MAF limited.
Rob's chip runs great, zero issues, it's never knocked, not even once. I'm running 93 octane E10.
With a 6K ecu and low boost, 12 psi earlier this year it went 13.2 @ 105, so the chip is a good improvement.
The car-
It pretty much looks stock.
Old 10-23-2010, 09:41 PM   #2
anothernord
Member#: 193703
Wow, a real sleeper. Well done.
anothernord is offline   Reply With Quote
Old 10-23-2010, 09:43 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
****ing sleeper, ****ing sweet.
makes me want to go 20g instead of eg.
So you are on the z32 route? does Rob do that?
eg33GC is offline   Reply With Quote
Old 10-23-2010, 09:49 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
He's working on the Z32 maf. When he figures it out, that is my plan. I know it could go 12.5 as is. With a perfect run, I don't doubt 12.4. With low 20's psi, I bet this could go 11's.
I don't really want to spend $1000 on a standalone for a car that I built for $3500 so far. So, I'll just wait.
I really like the EJ20G. Good power, no problems and cheap.
Old 10-24-2010, 01:12 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
just have to ask.. what RPM are you launcing at? and are you using launch control?
awesome numbers. i wish i could put down some numbers like that in my car...
maybe next summer...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 10-24-2010, 08:50 AM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Launching at 5500 rpm with launch control.
I was able to get a 1.7 60' a few times earlier this year without LC, but it's inconsistent, I prefer to use it.
Old 10-24-2010, 10:43 AM   #7
beaviscih
Member#: 123362
'93 Crapcan EJ22
FTW
Holy sleeper FTW! Very impressive.
beaviscih is offline   Reply With Quote
Old 10-24-2010, 09:43 PM   #8
MikeyMeyagi
Member#: 231209
1994 Legacy Wagon Mi
Matador Red Mica
nice times! sleeper car for sure too....
im running rob's chip in my hybrid 22t legacy wagon running 13.2 @101 with a 1.8 60', but my car weighs 3385lbs tho lol
12.5's for sure with the right conditions
MikeyMeyagi is offline   Reply With Quote
Old 10-24-2010, 11:39 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Yay for great results. Thanks for the plug.
Did you like LC at 5500? My base map is set for 5k. I think you are the only one who has asked to bump it up.
Just out of curiosity, how much do you think LC helps? I am not a 1/4 guy, so I have no feel for the scale of improvement.
-Rob
rob is offline   Reply With Quote
Old 10-24-2010, 11:43 PM   #10
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Dur....nevermind. I didn't read all the way down.
Old 10-24-2010, 11:48 PM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
-Rob
I like it at 5500, I'd rather have slight wheelspin than bog it.
As soon as you are ready with the Z32 maf, I want one.
Old 10-25-2010, 12:32 AM   #12
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
yeah I know, I have quite a few interested in bigger MAF support. You can blame Mike and the Legacy crowd for keeping me well distracted....
It will be coming.
-Rob
Old 10-25-2010, 06:19 PM   #13
jdmwrx94
Member#: 211619
94 jdm wrx
red
impressive!
jdmwrx94 is offline   Reply With Quote
Old 10-25-2010, 09:41 PM   #14
sniper512
Member#: 189923
1993 JDM WRX
I am impressed. I want a Z32 Tune as well :P. I may have to send back my ECU for a slightly raised LC rpm limit and the boost cut eliminated.
sniper512 is offline   Reply With Quote
Old 10-25-2010, 09:49 PM   #15
69subaru360
Member#: 159682
1995 WRX
2015 F150
Thanks everyone.
Video, this was the slowest run of the day.
Old 10-25-2010, 09:52 PM   #16
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
What you should ask is how he pulled that time and managed to keep his gearbox intact.
Sniper, if you can break an STi 6-speed with my 550 tune, I'm not sure a bigger MAF tune is such a great idea....I think we may need a collective intervention.
Old 10-25-2010, 10:01 PM   #17
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
A couple other thoughts....
Technically the MAF runs out at 5.12v (or at least that's where the ECU table runs out). So you still have a bit of headroom. Just make sure you measure MAF signal to the MAF signal ground (not chassis ground).
Also, if you REAAALLLY wanted to stretch it you can still max out the MAF as long as you keep a real *real* close eye on the AFRs. The ECU will simply stop adding more fuel so you will start leaning out from the last fuel map cells. Again, you have a little bit of headroom before things go bad.
Are you running into the rev limiter in 4th? Would it help to raise it a couple hundred RPM more to avoid that last shift?
-Rob
Old 10-25-2010, 10:02 PM   #18
69subaru360
Member#: 159682
1995 WRX
2015 F150
I think the LC is easier on the trans. It's more controlled, less room for operator error. My last 2 WRXs I drag raced using the LC and made probably 50 runs on each in the 12's and no trans failures.
I don't think I want to push it to the edge with the maf. The engine I have is a really nice, low mileage one and I don't want to break it doing something stupid. It runs perfect uses no oil, no leaks. My eventual goal is 11's. I know I can't pick up 6 tenths from what little headroom I might have on the maf, so it's not worth risking leaning it out and killing a piston to run 12.3 or so. With a bigger maf and low 20's psi, I think 11's is going to happen. I can wait.
I'm close to the limiter in 4th. But the engine doesn't really pull hard above 6500 rpm anyway. My math says I can go 116 or so in 4th, but I could be off.
Old 10-26-2010, 11:41 AM   #19
sniper512
Member#: 189923
1993 JDM WRX
Correction I exploded 2 5 speeds lol. The 6 speed is good just broke a driveshaft and rear axle once :P. I am sure the 6 speed will hold up just fine lol. Even with the ACT Stg3 clutch I don't worry about the actual transmission ya jerk lol.
Old 10-26-2010, 11:56 AM   #20
insaneimpreza
Member#: 83291
1998 RSTi
IAG Stg4 Extreme S366SXE
This thing is a super super sleeper, Ive met you a couple times at Island at Englishtown this past weekend, I have the Red GC8 with 02 WRX Swap.
insaneimpreza is offline   Reply With Quote
Old 11-09-2010, 11:46 PM   #21
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
haha sweet as sleeper! Good times! Those numbers I hit on my protuned stock turbo 06 Sti back in the day!
sizzflair is offline   Reply With Quote
Old 05-21-2011, 03:47 PM   #22
69subaru360
Member#: 159682
1995 WRX
2015 F150
Ran in on a dyno today.
279 hp 288 ft lbs tq
Dynojet 80 degrees out.
It's not as much of a sleeper anymore. I put on 6 spoke RS wheels with 4/2 pot brakes, P1 springs, AGX struts, Rallitek swaybars and some whiteline stuff. It handles and stops now as well as it goes.
http://s97.photobucket.com/albums/l229/tomrichdale/?action=view&current=VID00003.mp4
Old 05-23-2011, 03:23 AM   #23
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
nice job, i cant wait to see how my build is going to effect the HP... because before i had the 550tune with FMIC. soon it will be semi built with fmic.. hoping for 300awhp. my intake/exhaust mani are PnP, and my head in/ex ports PnP as well... idk we'll see
what happen in that lil hick-up right around 4.5k rpm
azn0boi04 is offline   Reply With Quote
Old 05-23-2011, 08:40 AM   #24
69subaru360
Member#: 159682
1995 WRX
2015 F150
I think the clutch might have slipped a little on the dyno, I smelled clutch. It never does on the street though.
Old 05-24-2011, 04:04 PM   #25
wagonryan
Member#: 163756
1996 R/RA
vtec kicked in
wagonryan is offline   Reply With Quote
'06 WRX Motor with a chipped piston,worth saving the motor? salvage Newbies & FAQs 15 10-24-2010 03:25 PM
Rob's EJ20G dyno results part 2 rob Pre-2002 Factory Turbo Powertrain 60 01-26-2010 10:22 PM
APS stage 1 kit dragstrip results jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-08-2001 06:54 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
