Welcome to the North American Subaru Impreza Owners Club Saturday June 3, 2023
Old 11-04-2010, 02:25 PM   #1
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
Default Knock sensor frequency?
Hi folks,
Looking to see if anyone had any solid details on how the 02 WRX knock sensor functions? Does it hone in around 6kHz or 13kHz (or somewhere in between)?
Trying to setup an external sensor, and am looking to make sure I get the settings "right".
Geek Guy is offline   Reply With Quote
Old 11-06-2010, 06:30 PM   #2
2milehi
Member#: 81633
'98 RS-T
Here is an in depth look at a 2.5 subie. The knock will be at a higher frequency than the 5.9 kHz I found.
http://www.msextra.com/forums/viewto...p?f=67&t=36089
2milehi is offline   Reply With Quote
Old 11-07-2010, 01:38 AM   #3
Geek Guy
Member#: 8151
2002 WRX Rally Car
So, calculated frequency for at stock-bore EJ20 is 6.2kHz. I'm using the Vi-PEC digital knock rig which allows for an adjustable narrow-band filter.
Right now, I've got it centered on 6kHz (+/- 1kHz at the corners), so the whole detectable range is 5kHz to 7kHz.
But the documentation mentions something about v7 WRXes onwards using a 13kHz knock sensor. (which would make sense, as it's closer to the 2nd harmonic).
Does anyone know if the stock sensor is a 1st or 2nd harmonic unit? I guess I could hook up the laptop and try to induce knock (while driving around).
Thoughts?
-E
Old 11-07-2010, 01:59 AM   #4
2milehi
Member#: 81633
'98 RS-T
That is your best bet, capture some knocks and look at the spectrum of the signal. Then build the circuit accordingly.
Old 11-07-2010, 01:02 AM   #5
Geek Guy
Member#: 8151
2002 WRX Rally Car
Well, nothing to build - it's a pretty slick entirely integrated (adjustable filter) box:
http://www.vi-pec.com/techdata/Vipec...kAmplifier.pdf
Old 11-07-2010, 11:28 AM   #6
2milehi
Member#: 81633
'98 RS-T
Slick little unit. Looks like it has features that I have yet to come up with on the one I have been designing from scratch. The frequency spread seems a little wide for a narrow band filter. It looks more like a notch filter. Curious, how much did that unit set you back?
Old 11-07-2010, 11:43 AM   #7
Geek Guy
Member#: 8151
2002 WRX Rally Car
I think the whole unit was something like $400? Bought it rolled into the price of my ECU (also a Vi-PEC). Went with this unit as it as a window in/out so the ECU pulls the knock data from the sensor when it's ready.
Old 11-07-2010, 11:46 AM   #8
Geek Guy
Member#: 8151
2002 WRX Rally Car
Do you think it's better to be high or low on the notch filtering in this case? eg, 5-7kHz (0.8 kHz above, 1.2kHz below) or 6-8kHz (0.2kHz below, 1.8kHz above) for headroom?
Most knock instances have a noise range that STARTS at the calculated value, right? or does it bleed below? I can't tell from the graphs you posted in the other thread?
Old 11-07-2010, 01:26 PM   #9
2milehi
Member#: 81633
'98 RS-T
Better to have the calculated frequency in the center of your filter. Temperature does affect the knock frequency so better to have some room for drift. So I would pick the 5-7 kHz filter.
As for your second question from what I have seen the knock frequency starts at approximately the calculated frequency. In the below pic, I recorded detonation from my knock sensor. Each lighter colored vertical band represents a knock event. From what I observed there was always a signal at 5.9 kHz. Because of the placement of the knock sensor, each cylinder has a different knock sound to it.
Here is the spectrum of the engine with no knock.
Here is the spectrum of the engine with a small knock event.
Here is the spectrum of the engine with large knock event.
It was pretty obvious for me to go after 5.9 kHz.
Old 12-14-2010, 07:08 PM   #10
dewfall
Member#: 123626
2003 WRX
Sonic Yellow
Nice work. What freq analysis software did you use to log the data, and how did you connect to get the data? Thx
dewfall is offline   Reply With Quote
Old 12-15-2010, 04:12 PM   #11
2milehi
Member#: 81633
'98 RS-T
I recorded the signal from the knock detector via the microphone on my laptop. I'll chime in later with more info on how to do this.
Old 12-15-2010, 04:17 PM   #12
Built Industries
Member#: 33839
Very nice info!
Great post
Built Industries is offline   Reply With Quote
Old 12-15-2010, 09:42 PM   #13
2milehi
Member#: 81633
'98 RS-T
Here is the spectrum analyzer
http://www.electronics-lab.com/downl...003/index.html
Here is a *.wav analyzer that generated the smaller spectrums
http://www.music-editor.net/download/index.htm
How to build the interface circuit.
http://www.electronic-engineering.ch...n/connect.html
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
Jorge's Daily hash: Knock sensor, false knock, filters and electronics... RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 09-10-2003 10:49 AM
knock link or msd knock sensor? wrxtcy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2002 07:21 PM
