Welcome to the North American Subaru Impreza Owners Club Friday April 25, 2025
Old 01-10-2011, 11:16 AM   #1
paN1k
Member#: 218607
2013 WRX
Ice Silver
Default Flashing Air Recirculation ?
Hey guys, I have noticed for the 2nd time my Air Recirculation light flashing. It does it for about 5 seconds sometimes. Does anyone know what this means? I was running the heater earlier and wasn't trying to recirculate the hot air.
paN1k is offline   Reply With Quote
Old 01-10-2011, 11:26 AM   #2
09rexwagon
Member#: 216135
I've seen that a few times. Couldn't find any documentation on it though. The outdoor temperature flashes at 37 degF as a warning and the OM outlines that, but nothing for the recirc light blinking.
09rexwagon is offline   Reply With Quote
Old 01-10-2011, 11:32 AM   #3
paN1k
Member#: 218607
2013 WRX
Ice Silver
The only thing I can think of is that it's warning you that the air is hot? I will bring it up when I get my oil changed next time. Yeah I've seen the flashing 37 degrees but no documentation on the flashing light on the air recirc. Thanks for the response.
Old 01-10-2011, 11:34 AM   #4
09rexwagon
Member#: 216135
Please update this thread if they say anything, thanks.
Old 01-24-2011, 09:09 AM   #5
echardcore
Member#: 260638
2011 WRX Sedan
Spark Silver Metallic
This happened to me today in my 2011. First there was a short squeal sound from the engine. Then the recirculate light flashed about 3 or 4 times. This was on the first start and it is extremely cold today.
echardcore is offline   Reply With Quote
Old 02-23-2011, 08:41 AM   #6
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Mine did the same thing last night and it is not cold here in Florida, it was 63 when I started it and it did not do it this morning. Anyone find out yet?
JordanM9 is offline   Reply With Quote
Old 03-16-2011, 07:57 PM   #7
wrx2011dreamer
Member#: 263614
2011 WRX 5-Door
Satin White Pearl
My 2011 just did it this afternoon. I drove for about 30mins...parked for about 5 mins...started car with all electronics off and in neutral.....recirculation light flashed about 5 times and than stopped. Car started up and drove fine....does anyone know what this means? It was 55 degrees outside and mostly Sunday. Can't think of any reason this would happen on my 2011 wrx with 7200 miles on it.
wrx2011dreamer is offline   Reply With Quote
Old 03-18-2011, 04:18 PM   #8
wrx2011dreamer
Member#: 263614
2011 WRX 5-Door
Satin White Pearl
Bump!
Old 05-24-2011, 04:35 PM   #9
wrx2011dreamer
Member#: 263614
2011 WRX 5-Door
Satin White Pearl
Happened again today. About 80 degrees, drove the car for about an hour, stopped and turned of car/all electronic components. 15 mins later, started car and the recirculation light flashed about 4 times. Anyone know why it did this?
Old 05-24-2011, 06:37 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
is this in the owners manual???
Old 05-24-2011, 07:42 PM   #11
09rexwagon
Member#: 216135
Nope. The only 'flashing' reference in the OM/FSM is to the temperature gauge which flashes when it hits 37 degF to warn of potentially slippery bridges.
Old 05-24-2011, 07:52 PM   #12
hardball75006
Member#: 214319
2009 Legacy 2.5 NA
Diamond Grey Metallic
I don't know if this would apply to the WRX but I found this on a Forester forum:
Hey everyone, I had an issue last week where when starting my '09 Subaru Forester the recirculation light blinked several times after starting up the vehicle. I did a web search but couldn't find any explanation for it so I emailed Subaru and got a reply from them a day or two later. I figured since I didn't find an answer when searching for it, I'd share the info here so if someone else does a search for the info they'll hopefully find it.
In their reply, Subaru explained that the recirculate light blinks if it detected a problem during the system self check. They went on to say that since it only occurred the one time that it's not an ongoing issue and that nothing needs to be done at this time. However, if it occurs again in the future (even just momentarily), then I would need to bring the car in.
Anyways, if anyone needs this info I hope they find it.
hardball75006 is offline   Reply With Quote
Old 05-24-2011, 09:55 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
filter may need to be cleaned
Old 05-25-2011, 08:12 AM   #14
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
FSM:
Short circuit: FRESH/ RECIRC switch LED blinks (Illuminates for 0.2 sec. ***8660; turns off for 0.2 sec.)
Open circuit: FRESH/ RECIRC switch LED blinks (Illuminates for 1 sec. ***8660; turns off for 1 sec.)
jonklein611 is offline   Reply With Quote
Old 05-25-2011, 09:09 AM   #15
wrx2011dreamer
Member#: 263614
2011 WRX 5-Door
Satin White Pearl
Thanks for the good info! Crazy that this is not stated in the manual. It's happened maybe 3 or 4 times in the past 6 months. I wonder if it's worth the trip to the dealer. I thought that was the purpose of the CEL.
Old 05-25-2011, 09:26 AM   #16
09rexwagon
Member#: 216135
Originally Posted by jonklein611 View Post
FSM:
You sir are a better searcher of the FSM than me . I searched for 'flash' and 'flahing' but not 'blinks' .
It happened to my 09 once in the 15k I owned it.
Old 05-25-2011, 09:37 AM   #17
wrx2011dreamer
Member#: 263614
2011 WRX 5-Door
Satin White Pearl
FSM:
Short circuit: FRESH/ RECIRC switch LED blinks (Illuminates for 0.2 sec. ⇔ turns off for 0.2 sec.)
Open circuit: FRESH/ RECIRC switch LED blinks (Illuminates for 1 sec. ⇔ turns off for 1 sec.)
What does this actually mean regarding my situation?
Old 05-25-2011, 10:15 AM   #18
jonklein611
Member#: 117776
WR Blue Pearl
The diagnostics section is a tough one, but the new manual is actually easy to dive through.
It's the error code that it's throwing. So if the blink is faster, it's the one, and so on. You may want to bug your friendly dealership to have them check it out with their diagnostics software.
Old 10-06-2011, 01:19 PM   #19
02fastWRBLUE
Member#: 52590
just installed 4 sets of lights on my 2008 STi last night(previously had 3 installed with no issues). Lights are all PIAA(2 sets of 510s, 1 set of 520s and 1 set of CC HIDs). Instructions say to wire them into a 15A light source, so I spliced from 4 fuse wires into 2 and plugged them in with my 15A lighting fuse in the fusebox.
Didn't start the car last night because all 4 switches lit up green ready to go.
Went to start the car this AM and at first try it hesitated to start. After 5 seconds of cranking I stopped. Went to go start it again and it fired right up, but the Air Recirc light flashed. It flashed about 5-10 times. I didn't count how long it was illuminated each time, but it was likely .2s signalling a short.
figured this might be useful for someone searching the future. yay, time to troubleshoot!
02fastWRBLUE is offline   Reply With Quote
Old 10-06-2011, 03:31 PM   #20
echardcore
Member#: 260638
2011 WRX Sedan
I feel that when this happens, the car is not starting right up for whatever reason. It has happened in hot and cold weather which is odd.
Old 02-13-2012, 09:59 PM   #21
L.P.
Member#: 236129
2009 WRX
Satin White
did anybody ever figure out what really caused this? I have had this happen to me on a couple of occasions does not seem to effect the car in any way really though.
L.P. is offline   Reply With Quote
Old 04-11-2014, 04:35 PM   #22
WhiskeySandwich
Member#: 364126
2007 WRX Wagon
CGM
Bump. What's the word?
WhiskeySandwich is offline   Reply With Quote
Old 03-23-2015, 09:21 PM   #23
Reezo
Member#: 404929
2010 Subaru STI H/B
bump again This happens to me once in a while as well, i'd probably say about once a month maybe once every couple months ? Still no one as true answer to the cause ?
Reezo is offline   Reply With Quote
Old 11-18-2015, 09:17 AM   #24
Sp2Pilot
Member#: 267212
2015 FXT
Did you guys that had this problem happen to have the recirc button enabled, along with having where the air comes out from (head, head/feet, feet etc etc) set to auto?
Or possibly even the fan set to auto with the recirc button enabled? <--- I don't think that's the cause.
This happened to me once the other day. I noticed that the dial that controls where the air is distributed was set to auto.
Before I shut the car down, I set all the dials to "off" with recirc still enabled, started the car and I have not seen this happen since then.
Sp2Pilot is offline   Reply With Quote
Old 12-14-2016, 10:07 AM   #25
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info
Thread necro. Had the flashing Ricirc button a few days ago and have been researching the issue. To expand on jonklein611 post...a bit more detail of what the flashes mean, only problem is you need to be plugged into the Subaru Select monitor to enter the diagnostics mode on the HVAC system. They can narrow down which sensor is acting up.
darkstarmoto is offline   Reply With Quote
2004 wrx ecu stage 2 flash, $65 shipped, and secondary air injection pump for $35 Keif Engine/Power/Exhaust 5 05-08-2011 01:35 PM
FS : 2008-2011 WRX Perrin Cold Air Intake CharcoalSTI Engine/Power/Exhaust 4 01-14-2011 11:30 AM
WTB : bpv recirculating elbow and air return hose wrxtuner570 Private 'Wanted' Classifieds 2 09-28-2010 12:07 AM
im getting an APS cold air intake and an ECUtek flash done soon on my sti FAST CO STi Proven Power Bragging 35 07-06-2004 03:39 AM
Air recirculation meter? wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 14 10-20-2002 05:32 PM
