12-19-2010, 07:04 PM | #1 |
Member#: 94268
TXIC
Vehicle:1995 JDM STi RA ver2 2010 Exige S240 |
Will GD rotated kits fit GCs?
Hey guys,
so there's a possibility that I may do a complete build because I've had enough of tinkering around and have more headaches. I'm looking into maybe a GT30R or similar sized kit for a 450whp build. I'm still working on the details as far as the engine goes (probably built G heads with 2.1-2.15 closed deck block). I'm not planning on making a drag car or anything, but I figured if I was to get a new engine, then it wouldn't make sense to run the stock 16G. I'm looking into AMS and UR (i think there are other kits out there, so I'm still looking. Anyone running a rotated kit of some sort on the GC?
12-19-2010, 07:43 PM | #2 | |
Member#: 15116
South East
Vehicle:2000 Ver6 STi Type-R EJ257/GT35R |
RHD? Most kits are not going to clear the brake master or clutch reservoir. Only real option is an APS RHD specific setup or custom. I went with a stock location ATP35R for my build (RHD GC8). Ryan |
12-19-2010, 07:50 PM | #3 |
Member#: 159682
NESIC
Vehicle:1995 WRX 2015 F150 |
nevermind forgot yours is rhd
12-19-2010, 10:02 PM | #4 |
Member#: 94268
TXIC
ah. Thanks for your input Ryan. What did you do about the 90 degree turbo inlet? Did you go rotated or?
12-20-2010, 03:17 AM | #5 |
Member#: 15116
South East
12-21-2010, 08:56 PM | #6 |
Member#: 159756
International
Vehicle:1998 wrx sti white 10.5@134 |
it can work but it will take a lot of fabricating of stuff. i had bought the perrin rotated turbo kit and had to have a welder do it up to fit.
to save the hassle and money maybe it will be better to try and order a kit from england or australia. |
12-21-2010, 10:22 PM | #7 |
Member#: 94268
TXIC
hmm... what kind of fabrication did you have to do?
Maybe I can look into Japan? |
12-21-2010, 10:55 PM | #8 |
Member#: 159682
NESIC
12-21-2010, 11:03 PM | #9 |
Member#: 94268
TXIC
12-21-2010, 11:08 PM | #10 | |
Member#: 159682
NESIC
You'd need the water crossover pipe from a newer wrx, it dips lower for clearance and rework the fuel lines or go to parallel fuel lines. For even more room, you can use intake manifold spacers and a remote reservoir p/s pump. |
12-21-2010, 11:37 PM | #11 |
Member#: 94268
TXIC
newer wrx as it 02+ right?
Snaking the inlet might be cheaper than going rotated.... |
12-28-2010, 07:16 PM | #12 |
Member#: 159756
International
check australia for a rotated kit
12-29-2010, 07:14 PM | #13 |
Member#: 94268
TXIC
They have rotated kits in UK... probably gonna order through them
Will this brake kit fit with my wheels? | masterpickle | Brakes, Steering & Suspension | 5 | 07-29-2008 12:19 AM |
FS:PA gt3076R rotated kit or just turbo,willing trade for 35r | JT's06sti | MAIC Private Classifieds | 0 | 03-18-2008 02:24 PM |
Will hidplanet valeo kit fit an 04-05? | chackoc | Electrical & Lighting | 41 | 07-04-2006 06:57 PM |
will GC8 parts work / fit on GD? sedan. | jaxscuby | Brakes, Steering & Suspension | 2 | 10-22-2002 05:55 AM |
Dumb question: Since the WRX aero kit fits the RS front bumper, will other kits fit? | Andrew | Interior & Exterior Modification | 3 | 06-05-2001 08:54 PM |
