Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 06-29-2002, 08:15 PM   #1
ringer
Member#: 4121
2005 impreza obs
grey/grey
Default rattling heat shields...
are rattling heat shields a common problem....i've got something rattling loose(havn't got underneath to find the exact problem)...want to know if there's any problems with removing them.
ringer is offline   Reply With Quote
Old 06-30-2002, 04:43 AM   #2
tonytiger
Member#: 3844
1993 Legacy 1.8
I have them too. I'll be welding them someday. My oppinnion is not to remove the heat shields.
The upper heat shields protects your feet from getting warmed and the lower is good in case of you hit the cars belly on the ground on a holiday trip or so. Cats are fairly easy to broke (a good excuse to by a free flow cat
Actually I have one of my exhaust pipings metal hangers broken as well. Don't as how
Fixing them shouldn't be a major operation. The heat shield on my car is broken at one of the four corners it has and it should be just clean it up and hit with the MIG. Shouldn't cost much if done in a work shop...
tony
tonytiger is offline   Reply With Quote
Old 06-30-2002, 09:00 PM   #3
goobie
Member#: 8273
2006 WRX Wagon
Default Use hose clamps.
Buy a couple of stainless steel hose clamps and tighten them around the heat sheild. This will solve your problem and allow you to keep your heat shields on. The best part is it will only cost you around $2.00
I had a heat shield rattle on one of the cats and got rid of it that way.
Chad
goobie is offline   Reply With Quote
Old 07-01-2002, 12:40 PM   #4
Jademonkey
Member#: 9213
2000 RS
Red
There could also be pebbles stuck in the cat shielding. I had this awful buzzing sound, thought it was pinging. I took off the shielding, and out came a handful of pebbles. They bounce around in there, and are annoying as hell!
Jademonkey is offline   Reply With Quote
Where to have an intake heatshield made in SoCal?? AM55 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-01-2010 02:48 AM
FS: (IL) TDO4, Spt Turbo Heat Shield matt107 MWSOC Private Classifieds 8 06-10-2010 01:36 AM
FS : (IL) Spt Turbo Heat shield matt107 Engine/Power/Exhaust 5 06-08-2010 02:43 PM
Do most Subies have rattling heat shields? Snoopy Off-Topic 32 11-24-2006 05:08 PM
Heat Shield Rattle Stickee Technical Forum Archive 8 09-01-2000 01:22 AM
