Welcome to the North American Subaru Impreza Owners Club Sunday August 19, 2018
Old 11-03-2010, 10:02 PM   #1
umscooby
Member#: 50902
05 STi
Default Intermittent Loss of Power Steering. Has this ever happened 2 U?
Out of no where I have an intermittent steering problem. My car will suddenly become VERY hard to turn while I'm driving. Steering will be normal and easy and then suddenly it becomes hard as hell. I can barely turn the wheel in either direction with both hands while rolling! It feels like the power steering is working against me! Super dangerous. It also seems like it happens more when I am decelerating. Is this my pump going? I really help diagnosing this. If anyone has any input please chime in or feel free to ask for more detail.
Car is '05 STi with 80k. I siphoned the old PS fluid and put in new approx. 5 months ago.
**Final diagnosis and fix posts 10 & 12 below**
umscooby is offline   Reply With Quote
Old 11-03-2010, 10:33 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Belt slipping perhaps?
Old 11-03-2010, 11:32 PM   #3
umscooby
Member#: 50902
05 STi
I replaced both belts with new NAPA ones last year. I have actually been wondering if they are too tight. Don't think they'd be slipping.
I'm thinking it's very possible the belt was installed to tight and now a bearing or something else has gone bad. If I remove the belt is there anything I should be looking for besides squealing bearings? What should the power steering pump feel like when I try and turn it by hand?
Old 11-03-2010, 11:37 PM   #4
fastwrx25
Member#: 126441
03 bugeye
check the belts again, its possible if the napa belt sucks that it could be worn by now. do the twist test to see how tight they are.
clamps to the hoses on the ps reservoir tight?air getting into system?
fastwrx25 is offline   Reply With Quote
Old 11-03-2010, 11:50 PM   #5
umscooby
Member#: 50902
05 STi
^ the NAPA belts are the same as OEM IIRC and what most on here recommend using. Never the less they are in great shape.
Air getting to the system is another avenue I need to explore further.
Old 11-03-2010, 11:55 PM   #6
Csquared33
Member#: 198053
02 WRX Wagon
www.efilogics.com
if air is in the system you'll hear a whine (sometimes) and you'll feel a shimmy in the wheel
Csquared33 is offline   Reply With Quote
Old 11-04-2010, 12:41 AM   #7
umscooby
Member#: 50902
05 STi
^ thanks, I am getting a slight squeal when idling but it too is intermittent.
Old 11-04-2010, 02:40 PM   #8
umscooby
Member#: 50902
05 STi
Rechecked belts, they are perfect. PS pump spins smoothly. No air bubbles in the reservoir. My fluid level hasn't budged in months. Same intermittent loss of PS while driving.
Anything else I should do? Something trapped in the line or a bad pump is all I can come up with.
Old 11-04-2010, 03:47 PM   #9
Web Foot STi
Member#: 39086
2004 STi
Try replacing the factory band clamps with real hose clamps. There is a history of them being a problem for some.
G/L
Web Foot STi is offline   Reply With Quote
Old 11-11-2010, 12:20 AM   #10
umscooby
Member#: 50902
05 STi
G/L
Ended up being this.
Old 11-12-2010, 01:44 AM   #11
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
I just had this happening too.. Had a light front-end tap and had it inspected by the insurance guy 'just in case' and he was really nasty saying it was totally unrelated blah blah..
I notice the whine/grumble and then it's 'difficult' to steer for a few seconds. I've had it parked for a bit while I save up some repair cash, but I looked at it closely today and it was a bit low on fluid, plus there was lots of moisture around the pump. I noticed also a bit of a bruising on the plastic where it may have compressed the power steering fluid reservoir when the front end was hit, causing it to ooze out/leak some fluid/suck in some air?
I have some band clamps.. I can top up the fluid and swap the clamps.. ?
420WRX is offline   Reply With Quote
Old 11-12-2010, 07:21 PM   #12
umscooby
Member#: 50902
05 STi
Plan on loosing some fluid. I just poured all mine out in a coffee can and replaced it with new. Do the clamps and I'm sure you will be fine.
I was able to pinpoint which one of my oem clamps was failing and thus allowing air to be slowly sucked in. Which is also the cause of the squealing sound btw.
Drain fluid.
Replace all 4 clamps. Cut a bit of hose off when you do this.
Replace fluid.
Start car and turn wheels. On or off the ground, your call.
Check and top off fluid.
Drive around the block once or twice to get remaining air out.
Check and top off if needed.
This should be stickied.
Not my lame instructions but the clamp problem itself. Seems to be quite common. Could be a real safety issue.
...mods... I'd be happy to make a sticky on this.
Old 11-22-2010, 12:49 AM   #13
420WRX
Member#: 27752
If the fluid gets low doesn't the air get in that way too?
is my power steering pump supposed to be this loud? XanRules Service & Maintenance 9 04-18-2010 01:45 AM
Is my power steering pump bad? or is it something else? psychoskip Brakes, Steering & Suspension 11 01-25-2010 02:46 AM
Is my power steering pump gone? BKscooby Newbies & FAQs 13 01-18-2010 10:19 AM
HELP!!!My Power Steering PUMP is SQUEELING!!! subaman81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-24-2006 10:55 PM
DAMN IT!!! My power steering pump is out and.... system_s4000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-22-2002 06:41 PM
