Welcome to the North American Subaru Impreza Owners Club Wednesday January 17, 2018
Old 06-17-2002, 02:24 AM   #1
Joseph
Member#: 15987
2002 Legacy GT Sedan
Black Granite Pearl
Question what is this?
I was looking at the compartment where the jack is today and I notice that there was a hose in there. It was a clear plastic hose just hanging there. The bottom came out when I pulled it, but the top was attached to something. I don't know if it is in the wagons but has anybody else with a sedan notice this before. And if you have do you know what is/is for? I am curious. I even looked in the manual for it but there was nothing in there about it.
Joseph is offline   Reply With Quote
Old 06-17-2002, 10:42 AM   #2
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
It's probably just a drainage tube to get rid of any water that collects within the body, or from the sunroof. By chance, why did you want to pull it out?
Jason
2.5GT is offline   Reply With Quote
Old 06-17-2002, 11:04 AM   #3
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
The clear tube is the overflow tube that originates from the sunroof splash area. It connects to the sunroof on one side, and connects to a drain near the bottom of the rear quarter panel.
Try to put it back where you found it, and try to locate the drain tube / hole. Otherwise you may end up with a 1/4 panel full of water.
Hope this helps.
JoeT is offline   Reply With Quote
Old 06-18-2002, 01:40 AM   #4
BlackGT00
Member#: 4658
2000 Legacy GT
Black granite pearl
You guys are all crazy. That's the recirculating power tube, I replaced mine with a 2" chrome unit and gain twenty HP.
Kevin
( if people can't find you handy, they should at least find you to be a jackass)
BlackGT00 is offline   Reply With Quote
Old 06-18-2002, 01:43 AM   #5
JoeT
Member#: 3956
Titanium
I guess, Kevin's recirculating power tube is letting too much Carbon Monoxide into the cabin.
Since neurons don't re-produce, I guess Kevein ( BlackGT00 ) is stuck in his reduced mental state.
Old 06-18-2002, 01:52 AM   #6
Hiroki Tada
Member#: 8048
Joesph: I havent seen any hoses yet and I've used my jack a few times to help fix flats. Though I did remember feeling my hand "catch" onto something in there.
JoeT: Is the TSC board server having some problems? I cant seem to get on all day.
Hiroki Tada is offline   Reply With Quote
Old 06-18-2002, 01:54 AM   #7
JoeT
Member#: 3956
Titanium
Hiroki,
There are problems, but I don't know what they are. I'm sure that James and the ISP crew are working on it.
Old 06-28-2002, 10:55 PM   #8
SubbyRS
Member#: 17193
1991 Legacy RS
Got an electric antenna? It's the drain for that....
SubbyRS is offline   Reply With Quote
Old 06-28-2002, 11:33 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
But the antenna is on the opposite side from the jack? Are you telling me they run a drain from one side all the way around the door to the other side
ciper is offline   Reply With Quote
Old 06-29-2002, 10:49 PM   #10
jslegacy
Member#: 17034
2005 Lotus Elise
Mercedes C230 6spd
it is for the antenna. I removed mine a few months ago and it is attached to the motor.
jslegacy
jslegacy is offline   Reply With Quote
Old 06-29-2002, 11:38 PM   #11
SubbyRS
Member#: 17193
1991 Legacy RS
If I open the bootlid (trunklid) the jack is on the left in a little compartment and the electric antenna is on the left as well....I assume USDM are the same??
Old 06-30-2002, 03:40 AM   #12
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
My vote is for the antenna drain too... especially if it's on the left side right beside/below the jack compartment on the left side. Just put it back sir and everything will be okay.
Br, Dale
Subietonic is offline   Reply With Quote
Old 06-30-2002, 05:23 AM   #13
SSR
Member#: 14760
2002 Legacy GT LTD
Black Granite Pearl
i have that hose in my jack area too
it could be used to steal gas from other cars maybe?
SSR is offline   Reply With Quote
Old 06-30-2002, 05:32 AM   #14
Joseph
Member#: 15987
Black Granite Pearl
SSR: thats what i was thinking…a syphon hose. I am thinking it is a drain tube of sorts since i seen some water or the water film stuff in the tube (and yes i did put it back/reattach it). Not for an antenna though, since the antenna is in the back window. Anyway just curious
Old 07-01-2002, 10:13 AM   #15
waldrm
Member#: 14552
1999 Outback 5Dr
Dk Blue
It is the drain tube for the power antenna; drain tubes fore the sunroof run down the A and C pillars on both sides.
waldrm is offline   Reply With Quote
Old 07-01-2002, 12:38 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
My Jack is on the same side as my washer fluid, OPPOSITE of that from my antenna.
I didnt realize subaru moved the antenna around.
what is this part called? what is it's part number? OUScooby Private 'Wanted' Classifieds 8 04-21-2010 05:08 PM
What is this connector, and why is it unplugged?? Kwyjibo Electrical & Lighting 7 09-24-2003 02:21 AM
What is this part in my fuel system. Can I remove this STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-06-2003 01:07 PM
what is this? is it a good deal? coilovers cheap? mcu81 Tri-State Area Forum 17 01-01-2002 12:24 PM
('93-'01) what is this and what does it do? shimstock Impreza Forum 4 04-10-2001 10:53 AM
