Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 11-23-2010, 02:20 PM   #1
silence2-38554
Member#: 121459
Default Interesting difference between stock WRX clutch & OEM Exedy replacement...
I tried doing a search & came up empty handed on this one. I recently installed a new Exedy OEM clutch kit in my '02 WRX. One thing I noticed is that the old disc had a sort of double spring setup with one small diameter spring inside of the larger one. The OEM replacement just has a larger single spring setup. How will this affect drivability / performance / feel, etc?
Pics:
silence2-38554 is offline   Reply With Quote
Old 11-24-2010, 11:39 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
The OEM clutch has a finely tuned spring rate that they achieved through using two springs. The Exedy replacement only uses one spring to get the same effect.
I'd put $5 down that I wouldn't be able to tell there was a difference between the two. I don't think there will be any difference in driveability or performance.
speedyHAM is offline   Reply With Quote
Old 11-25-2010, 11:10 AM   #3
sleeperrex
Member#: 19466
2002 wrx/hybrid
Could it explain the annoying deceleration noise that some people get? Including me.
sleeperrex is offline   Reply With Quote
Old 11-26-2010, 08:01 AM   #4
05-rsx
Member#: 101188
MY07 WRX Wagon
^Apparently, yes.
Some of the guys over here in Australia have screwing around for the ebst part of 3 years over this.
http://www.rexnet.com.au/forum/index...c=78962&st=180
05-rsx is offline   Reply With Quote
Old 11-26-2010, 02:29 PM   #5
usfsfire42
Member#: 242630
.. Flu shot
technician.
Just read that link you posted. Thats amazing to see the difference in the two cluthes the exedy oem replacment and the subaru oem replacement. I guess its better to go with the oem one. Good info
usfsfire42 is offline   Reply With Quote
Old 11-26-2010, 05:10 PM   #6
sleeperrex
Member#: 19466
2002 wrx/hybrid
Originally Posted by 05-rsx View Post
^Apparently, yes.
that is amazing. Thanks for the link
Old 11-27-2010, 04:42 AM   #7
fastwrx25
Member#: 126441
03 bugeye
My question is would it be possible to use a dbl spring oem disk with the daiken kit pressure plate. That Australian thread has good info.
fastwrx25 is offline   Reply With Quote
FS 310 : WRX Exedy Organic Clutch & OEM Flywheel. Used for 900 miles Lazyxturb0 SCIC Private Classifieds 6 09-12-2008 09:41 PM
What's the difference between stock WRX and STI exhaust? joker11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-09-2008 07:12 AM
Difference between stock WRX and STi axlebacks? mummer43 Normally Aspirated Powertrain 12 10-24-2006 08:37 PM
difference between stock WRX turbo vs. vf-23 wRxbeater11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-08-2002 12:52 AM
Any interest in 4 stock WRX rims & Tires? Philly WReX Tri-State Area Forum 16 01-14-2002 10:14 AM
