Welcome to the North American Subaru Impreza Owners Club Thursday December 1, 2022
Old 01-02-2011, 02:01 PM   #1
79tranny
Member#: 209661
JDM RHDswappedWRX
2012 Dodge Ram-daily
Default Radiator support removal?
I tried posting under service and maintenance but it seems not many people post in there.. Hopefully this can still count under exterior work..
I had an accident in my bugeye and got a new bumper support and radiator support.. But can seem to figure out how it comes off my car.. There are both bolts and tac welds?.. Just wondering if anyone has replaced their's, how they did it, pics help if available!
Thanks for any info
79tranny is offline   Reply With Quote
Old 01-02-2011, 02:06 PM   #2
thescooby05
Member#: 191563
2005 STI Protuned
theres tac welds all around the support, best to drill them out ( they have drill bits to do just this) or you can drill strait thru and use the holes on the back side to roset weld the new one back on for a stock looking weld You can use somthing to separate it from the front of the car(pry bar maybe) make sure you disconnect your battery unless u want to replace your airbags and sensors too
thescooby05 is offline   Reply With Quote
Old 01-02-2011, 02:35 PM   #3
79tranny
Member#: 209661
JDM RHDswappedWRX
I heard something like that, sounds good I'll find that drill bit thanks!
Old 01-02-2011, 03:02 PM   #4
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info
Check Eastwood for spot weld drill bits.
darkstarmoto is offline   Reply With Quote
Old 01-02-2011, 03:04 PM   #5
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
Yup just a bunch of spot welds. I just swapped to the 06 front end from 04. Little tip, use the correct size drill bit and make sure its center or you'll have a hard time getting it off.
Ethan_Drift is offline   Reply With Quote
Old 01-03-2011, 11:29 PM   #6
ihayhurs
Member#: 252319
Default Welds
I also had a recent collision with my bugeye. I had the bumper skin off today and was looking at the rad support.
1. I can see that the upper tie bar is welded to the sides of the rad support, but is it also welded at ends? It looked to me like it was just a single bolt on each end through the fenders.
2. Can the entire rad support (I believe that's an upper, two lower, and L&R sides) come out without breaking any welds?
3. Are there any welds for the bumper beam? It looks like it is just 8 bolts. Damage to my beam was limited to some push-back of the top strip that the skin is pinned to--think I got it straight enough it won't need to be replaced.
Thanks.
Ian.
ihayhurs is offline   Reply With Quote
Old 02-10-2011, 10:02 PM   #7
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
is the upper tie bar easy to remove? just a couple of bolts and some spot welds along the way correct? not trying to remove the whole support just the tie bar...
jrrevo1 is offline   Reply With Quote
Old 02-10-2011, 10:27 PM   #8
sleazy07sti
Member#: 273116
2007 Hawkeye Sti
0bp
Impreza WRX STi
sleazy07sti is offline   Reply With Quote
WTB: Radiator Support, Radiator & shroud... RealiTnh NESIC Private Classifieds 0 04-07-2009 08:35 PM
Removing Radiator Support timmyp Interior & Exterior Modification 1 09-23-2006 08:58 PM
Bent radiator support off roading underledge Interior & Exterior Modification 4 02-02-2006 07:44 PM
WTB: 02 wrx Radiator Support WRB4U Private 'Wanted' Classifieds 1 04-30-2004 10:06 PM
Headlights, Fender, Airbags, Radiator, Radiator Support, and more elhalisf Private 'Wanted' Classifieds 23 03-20-2004 05:47 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
