Welcome to the North American Subaru Impreza Owners Club Monday June 16, 2025
Old 12-23-2010, 10:43 PM   #1
pjensen641
Member#: 36777
2004 WRX Wagon
Exclamation GSP Axles (Advace Auto)...Pure Garbage
To anyone looking to replace CV axles with cheaper aftermarket ones....Beware of the GSP ones from Advance Auto Parts.
I have a 2004 WRX wagon. The earlier model with the stub axles coming out of the transmission. The CV shafts have a female inboard end on the fronts. I mention this because maybe it is just a problem with this specific configuration.
Anyway, I replaced all 4 axles because of a torn right front and torn left rear boot. Figured they must all be getting worn and cracked. On some of the reviews and advice here, I picked up the GSP axles. Immediate after replacement, the front end knocked. It was worse when cold, and when accelerating. Never really went completely away. I thought it was more of a rubbing sound on just to front left at first, an though maybe the outboard seal shield might be rubbing the hub. It was slightly bent out of the box, but never though much of it.
I thought the noise might go away if it was just the shield. Figured it would wear away after a bit. Not so. The noise grew louder. I picked up another one from Advance to swap the left out (thought only the left was clunking). The new one did the exact same thing, just not as loud. Now I could hear that both were clunking. Knew it was both by the way the frequency would change going around a corner, the knocking would sync up and then go out of sync.
So now I was pissed. Wanted to find out exactly what part was clunking. Jacked it up and spun the wheels and couldn't hear anything. Got underneath and started tugging on parts. Both the axle and inboard joint were loose. I am nearly positive that the inboard CV joint was the culprit. It fit so loose on the splines that i think it was rocking back and forth, while pivoting about the roll pin.
Back to the first new one that I had just pulled out. Started twisting all the joints and feeling for looseness of the CV bearings themselves. I could definitely feel play in both joints. In fact, the play was worse that the OEM one I had pulled out...and it had been running without grease for 5,000 miles!
So long story short...I replaced these pieces of garbage with some NAPA MaxDrive units...Problem solved. Only good thing about the GSP axle is that I can now swap a pair of front axles in an hour...too much practice. Now I am paranoid that the rear axles I installed might be of similar crap quality.
pjensen641 is offline   Reply With Quote
Old 12-24-2010, 03:23 PM   #2
REX_WGN
Member#: 107618
06 GG WRX / 09 FXT
@florencedestinedfxt
How come you didnt try to get oem ones? Too expensive? To me, some parts are worth it to get other than oem ( as in cheaper) but axles seem pretty important and I would've went that route. How are the napas holding up?
REX_WGN is offline   Reply With Quote
Old 12-24-2010, 04:43 PM   #3
Csquared33
Member#: 198053
02 WRX Wagon
www.efilogics.com
next time just replace the boot. the strength of the oem cv joints is unrivaled
Csquared33 is offline   Reply With Quote
Old 01-27-2011, 11:03 AM   #4
jash
Member#: 223671
2002 wrx
sedona red
wrong posting sorry
jash is offline   Reply With Quote
Old 01-27-2011, 11:07 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The only non oem axles that we use are Empi. They are quite good. We have them in you guys want them.
Tony
Old 01-27-2011, 11:38 AM   #6
Arnie
Member#: 1725
2002 Subaru Forester
SG silver
Any of the refurbished axles I've gotten from Subaru haven't been the "green" OEM ones. They have lasted longer than PEP Boys and Kragen but no where close to OEM. I'm tempted to just buy low mileage take-off axles!
Arnie is offline   Reply With Quote
Old 01-27-2011, 12:38 PM   #7
kumanchu
Member#: 146696
Tony
are they on your site or should I call?
kumanchu is offline   Reply With Quote
Old 01-27-2011, 01:00 PM   #8
Legacy777
Member#: 4800
1990 Legacy & OB XT
AWD 6MT EJ22T AWIC Swap
I tried the GSP axles on my Impreza....they were horrible...had vibration leaked grease. I took them back and told Advance I didn't want a replacement I want my money back. I ended up having the subaru axles rebuilt. The rebuilt axles were fine.
Legacy777 is offline   Reply With Quote
Old 06-18-2011, 10:44 AM   #9
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
I also had horrible experience with GSP axle. Had this thump sound that puzzled me for about 6 months.
I ended up going with spare OEM axle and now noise is gone.
Old 06-18-2011, 11:35 AM   #10
HiTempguy
Member#: 189427
Are these axles "rebuilt"? You can not actually rebuild a CV joint (you can "sort of"), hence the problem you guys are experiencing. New is the only way to go.
HiTempguy is offline   Reply With Quote
Old 06-18-2011, 09:25 PM   #11
crxgator
Member#: 39017
2017 VW Alltrack "R"
Ive been having good luck with my NAPA axles in the front so far.
crxgator is offline   Reply With Quote
Old 06-19-2011, 09:55 PM   #12
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
nope, they are NEW.
Old 06-20-2011, 02:43 PM   #13
Lboogie
Member#: 171611
2014 FiST
Blk
*NAPA know how*
sorry, couldn't resist
Lboogie is offline   Reply With Quote
Old 06-20-2011, 04:41 PM   #14
69subaru360
Member#: 159682
1995 WRX
2015 F150
I use only good used factory axles or new empi from rock auto. The empi are only $60 new and you can't beat that anywhere. The new empi are a quality brand made in an iso 9000 factory not "rebuilt" by clueless minimum wage workers who knows where.
Old 06-20-2011, 05:49 PM   #15
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
problem is EMPI only sells front axles...
Old 06-21-2011, 09:23 PM   #16
Dentt42
Member#: 180570
I've had very good experiences over the years with Raxles in Gainesville, FL. They're a little more, but are built in house with USA components, and their customer service is excellent.
www.raxles.com
Dentt42 is offline   Reply With Quote
Old 01-09-2012, 08:18 PM   #17
Spigatelli
Member#: 306391
2005 Outback 2.5i
+1 for Raxles. I have been running them on my Outback for almost a year and around 20k miles. They are solid.
Spigatelli is offline   Reply With Quote
Old 01-10-2012, 12:19 AM   #18
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Let this be a lesson. If it ain't broke, don't fix it. My rear axles are still stock with 205k miles. Since the rear wheels don't turn, there is a lot less stress on the boots.
bugeyetex is offline   Reply With Quote
Old 01-10-2012, 09:03 AM   #19
sszyma
Member#: 31399
2007 WRX
2015 SQ5
Total agreement. My original axle boot deteriorated and I figured rather than replace the boot I would by the Advance GSP axle. I went through three of them and they all made noise after 15-20 miles. Since I tossed the original I had to bite the bullet and by a rebuilt OEM unit for 3x the price. However the rebuilt OEM has been great for 2k miles so far.
sszyma is offline   Reply With Quote
Old 01-11-2012, 07:48 AM   #20
Driveshaft shop
Member#: 306253
i see that your car is a wagon, do they show different part numbers for the sedan VS the wagon. the wagon axles are a bit shorter ? I'm not trying to support the axles listed just checking to see if this may be the problem. We will be spending some time on the forum very soon and want to see if we can help with certain things like this.
Frank
Driveshaft shop is offline   Reply With Quote
Old 01-11-2012, 08:51 AM   #21
sszyma
Member#: 31399
2007 WRX
2015 SQ5
I had the "Wagon Axle" or at least that is what the box and the computer said. They did have a different part number for the 02 Sedan so I was assuming different lengths. After ten miles of driving on one of them I removed it and felt rotational pay on both ends!
Old 01-11-2012, 09:34 PM   #22
Driveshaft shop
Member#: 306253
there is allot of junk parts coming out of China as far as axles go,not all of them are bad but when the part can be purchased for less than the material costs here you have to wonder why (there buying our scrap at a higher rate than we can supply right now) see if you can find some "factory Rebuilts" they would be the best option.
Old 01-12-2012, 10:52 AM   #23
boilermaker29
Member#: 278025
2011 IMP 2.5i HATCH
BLUE
This is why I use raxles, you actually get a decent rebuilt set the first time. Good balance between expensive OEM and the cheapo's.
boilermaker29 is offline   Reply With Quote
Old 01-12-2012, 02:52 PM   #24
FCP Import
Member#: 305489
91 skyline GTR
champ white
We carry the EMPI axles as well and they are on our website if you want to check it out.
FCP Import is offline   Reply With Quote
Old 11-28-2012, 10:51 PM   #25
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
bumpdigity. I need front wagon axles.
how much are EMPI's?
Do sedan axles work on wagons?
chimchimm5 is offline   Reply With Quote
FS : FL: 02-05 wrx Exedy Stg 1 Organic HD Clutch kit/STI Axles/WRX Axles/Diff etc.. simon930 Drivetrain 44 02-22-2011 07:21 AM
Too much garbage, where to get rid of it before garbage day? Davenow Texas Impreza Club Forum -- TXIC 29 05-08-2007 03:28 PM
Garbage my CAR IS!!!! GARBAGE!!! aznburn210 Member's Car Gallery 30 01-30-2007 07:18 PM
You got Garbage in my PBS! You got PBS in my Garbage! beachbum Off-Topic 10 07-07-2006 11:50 AM
Me (99 2.5RS auto) vs. Wife (2000 Altima auto) spshultz General Forum Archive 14 09-10-2000 10:17 AM
