Welcome to the North American Subaru Impreza Owners Club Wednesday August 10, 2022
Old 10-24-2010, 03:04 PM   #1
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
This is going to be the new location for me to post updates and pictures of my moneypit
All the recent work was done by Dominic, Craig and Dave at Maxwell Power Services (MPS) in Marysville, WA and I can't thank them enough for all the hook-ups and endless hours of free or discounted labor
The awesome rear sedan fender flare conversion was done by Johann Ave of Girodisc/ Performance Ave.
Engine bay:
Current Configuration:
The following is a list of the mods as the car sits currently. For most up to date pics, check the latest pages on this thread.
Base: Complete salvaged 05 STi swap in a wagon body. (yes everything ) Swap done by Steve at Aerosim Research in Costa Mesa, CA !
Exterior:
***8226; ABW Motorsports 45mm 8pc Fender Flares
***8226; APR GTC-200 Custom 61" Airfoil with Singular Motorsports Endplates
***8226; Beatrush Carbon Brake Ducts
***8226; BMSPEC Custom Wing Risers
***8226; Custom Painted Seibon Carbon Fiber Hatch
***8226; Custom Painted Seibon Carbon Fiber Hood
***8226; Ebay Performance Carbon Canards
***8226; JDM STi HIDS
***8226; JDM STi Side Markers
***8226; Kaminari Aerodynamics Carbon Front Air Dam
***8226; Kaminari Aerodynamics Carbon Front Splitter
***8226; Kaminari Aerodynamics Carbon Rear Apron
***8226; Kaminari Aerodynamics Carbon Side Strakes
***8226; Oswald Performance rear lightweight bumper beam with Rennen rear tow hook
***8226; STi Fenders and Rear Quarters
***8226; STi Front Bumper cover
***8226; VTR Tint (50% front, Limo rear)
Suspension:
***8226; Cobb adjustable Rear Swaybar Bracket
***8226; Covert Performance Tubular Front Subframe
***8226; Ground Control Front Camber/ Caster Plates
***8226; Group-N Bushings everywhere
***8226; Kartboy Endlinks F+R
***8226; Kartboy Rear Subframe Outrigger Bushings (Race)
***8226; MSI Trailing Arms
***8226; Oswald Performance Rear Triangle Brace
***8226; Perrin P.S.R.S.
***8226; Q-rack 11.5:1 steering rack
***8226; RaceComp Engineering Tarmac 2 Coilovers with Swift Springs 600 F/ 500 R
***8226; RaceComp Engineering 25.5mm Swaybars F+R
***8226; TSSFab Rear Diff T Frame (www.tssfab.us)
***8226; TSSFab Rear Sub Frame
***8226; TSSFab Spherical Bearing Lateral Links
***8226; TSSFab Front Engine Cradle
***8226; Turn In Concepts Trailing Arm and Lateral Link Bushings
***8226; Vorschlag Rear Camber Plates
***8226; Whiteline Balljoint Extenders
Suspension settings:
***8226; Camber: -3.1 F -2.0 R
***8226; Caster: 4.8 degrees
***8226; Rideheight: 14" F 13.75" R
Brakes:
***8226; 05 STi Brembo's, Custom painted silver with Girodisc Logo's
***8226; ARP extended wheelstuds
***8226; Carbone Lorraine (CL Brakes) RC5+ F+R for DD, RC6 Front and RC5+ Rear for the track.
***8226; Cusco Master Cylinder Brace
***8226; Girodisc 2 PC rotors F+R with custom anodized red hats
***8226; Motul RBF600 fluid
***8226; Prova Brake Cooling Ducts
***8226; Quantum Super Touring Brake Cooling Kit
***8226; RooDucts
***8226; Stoptech Stainless Brakelines
Engine/head specs:
Maxwell Power Services 2.6L Long Rod Track Series Block:
***8226; 2.6L STI semi-closed deck case (8.5:1)
***8226; ACL rod bearings
***8226; ARP case bolts
***8226; Custom JE Pistons (102.5 mm)
***8226; Fully balanced & blue printed
***8226; JE Pro Seal Piston Rings
***8226; King Main Bearings
***8226; Maxwell Power Services shimmed STI oil pump
***8226; Maxwell Power Services (Seanz) +2mm Rods
***8226; Subaru 79mm Nitrited crankshaft
***8226; STI Group-N Kevlar timing belt
***8226; Subaru Factory engine gasket kit
***8226; WRX water pump
RAW Performance (Axis) Signature Series heads:
***8226; Kelford "B" 264 camshafts
***8226; Custom hand porting work
***8226; 5-Angle intake valve job
***8226; 3-Angle & radiused exhaust valve job
***8226; Ferrea oversized intake valves (+1mm)
***8226; Ferrea oversized Inconel exhaust valves (+1mm)
***8226; Ferrea dual valve springs
***8226; Valves lapped into head
***8226; Titanium retainers- new spring seats
***8226; Subaru valve stem seals
***8226; Subaru Shimless Buckets
***8226; ACPT Carbonfiber Drive Shaft
***8226; ACT SB10-HDSS Extreme Street Clutch and XACT Prolight flywheel
***8226; Accusump 2QT with 55-60 PRO EPC Valve
***8226; APS DR525 FMIC with Custom Crawford Performance 2" hot side and Maxwell Power Services 3" cold side FMIC Piping kit.
***8226; Boomba Racing 3" DBW Throttle Body
***8226; Braille racing B14115 11lbs battery and mount
***8226; Covert Performance Twinscroll manifold, uppipe and downpipe, Swaintech White Lightning Ceramic Coated
***8226; Crawford Performance Air oil separator
***8226; Cusco Transmission Mount
***8226; Garrett GT3582R with Forced Performance HTA 82 upgrade and Swaintech White Lightning Ceramic Coated Twinscroll 1.06 hotside.
***8226; JIC Spartan DE Type 1 (Bullet style) Full Titanium Exhaust
***8226; Kartboy pitch stop mount
***8226; Killer B Oil pan, Baffle and pick up
***8226; KSTech 16mm Phenolic Spacers
***8226; KSTech 83mm mafless CAI with Filter
***8226; Link G4 PnP EMS
***8226; Mishimoto Oil Filter Sandwich Plate with Thermostat
***8226; Outfront Motorsports Modified 2.5i NA Intake Manifold
***8226; P&L braided Power steering line
***8226; Perrin Oil Filter Sandwich Plate
***8226; TIGWerks Solid Motor Mounts
***8226; Turn in Concepts Oil Cap
Fuel Setup:
***8226; Deatschwerks DW300 In tank fuel pump
***8226; Fore Innovations 128mm Inline Fuel Filter with Microglass SSD (anti-static) Filter Element
***8226; Fore Innovations -8AN PTFE Fuel Hose and Fittings
***8226; Fore Innovations F2i Fuel Pressure regulator
***8226; Fragola -6AN PTFE Fuel Hose and Fittings
***8226; IAG Top Feed Fuel Rails
***8226; Injector Dynamics 1700cc Top Feed Injectors
***8226; MA Performance UNI-ST-2 Dual Pump Surge Tank
***8226; Radium Engineering Fuel Pulse Damper
***8226; Radium Engineering Secondary Fuel Pump Pressure Switch
***8226; Radium Engineering Venturi Pump
***8226; TI Automotive Walbro TIA485-2 F90000267 Fuel Pump 450LPH
***8226; Zeitronix ECA E85 Flexfuel setup
Interior:
***8226; AEM UEGO AFR Gauge
***8226; Complete Customs Full Welded Roll Cage with BSCI FIA 8857-2001 Type A Homologated Roll Cage Padding
***8226; GFB STi Super Short Shifter (with all the Kartboy bushings)
***8226; Key!s Racing 325mm Flat Type Suede Steering Wheel
***8226; PDE rally pedals
***8226; Planted Aluminum Seat Brackets
***8226; Schroth Profi III-6 6pt harness (Driver & Passenger)
***8226; Sparco Circuit seat (Driver)
***8226; Sparco Pro2000 seat (Passenger)
***8226; Subtle Solutions Ashtray gauge bezel
***8226; Turn in Concepts shifter bushing kit
***8226; WC Lathe werks Stainless steel sphere shift knob with 2.5" extension
***8226; Works Bell Rapfix 2 Steering Wheel Quick Release
Wheels:
***8226; Enkei RC-T4 White 18x9 +35 with 265/35/R18 Federal 595 RS-R (Street/ Track)
***8226; FFD motorsports black EVO2's in 18 x10 +32 with 285/30/R18 Hankook Ventus TD Z221 (hard) (Track)
With all of this it was tuned by Dominic at Tier One Imports in Liberty Lake, WA and it puts down 526 AWHP and 560 AWTQ
[/font][/color]
leonbmx is offline   Reply With Quote
Old 10-24-2010, 03:04 PM   #2
leonbmx
Member#: 82864
Detail of fuel setup:
Under the enginebay:
Driver and Passenger side (it's all cleaned up now):
From the rear:
Custom painted CF Hatch:
Right before the body parts swap:
In Winter trim:
Old 10-24-2010, 03:04 PM   #3
leonbmx
Member#: 82864
Few pics I found just now
Old 10-24-2010, 03:05 PM   #4
leonbmx
Member#: 82864
Old 10-24-2010, 03:05 PM   #5
leonbmx
Member#: 82864
and another one
Old 10-24-2010, 05:12 PM   #6
lowrider89
Member#: 143022
2005 modded S4
i cant imagine driving a 500 WHP car.... 350 WHP is all i need to have a blast
nice car
lowrider89 is offline   Reply With Quote
Old 10-24-2010, 05:15 PM   #7
jgardner9000
Member#: 219549
2009 STi
Leon quit making me look bad Always loved your car keep it up
jgardner9000 is offline   Reply With Quote
Old 10-24-2010, 07:34 PM   #8
JDM_OBP
Member#: 105409
2017 WRX
stock as a rock
sick wagon man. love the setup under the hood.
JDM_OBP is offline   Reply With Quote
Old 10-24-2010, 07:37 PM   #9
xfactor78
Member#: 189619
2006 Evo IX MR
wow craaazy sleeper! Keep up the good work. Just curious if you've ever tracked at Pacific Raceways, if you do what do you run?
xfactor78 is offline   Reply With Quote
Old 10-24-2010, 07:48 PM   #10
DumbstixLars
Member#: 205942
2003 WRX,00 2.5RS
2007 2.5i, 04 STI, 99 OBS
Wow, all that in a wagon. I am definitely jealous.
DumbstixLars is offline   Reply With Quote
Old 10-24-2010, 07:54 PM   #11
leonbmx
Member#: 82864
I've been to Pacific, but not with this setup yet. You mean the roadcourse or the dragstrip?
If it's the latter, I don't do drag racing, I suck at it and it's pretty rough on the car...
After all the $$$ I spent, I'd like to keep it in one piece for a while, so I only do trackdays and auto-x.
Old 10-24-2010, 08:30 PM   #12
P-iff
Member#: 201568
'05 rotated STi
wrb
^thumb up.
nice setup!
P-iff is offline   Reply With Quote
Old 10-24-2010, 08:34 PM   #13
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Awesome. Love the STI CF poking thru :P
freeride is offline   Reply With Quote
Old 10-24-2010, 09:00 PM   #14
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
damnnn fast wagon!
wherez the videoz?!
blakkboxer is offline   Reply With Quote
Old 10-24-2010, 09:46 PM   #15
xfactor78
Member#: 189619
2006 Evo IX MR
meant the roadcourse
Old 11-13-2010, 11:59 AM   #16
leonbmx
Member#: 82864
updated pics
Old 11-13-2010, 01:03 PM   #17
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
I know it's a small detail amongst how wild your car is but I've never seen anyone paint their washer fluid tank black like that.. it looks really good!
N'CTRL is offline   Reply With Quote
Old 11-13-2010, 01:11 PM   #18
leonbmx
Member#: 82864
courtesy of Maxwell Power Services, they came up with the idea and do it on all their shop cars
Old 11-13-2010, 01:19 PM   #19
SNClocks
Member#: 263679
Default Omg
Beautiful Car!
SNClocks is offline   Reply With Quote
Old 11-13-2010, 02:16 PM   #20
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
You have a supreme taste in wheels. I have a silver 92x and want all three of your setups, but alas, cannot. Your FS thread was perfect, minus the bolt patterns!
Thanks for giving the wagon guys something to brag about!
Zee Biker is offline   Reply With Quote
Old 11-13-2010, 02:34 PM   #21
5432gone
Member#: 187164
2003 Holset bug-I
Beautiful ride man. Love high hp wagons...
5432gone is offline   Reply With Quote
Old 11-13-2010, 04:27 PM   #22
suby15
Member#: 189017
2004 WRX vf48'd
291whp 282wtq
Badass Sleeper
suby15 is offline   Reply With Quote
Old 11-13-2010, 07:43 PM   #23
yanper
Member#: 263879
04 STI
02C
nice wagon!
yanper is offline   Reply With Quote
Old 11-13-2010, 08:00 PM   #24
daleyswanson
Member#: 205604
87J Robinson
R22
You were out at pacific raceways for the Olympus Rally media event right?
daleyswanson is offline   Reply With Quote
Old 11-13-2010, 08:14 PM   #25
leonbmx
Member#: 82864
Yup, that was us That was a lot of fun too, I like Pacific Grand Prix!
My ultimate stealth machine. 2005 Built 35R Wagon BiggSean Member's Car Gallery 127 09-04-2011 05:57 PM
built motor 450-500 awhp?? simon930 Built Motor Discussion 43 10-13-2010 03:30 PM
2004 STi : 276 AWHP / 333 AWTQ hdempsey Proven Power Bragging 6 09-16-2010 08:46 PM
FS West LA: 2005 OBP STi, $15,500 80,500 miles. Sanchez SCIC Private Classifieds 9 04-11-2010 12:24 PM
...500+ AWHP and cluches...Need help... WipeOutXXL Transmission (AT/MT) & Driveline 20 02-28-2006 04:58 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
